Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 11-21-2009, 06:13 PM   #1
jake00
Senior Member
jake00's Avatar
Default best way to strip Thick copper wire?
at the risk of sounding like a meth head.....
We removed a room full of outdated electric panel and disconnects at work. We've got about 300 lbs of Thick (3/4") copper wire.
Whats the best way to strip this?
jake00 is offline   Reply With Quote
Old 11-21-2009, 06:19 PM   #2
metal1313
Senior Member
metal1313's Avatar
Default Re: best way to strip Thick copper wire?
fire....or a stripping machine. other wise id just get a few sharp knives and get cuttin
metal1313 is offline   Reply With Quote
Old 11-21-2009, 06:25 PM   #3
tw33k2514
Senior Member
tw33k2514's Avatar
Utility knife and patients.
That is how I have always done huge wires. But I am sure someone has a better way.
__________________
Quote:
Originally Posted by Merkava_4 View Post
I'm on a one man crusade to rid the world of holes in screwdriver handles and ratchet handles!!
tw33k2514 is offline   Reply With Quote
Old 11-21-2009, 07:49 PM   #4
Stuart in MN
Senior Member
Stuart in MN's Avatar
Check with your local scrapyard, and find out what the price difference is between stripped and unstripped wire. Then, decide if it's worth your time to strip it or just drop it off as is.
I wouldn't burn it. Besides creating a toxic cloud, it may also affect the scrap price.
Stuart in MN is offline   Reply With Quote
Old 11-21-2009, 08:01 PM   #5
jake00
Senior Member
jake00's Avatar
its about 1.80 more a Lb for stripped.
I'm thinking dremel with a cut off wheel
Old 11-21-2009, 08:04 PM   #6
mrb
Senior Member
mrb's Avatar
do you have a table saw? take a piece of PVC pipe slightly larger than the OD of the wire. Clamp it down on top of the saw (on top of and inline with the blade). Turn saw on and raise blade through the pvc pipe to where the blade is protruding through an amount equal to the insulation thickness. Shove the wire through the pipe, have another guy receiving it and yanking the jacket off.
mrb is offline   Reply With Quote
Old 11-21-2009, 08:13 PM   #7
tcianci
Senior Member
tcianci's Avatar
Send a message via AIM to tcianci
If you think it's 300 lbs, and it is 3/4 inch in diameter, then it sounds like you certainly don't have too many lineal feet of it. I would take all my stripping method research time and spend it with a good utility knife and some of your favorite tunes while you just strip it by hand
__________________
People are doing either what they THINK is right or what they KNOW is wrong.
tcianci is offline   Reply With Quote
Old 11-21-2009, 08:28 PM   #8
supertooljunkie
Senior Member
I have always used a utility knife with a new blade and cut the insulation. If you have a heat gun and soften the insulation it will make it easier.
supertooljunkie is offline   Reply With Quote
Old 11-21-2009, 09:18 PM   #9
Bojans
Senior Member
soak it in fuel oil...
Bojans is offline   Reply With Quote
Old 11-22-2009, 12:11 AM   #10
ears
Senior Member
Most places wont take it if you burn it. The best way I have found if it is big enough and long enough is to stretch it tight. I did a little over a thousand pounds of number two through 4/0 last year. I hooked one end to a beam and the other to a forklift and drove it until it was really tight, then I used a drawknife, peels right off. Still not a lot of fun though.
ears is offline   Reply With Quote
Old 11-22-2009, 02:33 AM   #11
Toolhorder
Senior Member
Toolhorder's Avatar
Our local scrapyard take it w/insulation, burnt and clean and pays a different price for each. The burnt price is always better than w/insulation.
Toolhorder is offline   Reply With Quote
Old 11-22-2009, 10:55 AM   #12
M3Pilot
Senior Member
[QUOTE=jake00;658192]at the risk of sounding like a meth head.....
Now that's funny, I don't care who you are.
M3Pilot is offline   Reply With Quote
Old 11-22-2009, 11:13 AM   #13
ironroad 9c1
ironroad 9c1's Avatar
China doesn't care about the quality, they just want quantity.
ironroad 9c1 is offline   Reply With Quote
Old 11-22-2009, 11:46 PM   #14
Costner
Senior Member
Costner's Avatar
Quote:
I'm not sure what a person who is under medical care has to do with it, but I do think removing insulation from wire takes a lot of patience.
Sorry - couldn't resist.
__________________
~Costner (No, not the Waterworld guy)
Costner is offline   Reply With Quote
Old 11-23-2009, 05:20 PM   #15
Mattlt
Senior Member
Mattlt's Avatar
Maybe weld up a V-shaped contraption you could mount in a vise. I'm picturing two sickle sections (google the image) mounted close together, with something else weighting down from the top. A slight twist should cut the insulation, then pull towards you to remove the insulation from the wire.
It would definitely be easier to design something if all the wire was the same diameter.
Maybe a set of 3-4 blades set up in a cross pattern, open in the middle, just the right size to feed the wire through... Just pull it through and the insulation should be cut into ribbons.
Mattlt is offline   Reply With Quote
Old 11-23-2009, 06:37 PM   #16
Steevo
Senior Member
Steevo's Avatar
Two friends an I once pulled all the wire from an old building, piled it onto a car trailer and hauled it out to the desert, where we burned the insulation off of it in a bonfire. Not exactly eco-friendly, but then a lot less damaging than razing a rainforest.
We got top dollar for the copper, which in those days was a fraction of what it is today. As an investment, it would have paid us to hoard it for twenty tears or more instead.
But I don't recall being in it for the long-term return at the time. Whatever we did with the cash has resulted in long-term memory loss instead.
Steevo is offline   Reply With Quote
Old 11-23-2009, 07:57 PM   #17
StumpXJ
Senior Member
StumpXJ's Avatar
We always burned it in piles. It works good, and its a HECK of a lot easier quicker than stripping it yourself. We just used a hard metal rake and moved it around to keep the insulation off of it. We used to do 400 - 500lbs at a time when I worked for an electrician. We used to throw all the scraps in a trailer until it was full, then burn it.
~James
StumpXJ is offline   Reply With Quote
Old 11-24-2009, 01:45 AM   #18
rikmeister
Senior Member
rikmeister's Avatar
you really should not burn it. the coating is very toxic and a carcinogen. so sell it with the coating on it and let the next person find a way to get rid of the coating. all the firms that took the wire from like at&t and stripped had no way of getting rid of the coating and now there are toxic waste sites all over from. I know i live by one. and no one seems to have an answer what to do with it.
rikmeister is offline   Reply With Quote
Old 12-06-2009, 02:09 AM   #19
jake00
Senior Member
jake00's Avatar
I used a dremel with a cutting wheel, went pretty quick,
Old 12-06-2009, 10:24 AM   #20
NUTTSGT
NUTTSGT's Avatar
Quote:
So what what would the price difference been if you wouldn't have stripped it?
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 12-06-2009, 10:55 AM   #21
79BlackPearl
79BlackPearl's Avatar
Many moons ago I inspected General Cables, a producer of Power Service Entrance Cable and Transmission Cable.
To strip wire by hand, the used a utility knife and scored (not cut through), but scored the cable on one side, then 180 degrees on the opposite of the cable, down the length. They then took Klines, grabbed the insulation, and it peeled back like skinning a deer. They would clean 100' of cable in minutes.
However, if they had to strip several hundred feet, they used an automatic stripper.
__________________
2 Acres of fresh land....looking to put a Jeep Workshop on it.
79BlackPearl is offline   Reply With Quote
Old 12-06-2009, 12:12 PM   #22
WinFred
Senior Member
cable ripper...
http://images.google.com/images?q=ca...ed=0CCkQsAQwBg
WinFred is offline   Reply With Quote
Old 12-06-2009, 12:40 PM   #23
wreckercologist
Senior Member
wreckercologist's Avatar
I've used one of these for over a decade. They work very well.
You can find them a lot cheaper at the hardware store.
http://buy1.snapon.com/catalog/item....e=&dir=catalog
__________________
Pride is dead
wreckercologist is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
