Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 11-18-2009, 01:08 PM   #1
Ryan
Administrator
Ryan's Avatar
Default Military Ratchet Set
Here's an interesting find... A set of government issue SAE ratchets. I don't believe I've ever seen them before and was wondering if any of you fellas have the goods on...
Ryan is offline   Reply With Quote
Old 11-18-2009, 01:38 PM   #2
forceyoda
Senior Member
forceyoda's Avatar
Default Re: Military Ratchet Set
Looks like proto's ratcheting flare nut set-
http://www.stanleyproto.com/default....tCatalog=PROTO
forceyoda is offline   Reply With Quote
Old 11-18-2009, 01:53 PM   #3
blazemaster83
Senior Member
Never seen those before, but they look nice. I like the green roll-up
blazemaster83 is offline   Reply With Quote
Old 11-18-2009, 01:53 PM   #4
MAD
Senior Member
I believe they are made by Stride Tool / Imperial.
They call them "Kwiktite" wrenches.
http://www.stridetool.com/tools/kwik...wrench_01.html
MAD is offline   Reply With Quote
Old 11-18-2009, 03:12 PM   #5
d110pickup
Senior Member
I bought a set of those back about 1990 - 91 and they work great on flare nuts!
Mike
d110pickup is offline   Reply With Quote
Old 11-18-2009, 03:20 PM   #6
caper
Senior Member
caper's Avatar
Send a message via MSN to caper
Mostly designed as hydraulic wrenches if I remember right.We have a set up to somewhere around 1 1/2" at the shop.As new never used,hanging on the wall for about 20 yrs I'd guess.Not something we need very often.
__________________
Quote:
Originally Posted by mrholeshot View Post
Takes about two minutes once you have the shaft in hand.
caper is offline   Reply With Quote
Old 11-18-2009, 04:11 PM   #7
scottybaccus
scottybaccus's Avatar
Pretty nifty!
__________________
Who cares?
scottybaccus is offline   Reply With Quote
Old 11-18-2009, 09:42 PM   #8
kwb
Senior Member
We use those for the piping of heavy truck air systems - generally called slap wrenches by our guys. Push to connect are getting better but we haven't gone to them 100% yet so we have lots of the compression fittings to tighten.
kwb is offline   Reply With Quote
Old 11-18-2009, 09:50 PM   #9
UncleDirty
Senior Member
UncleDirty's Avatar
I've had a set of those for over 20 years that I got from Mac. I have not used them that much, but when I have, they sure work bitchen.
UncleDirty is offline   Reply With Quote
Old 11-20-2009, 07:26 AM   #10
Andamo
Senior Member
Back in my working days I bought a set for use at work. I worked in the oil/chemical industry on pilot plants and these are great for working on tubing.
You can just flip the mouth open, put it around the tubing and then slide it onto the nut and tighten or loosen. They're nice too because the equal pressure exerted all around the perimeter on the nut.
Andamo is offline   Reply With Quote
Old 11-20-2009, 08:24 AM   #11
wreckercologist
Senior Member
wreckercologist's Avatar
+1
I've got a set that are branded Armstrong. Invaluable is a tight spot!
__________________
Pride is dead
wreckercologist is offline   Reply With Quote
Old 11-20-2009, 09:35 AM   #12
franzdom
Senior Member
franzdom's Avatar
The handle is all on one side, I can't see how it has equal pressure on all sides of the nut. That would generally only occur with a T-handle type of wrench, like a tap wrench, something with 2 equal length arms on each side.
franzdom is offline   Reply With Quote
Old 11-20-2009, 12:16 PM   #13
mkdive
Senior Member
mkdive's Avatar
I have a double sided one that was built for the compression nut on a angle stop (plumbing)....works great. Had a jobsite a few years back we had to change out 12,000 angle stops. Big PITA!
__________________
"Hammer to shape, Grind or File to fit, Paint to match!"
Posted by Fedwrench
"As a tool whore, it is my duty to have wrenches for every possible occasion".
Posted by TAMPAGT07
"I like my ratchets how I like my women, the more teeth the better".
Posted by stricht8
"When life is over as we know it there will be cockroaches eating Twinkies using craftsman RHFT ratchets."
mkdive is offline   Reply With Quote
Old 11-22-2009, 02:11 PM   #14
Ggg
Senior Member
IIRC about 15 or so years ago Snap-on or Mac had them.
Ggg is offline   Reply With Quote
Old 11-24-2009, 07:32 PM   #15
Kjbakke2
Senior Member
Kjbakke2's Avatar
toptul also makes these....has anybody used them in automotive at all??
Kjbakke2 is offline   Reply With Quote
Old 11-24-2009, 07:41 PM   #16
caper
Senior Member
caper's Avatar
Here's the set at work.Runs from 3/8" to over 2".These ones are branded Parker.
__________________
Old 11-24-2009, 08:00 PM   #17
krusty the clown
Senior Member
krusty the clown's Avatar
Quote:
yes i think all the trucks had them. MATCO introduced them 20 years ago, i sold several sets to the guy's that worked on trash trucks. they liked them for hydraulic lines.
__________________
DEGENERATE Main Entry: 1de·gen·er·ate
Pronunciation: \di-ˈjen-rət, -ˈje-nə-, dē-\
Date: 15th century
1 a : having declined or become less specialized (as in nature, character, structure, or function) from an ancestral or former state b : having sunk to a condition below that which is normal to a type; especially : having sunk to a lower and usually corrupt and vicious state c : degraded 2
krusty the clown is offline   Reply With Quote
Old 12-03-2009, 09:53 AM   #18
claudia
Junior Member
The wrenches pictured are used for tightening airline and hydraulic line fittings. I worked for Mack Trucks and used them when working on the air brakes.
claudia is offline   Reply With Quote
Old 12-03-2009, 05:44 PM   #19
Ggg
Senior Member
Quote:
Huh thats funny back then I was a mechanic for Laidlaw Waste Hauling.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
