Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#181 | |
Senior Member
Quote:
Thanks for the info, much appreciated. We'll probably try one of these mounts from Mcmaster, cheap enough to try, and they should offer a bit more isolation than the pucks. We're going to have over a hundred pieces of NHL memorabilia in the upstairs garage lounge, so it should take care of the hockey content lol (car stuff will be kept to the other major garage areas, in the showroom/shop, along with all the model displays/etc). Car stuff might get priority though, hockey stuff might make the move into the basement. But with 12ft high ceiling in the 2nd floor lounge, we might have enough space for it all. Last edited by enginerd; 11-04-2007 at 05:59 PM. |
#182 |
My new to me compressor, still have to rewire a new 220 outlet for it and do up some copper now that prices are dropping. 80 gallons of nice 18.4 cfm @ 90 psi. Forgive the mess the garage got invaded for a bit so stuff had to be piled up.
#183 |
Junior Member
#184 |
Senior Member
Holy Crap this is a long thread...
I just read the WHOLE thing!!! Thanks guys... I learned a lot from this. I especially liked the pics of the hard piping and the ideas for getting rid of water in the lines. I just have a 175 Craftsman right now... maybe I'll get something cool enough to post pics of one day... lol
__________________
www.WolverineCoatings.com Our products are proudly offered exclusively through Fred with AlphaGarage for your DIY application. Please contact Fred@AlphaGarage.com for your DIY project. |
#185 | |
Senior Member
Quote:
#186 |
Junior Member
I recently traded a 30 Gal oil lubed compressor for a unit that was in a friend's 3 bay gas Staion. :
![]() ![]() ![]() ![]() ![]() My shop is on inside wall of attached storage area. I need info on the unloader setup. I don't think it's working. The continuous duty "3 HP" motor needed an engine cherry picker to pick up - not quite like the sewing machine size "5 HP" motor on the little one I traded... Powerband l |
#187 |
Senior Member
Nice find Powerband. Ya, you got a real motor now .. 16 amp on 220v is a great 3 hp! I know what you mean ... I have a similar one and they are heavy ... especially to lift that high. Both my motor and pump have eye bolts which makes it real easy to lift from.
#188 |
Senior Member
Here is my 3 phase Champion compressor that my uncle left me when I bought the garage off him. More then I will ever need. It used to run the whole place when it was a machine shop.
#189 |
Junior Member
A really long thread. I read all of the "Bunker" thread yesterday so I skipped to the end of this one.
I piped lines from my compressor in the basement when I built the house 10 years ago. It is in a room for the compressor and the electrical subpanel. It is enclosed and insulated so little noise escapes, out of my way, and stays warm. Piped in PVC so I can easily tap for more drops. Compressor is oil-free which I wouldn't recommend because of it's noise. |
#190 |
Junior Member
Newbie to this forum but here is my setup with an Air Dryer and Silencer
U5 - 1 (1 being the inlet side) http://www.nciweb.net/universalsilencers/u5.htm Paid about $135.00 for the silencer at Ingersol Rand Dealer. My be cheaper from this site. Should be able to get one that will fit any compressor. 90% of the noise of a comprssor is on the inlet. Makes it quite. I will move the whole unit outside eventually but will leave the silencer on it to be nice to the neighbors . The hard lines and IR filters are great also.
#191 |
Senior Member
Here's my IR.
#192 |
Senior Member
oops- wrong picture. Here's my IR.
#193 |
Senior Member
You might have to pop the hood to show us the compressor on that one
__________________
www.V10Killer.com My Toybox Build "Up until the 20th century, advancement of civilization was defined by the strongest among us. Now, it appears its going to be defined by the weakest among us." |
#194 |
Senior Member
Here's the other air compressor
#195 |
Junior Member
The attic installation is a great use of garage space.
#196 |
indeed it is.
__________________
www.hacksawsgarage.com |
#197 |
Junior Member
#198 |
Senior Member
I’m almost in the market for a new compressor and was wondering about the merits of single versus dual stage compressors.
I had a quick look at a dual stage compressor and from memory it achieved higher out PSI than the singles. Also the dual stage had a better quality air filter and seems to run slower (bigger pump pulley) than the single stages, would this asst with inlet noise reduction. My logic is if the pump is turning slower and the relative pressures on the reed valve exposed to the atmosphere is lower then the noise may be lower?
#199 |
Junior Member
Haven't seen anybody with anything like mine - so here's my contribution.
The compressor is a Hydrovane 10 PUTS. It's a rotary vane compressor - should last about 100,000 hours before failure. I spent a month or two searching for one of these - almost bought a new one but delivery was too far out. Hydrovanes come from the factory with a 10 year, 48,000 hour warranty, that should give some idea of the quality involved. ![]() When I looked for a compressor, I needed three things - it had to last forever, it had to be QUIET, and it had to put out enough air to run my milling machine (100 psi 7 CFM). This one runs at 65 db - about as noisy as a dishwasher. $1100 used - not cheap, but I expect I will be dead before it will. I put it on a cart I got from Lowes for $70 - I can haul it anywhere I want. It doesn't have an air tank because rotary vane compressors run continuously at 100 percent of capacity. Last edited by kochevnik; 12-26-2007 at 02:42 PM. |
#200 | |
Senior Member
Quote:
To walk out to the shop and fire up the compressor and let it run the whole time you are in the shop, just in case you need air, must be real expensive electricity wise. Charles |
| Thread Tools | |
| Display Modes | |
