Go Back   The Garage Journal Board > The Garage > Free Parking
Reply
Thread Tools Display Modes
Old 11-08-2009, 09:53 AM   #1
Bencrx91
Bencrx91's Avatar
Default How to replace fan blower resistor on GMC Safari / Chevy Astro (aka GM Engineering)
Take a look, I created a procedure out of it (lol).
http://www.benoitcloutier.com/BAGNOL...esistor_EN.pdf
Ciao,
Ben
__________________
Ben
Bencrx91 is offline   Reply With Quote
Old 11-08-2009, 10:31 AM   #2
Britwrench
Senior Member
Default Re: How to replace fan blower resistor on GMC Safari / Chevy Astro (aka GM Engineerin
Excellent!!!!!!!! Ever thought of writing repair manuals for manufacturers?
Never going to happen though, most of the current ones are unreadable, so why change a tradition?
Britwrench is offline   Reply With Quote
Old 11-08-2009, 11:29 AM   #3
tatra
Senior Member
tatra's Avatar
very good writeup...........tech. eng. man. writers are probably putting a hit on you now.........don't mess with tradition.......
tatra is offline   Reply With Quote
Old 11-08-2009, 02:52 PM   #4
Old Donn
Senior Member
Old Donn's Avatar
You're a little late, Ben. I thought had to do this job a few years back. As you mentioned, the resistor's a dealer only item and the price had gone up to $75 if memory serves. Went thru all the steps up to replacing the resistor. Turned out it was OK, the blower motor was bad. The blower's encased in a rubber boot. Had to cut out the front with a razor knife to access. That noise you thought was thunder was me shouting curses toward the GM Tech Center.
Old Donn is offline   Reply With Quote
Old 11-08-2009, 05:40 PM   #5
Torque1st
Senior Member
Torque1st's Avatar
One thing to remember. The blower resistor may fail again if there is no airflow over it when tested.
__________________
Faster, Better, Cheaper: Pick Two
The FairTax
Follow the Money. -72chevy
Yes, I am insensitive and yes, not politically correct, and yes, Im sure I offended someone,... -Busted_Knuckles (Me too, plus I am old, tired, and grumpy!)
Read "The Marching Morons" Here
"Works" <> Safe, Good, or Right
"You can't fix stupid." -Ron White
Torque1st is offline   Reply With Quote
Old 09-05-2010, 09:27 PM   #6
AWalker42
Junior Member
Question: I ran into the same problem with my 2002 Safari and now have replaced the fan blower resistor for the 2nd time. Before the first failure, I smelled a burnt wiring smell . . . same for the 2nd failure. I did not encounter such problems until about 9 months ago. The van is now 8 years old. Why does the resistor continue to fail?? (and it now seems to fail more frequently)
AWalker42 is offline   Reply With Quote
Old 09-05-2010, 09:30 PM   #7
Red Green
Senior Member
Red Green's Avatar
Your blower motor is going bad causing the resistor to fail.
__________________
"If the women don't find you handsome, they should at least find you handy."
"Unlike love respect can't be bought" H. Simpson
Red Green is offline   Reply With Quote
Old 09-05-2010, 09:30 PM   #8
jethro29
Senior Member
i would test your blower motor for a high current draw,that's probably what's burning up your resistors.
jethro29 is online now   Reply With Quote
Old 09-05-2010, 11:20 PM   #9
Radio Flyer
Senior Member
Look at the connector. If the terminals are loose, it will cause resistance. My terminals were burned. the pigtail cost just as much as the resistor. It also comes with all one color wire for even more fun!
Radio Flyer is offline   Reply With Quote
Old 09-06-2010, 02:10 AM   #10
Lotek
Senior Member
Lotek's Avatar
The problem is usually the connection at the resistor, I always replace the resistor and the connector at the same time. The telltale is that the connector has turned yellowish brown near the orange and/or black wires. If it were my vehicle and wiggling the connector made it work, I would be tempted to replace the connector only, cleaning the contacts in the resistor until they were shiny. Customer cars get both, since I can't be sure how long it will last, and the new resistor is an improved type. I believe the connector is available through the aftermarket much cheaper than from GM, it is a Delco pigtail, don't have the number handy. Blower motor failure is rare on these since it mounts sideways. Truck and some passenger car motors can fail because they are vertical and water can collect in the motor if the evaporator drain is restricted. If If the blower motor gets noisy, before removing it, reach into the fan opening from the inside of the dash (with it turned off) and feel around inside the squirrel cage fan to make sure there isn't any trash in there. You wouldn't believe some of the crap I have pulled out of blower motors... napkins, rubber gloves, other...rubber products, 1/2 a mouse...
__________________
Tim
Another example of when God turns to Darwin and says "I thought you were going to fix this s@#t".
"You keep using that word. I do not think it means what you think it means. "
"I have a hammer! I can put things together! I can knock things apart! I can alter my environment at will and make an incredible din all the while! Ah, it's great to be male!" -Calvin
Lotek is offline   Reply With Quote
Old 09-13-2010, 09:55 PM   #11
kidashley25
it is located under the dash behind the glove box. there are 2 bolts hold it in place. remove the wire connecter and the 2 bolts and slide it out.
__________________________________________________ _________________
BLOWER MOTOR ASSEMBLY -- With fan blade; A high quality, direct fit OE replacement blower motor assembly.
kidashley25 is offline   Reply With Quote
Old 09-14-2010, 11:15 AM   #12
Hlidskjalf
Senior Member
Hlidskjalf's Avatar
Thanks for the write up. Any insight as to why some of my astros only blow on defogger? I had the issue with bad fan resistor, but now a couple of my astros only blow through the defogger.
Ideas?
Hlidskjalf is offline   Reply With Quote
Old 09-14-2010, 11:36 AM   #13
MattT
Senior Member
Quote:
Ideas?
First thing I'd check is the body vacuum. Had a Jeep Grand Cherokee stuck on defrost couple weeks back. Body vacuum line had fell off the intake. Easy $20
MattT is offline   Reply With Quote
Old 09-14-2010, 04:29 PM   #14
Lotek
Senior Member
Lotek's Avatar
Ideas?
There is a plastic tube that connects to the pcv fitting on the left side of the intake manifold about half way back, the other end snakes in front of the throttle body over to a tee fitting near the A/C accumulator. A temporary fix is to use some vacuum hose to reconnect where it is broken, but the pipe is about $20 from the dealer and will last a lot longer than hose. I do it from the front, but it is a lot easier to remove the doghouse and get the engine side that way.
__________________
Tim
Old 09-14-2010, 06:40 PM   #15
Hlidskjalf
Senior Member
Hlidskjalf's Avatar
Thanks, I had a look at the vacuum hoses. I have a few Astros and it seems the resistor and vacuum hoses all broke at the same time.
One truck had a clog in the vacuum line and the other crumbled when I grabbed it. I thought I was going to have to leave my arm inside there with that tight squeeze, lol.
Are those fan resistors dealer only items? The one in my 05' seems to look like the updated version. Did it come like that or was it previously replaced?
Old 06-01-2011, 10:51 AM   #16
rocklobster
Senior Member
rocklobster's Avatar
Hey guys digging up an old thread here and I think that I have the same problem on my 2003 Astro. Thanks for the tutorial BTW Bencrx91!
A few weeks ago I had a burning smell in the van and outside while driving with the fan on. Currently I am rebuilding the alternator and have the battery disconnected, yesterday I reconnected the battery and the fan started blowing on high without the ignition on, I played with the fan control switch and it controlled the headlights!
Finally I researched this topic and found the common problem of the relay. I pulled mine and it dosent look burnt it just looks as though the green coating on the exposed circuit board is peeling off. I am continuing to diagnose the issue by checking off the easy things first before I buy a new relay.
The question I have is should there be 12v at the wiring connection for the fan relay when the ignition is off?
rocklobster is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
