Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 11-07-2009, 09:35 PM   #1
kylewilliams
Junior Member
Default Reznor UDAP 45 is Installed and Inspected
Took a little while, but I got my Reznor UDAP 45 all done. I scratched my head for a while trying to decide how to mount it as there is no attic space above the ceiling to hang the heater with ready-rod.
I deck-screwed 2x4's along the wall 1-1/2" down from the ceiling. Then, I mounted 2x4's with 3/8" lag bolts to the top of the heater. The lag bolts are counter-sunk in the boards so the boards sit flush against the ceiling. The bolts are then held solid with nuts and lock washers against the heater and the boards. I had a buddy help me lift the heater and slide it into place on the top on the 2x4's on the wall. I was able to catch a couple joists in the ceiling to put some deck screws through the diagonal boards. The diagonal boards also have L-plates attached to the wall boards.
I ran the B-vent as per instructions with a thimble sleeve through the wall. Instead of black pipe, I used 1/2" Swagelok stainless tubing and fittings. They are commonly used in the oil and gas industry, which I work in, and are far better than pipe. I got a letter from Swagelok indicating CSA approval, so my inspector had no issues with it. I also used a Fluke pressure calibrator from work to check the inlet and regulator outlet pressures, but no adjustment was needed as per the instructions.
The heater location was close to a receptacle, so I simply made up a cord to plug it in. I also had a spare digital thermostat lying around so I can program all my heat settings.
As a final touch, I removed the Reznor decals and painted the air louvers orange to match the garage. I also filled all the wood screw holes and caulked the seams along the mounting boards.
kylewilliams is offline   Reply With Quote
Old 11-07-2009, 10:37 PM   #2
Steevo
Senior Member
Steevo's Avatar
Default Re: Reznor UDAP 45 is Installed and Inspected
That was an ingenious mounting solution, and the stainless swagelock gas line is very nice!
Steevo is offline   Reply With Quote
Old 11-08-2009, 02:42 PM   #3
Schrodingers Cat
Senior Member
very clean install...nice
Schrodingers Cat is offline   Reply With Quote
Old 11-08-2009, 09:15 PM   #4
Motown 454
Senior Member
Motown 454's Avatar
Nice job it looks great.
Motown 454 is offline   Reply With Quote
Old 11-08-2009, 09:28 PM   #5
notme_76
Junior Member
where did u get the chimney cap...looks different?
notme_76 is offline   Reply With Quote
Old 11-08-2009, 09:38 PM   #6
Weedwaka
Senior Member
Weedwaka's Avatar
Nice and clean !!
Weedwaka is offline   Reply With Quote
Old 11-08-2009, 10:18 PM   #7
kylewilliams
Junior Member
Quote:
The cap is made by www.eccomfg.com, same as the rest of the ducting.
Old 11-08-2009, 10:33 PM   #8
D.J.
Senior Member
Well I really hate to tell you but your drip leg does not include a change of direction as required by NFPA Pamplet 58 "Gas Code". From the photo I can't tell if you installed a noncombustible sleeve where your gas line breaches the wall. Other than than those two items, it appears to be a flawless install. Yes I know I'm just too picky.
________
The cigar boss
D.J. is offline   Reply With Quote
Old 11-17-2011, 10:36 AM   #9
SeanM
I really like the clean look of the swagelok, and with using swagelok all the time at work in our products I am a huge fan of the product.
Although my inspector said that I could not use compression fittings. I don't know if this is true everywhere, just thought it was interesting.
SeanM is offline   Reply With Quote
Old 11-17-2011, 11:05 AM   #10
Innov8tive1
Senior Member
Looks like the same cap that came with my Reznor UDAP 75. I'm waiting on the vent to arrive. I'll post pics when it's all done.
Nice looking install!
Innov8tive1 is offline   Reply With Quote
Old 11-17-2011, 11:58 AM   #11
dave67fd
Senior Member
dave67fd's Avatar
Nice job on the mounting, nice clean look. I also like the Swagelok gas line. I too use the stainless pipe and Swage fittings in my job in the Pharmaceutical buisness but my town codes are stringent on the black iron on new installs. Who would think in a little hic town in NH codes would be a PITA but they are there for a reason.
Maybe just the pic but the louvers look far from the same orange as the wall?
Again nice job.
__________________
Check out my Build at:
http://www.garagejournal.com/forum/s...d.php?t=102939
dave67fd is offline   Reply With Quote
Old 10-27-2016, 10:12 AM   #12
wirthj23
Junior Member
How far down is your exhaust pipe from the soffit?
wirthj23 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
