Go Back   The Garage Journal Board > The Garage > Flooring
Reply
Thread Tools Display Modes
Old 07-05-2006, 09:41 PM   #1
bhays
Senior Member
Default thickness of concrete slab to weight load?
This is a bit off-topic, but I know that several of you have just gotten done with concrete floors and thought perhaps you could answer my question. I need to pour a 4' x 4' slab in my front yard to set a new fountain on. The fountain weighs about 1200 lbs...
I was planning on pouring a 4" thick pad with Sakrete...will that be sufficiently strong? Thanks for any advice.
bhays is online now   Reply With Quote
Old 07-05-2006, 10:28 PM   #2
boiler7904
Senior Member
boiler7904's Avatar
Default Re: thickness of concrete slab to weight load?
My initial reaction is that 4" is good (5" or more would be better) but i have two quick questions:
1. What is the actual footprint of the fountain? A 1' x 1' footprint is 1200 (weight you list) lbs per square foot. A 2' x 2' footprint is 300 (weight you listed divided by 4 square feet) lbs per square foot. A big difference when designing a slab.
2. Does that 1200 lbs include the water? If not you'll also need to know water capacity and multiply by 8 lbs per gallon.
boiler7904 is offline   Reply With Quote
Old 07-05-2006, 11:05 PM   #3
sayemthree
one, add a 10 GA welded wire mesh for steel reinforcing in the middle of the slab as you pour it. or #3 repars at 12 iches oc.
otherwise 4 inches is fine. since the fountain is 1200 # devided by a 16 square foot footprint your soil pressure is only 75 pounds per square foot - far less than the 1000 normally allowed.
also as siad below, concentrated load of the fountain base can be determined - normal concrete is 1500 psi but you can order 3000 if you need it.
sayemthree is offline   Reply With Quote
Old 07-06-2006, 06:33 AM   #4
bhays
Senior Member
Thanks!. This is the fountain: http://www.krupps.com/Garden-Fountai..._krsam3795_0_0
So, a 4x4 pad 5" deep will take how much concrete (how many bags of sakrete)?
Old 07-06-2006, 06:57 AM   #5
PAToyota
Senior Member
PAToyota's Avatar
Send a message via AIM to PAToyota
Online calculator for doing just that: http://www.quikrete.com/calculator/calculator.html
Of course, they only have for 4" and 6" slabs (standards). So plug your numbers in to each and then split the difference for 5".
PAToyota is offline   Reply With Quote
Old 07-06-2006, 04:01 PM   #6
sayemthree
you will have to read the manufactuerers specs on that.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
