Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 11-29-2009, 01:59 PM   #21
mrb
Senior Member
mrb's Avatar
Default Re: Best, toughtest, most durable spray paint?
have you tried the seymour paint? Their MRO line has a high solids content and is pretty good. Do you buy from IMS? They stock it.
mrb is offline   Reply With Quote
Old 11-29-2009, 02:55 PM   #22
dankeenan
Senior Member
I use SEM paints. They have some pretty tough paint, I use chip guard for bumpers and such stays on really good, but has a textured finish. They also have a really good self etching primer.
dankeenan is offline   Reply With Quote
Old 06-30-2012, 05:58 AM   #23
darkk
Senior Member
If you're looking for silver, then Stainless Steel Hi-Temp Coating from Eastwood is the baddest shit on the planet. Comes in spray cans and in regular cans. I've used it from the can with a spray gun for Cast Iron manifolds and it doesn't even turn colors. If you want colors, then most enamel sprays are about the same.
__________________
My garage build: http://www.garagejournal.com/forum/s...ad.php?t=39357
darkk is offline   Reply With Quote
Old 06-30-2012, 06:58 AM   #24
5lima30
Senior Member
5lima30's Avatar
Valspar tractor/implement paint is the best rattlecan paint I have ever used. YMMV.
__________________
Retired Police Lieutenant, Retired USAF Res, Glock Armorer
"I can do all things through Christ who strengthens me" Phil 4-13.
5lima30 is offline   Reply With Quote
Old 06-11-2014, 06:35 AM   #25
A**holes Garage
Senior Member
VHT and Rustoleum heat resistant paints outlasts their standard paints. Limited colors.
A**holes Garage is offline   Reply With Quote
Old 06-11-2014, 08:47 AM   #26
Voi
Senior Member
Quote:
Originally Posted by Vinko View Post
What in your experience is the most durable and toughest spray enamel you've ever used on sheet metal?
[EDIT] Just replied to a four year old+ post.
I've never used it but there is a 2K post-catalyzed rattle can spray paint that has been discussed on this forum before. I can't imagine there would be anything tougher. I do not know how user friendly or expensive it is.
If somebody doesn't chime in with the brand I'll look it up and post back later.
Voi is offline   Reply With Quote
Old 01-29-2015, 06:50 AM   #27
Wisable1951
Junior Member
Fuji 2903-T70 Mini-Mite 3-T70 HLVP Spray System is the best paint sprayer brand known to me so far.. It is portable and easy to transport. I have just buy my mini-mite 3 few months back and refinished an antique bed. Turned out great. Easy to use, adjust and clean. Be sure to properly thin your material and do test sprays. Seems to be a solid unit at this point and will update after more projects.
Wisable1951 is offline   Reply With Quote
Old 01-29-2015, 07:10 AM   #28
Ainsley
Senior Member
[QUOTE=Wisable1951;4593159]Fuji 2903-T70 Mini-Mite 3-T70 HLVP Spray System is the best paint sprayer brand known to me so far[QUOTE]
I have the Fuji semi-pro unit and it has been great for spraying larger stuff like doors for my house. I still have rattle cans on hand as cleaning the gun isn't always worth the time and mess for smaller parts.
Ainsley is offline   Reply With Quote
Old 01-29-2015, 09:34 AM   #29
rburke65
Senior Member
rburke65's Avatar
The OP was talking paint and not sprayers......No?
rburke65 is offline   Reply With Quote
Old 01-29-2015, 06:11 PM   #30
Hammer1963
Senior Member
Hammer1963's Avatar
I have had good look with Seymour and SEM for auto restoration on small parts. I also highly recommend Wurth.
Hammer1963 is offline   Reply With Quote
Old 01-29-2015, 07:51 PM   #31
dougf
For maximum hardness they sell 2K in a can now. Snap the bottom to activate the hardener, can is good for about 48 hours. Otherwise, Rustoleum Professional has held up really well for me. I usually clean all the rust off with a wire wheel, convert with Loctite Rust Converter, prime with Rustoleum Professional Primer, then topcoat with Rustoleum Professional. Works great.
dougf is offline   Reply With Quote
Old 10-21-2015, 09:09 PM   #32
birmingham
Junior Member
Rustoleum Professional, Painted the hood on my van with it, its white so its a match scraped the entire thing, sanded primed and painted, 9 very light coats looks factory and has for 2 years, and 40000 miles. lot better then the factory paint did.
birmingham is offline   Reply With Quote
Old 10-22-2015, 09:07 AM   #33
ishiboo
Senior Member
Rustoleum works great but it's always much softer than if you did a 2-part finish with an enamel hardener.
dougf - what brand do you recommend? I found 2-part at Eastwood but it doesn't get very good reviews.
I'd like to HVLP stuff but every time I have to clean the gun I realize it's a lot of work. The best option may be to simply buy the HF guns and throw them away when you're done, if your project is any bigger than 3-4 rattle cans worth it probably breaks even for a better finish?
__________________
2017 Denali 3500HD Duramax
2006 Pontiac GTO 6-speed
ishiboo is offline   Reply With Quote
Old 10-22-2015, 09:16 AM   #34
Squankum
Senior Member
Squankum's Avatar
I'll also chime in and say that Wurth has impressed me.
I put an aluminum pedal cover on my car's gas pedal about 20 years ago -- not for ricey purposes, done for actual heel & toe purposes -- and I spray painted it flat black with a Wurth spray can. (Not just to eliminate riciness, but also, I was in Stock class at the time, and...)
It took a long danged time, and about 180K miles, for that paint to wear off significantly. And I didn't even know about primer at that age.
I just resprayed it again with the last remnants of that same Wurth can a few months ago, and it's still looking great. I will admit that gas pedals don't get hard usage, but it sure is constant, and there's some dirt involved. I am impressed.
Except the price is stupid. Germany. You know.
__________________
"I don't vouch for this, but merely repeat what the Libyans say." - Herodotus
Underground Lair of the Squankum
http://www.garagejournal.com/forum/s....php?p=1796399
Squankum is offline   Reply With Quote
Old 10-22-2015, 09:39 AM   #35
creativecars
Senior Member
creativecars's Avatar
Many of us have been successful with using Rustoleum and adding a catalyst. I am a year and a half in on a trailer and hitch. It still looks good and is out in the elements. Dried hard and faster with the catalyst.
__________________
The dumb questions are much easier to handle than the dumb mistakes.
I DO IT DADDY!!
creativecars is offline   Reply With Quote
Old 10-22-2015, 10:45 AM   #36
ishiboo
Senior Member
Quote:
Of course, that's what I said. The question though is if it's doable and financially makes sense to do with spray bombs. The difference in the cost of the catalyst paint ($25 a can from Eastwood) to the regular stuff ($5 a can) is enough to pay for a quart of Rustoleum pro enamel and a HF spray gun. Add another ~$10 for the hardener.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
