Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 06-18-2011, 05:42 AM   #1001
Mr9two9
Default Re: Compression - Show Off Your Compressor
I just picked up this, and an oxy actelene setup from a guy on cl. I had to separate the pump from the tank to fit it in the minivan to get it home. It will go under my porch, on hockey pucks /threaded stock drilled into concrete. Also got a funky splitter/ dryer setup. Gonna need you guys help for the wiring, as my box is about full. I thing its setup for 220. Guy had a shop in his garage from previous owner.
Mr9two9 is offline   Reply With Quote
Old 06-18-2011, 05:57 AM   #1002
Mr9two9
splitter/ dryer
Old 06-18-2011, 06:19 AM   #1003
70Camaro
70Camaro's Avatar
Here is my Quincy 310. 60 gal. 1964(date on tank) Bought it from an old gas station. Took it apart and cleaned and painted it. Replaced all the bolts, tubing and wiring. Every where there is metal to metal contact, I have put rubber pads or sheet between. From empty to 140psi takes 12 min. Just wired in the breaker and recp. this past Tues. 06-14-11 . Have yet to run the piping.
Hockey Pucks
Runs so quiet. Sounds like the African Queen.
__________________
"If I had known how much work this was, I never would have started!" LOL
Jane's Build
70Camaro is offline   Reply With Quote
Old 06-22-2011, 01:15 PM   #1004
PDACPA
PDACPA's Avatar
No compressor to show off, but wanted some opinions. I was in Harbor Freight today and they have these two models:
http://www.harborfreight.com/2-hp-29...sor-68127.html
http://www.harborfreight.com/25-hp-2...sor-67847.html
I do not have 220 in my garage so that sort of limits me at this point and not in the near future upgrade list.
My needs are to run my impact wrench for the car, truck, trailer wheels, some small tools , etc. Would these suffice for my needs? Anyone own one and how do you feel the quality is for longer term. I know some of the HF stuff can be junk, but then there are the tool boxes that are pretty decent for the money.
Thanks.
__________________
1989 911 Carrera Coupe 3.2
2003.5 BMW M3 Dinan
2003 Four Winns 180 Freedom
"It is not how much power you have, it is how much you have left to spare!"
Photo Gallery
PDACPA is offline   Reply With Quote
Old 06-22-2011, 04:39 PM   #1005
Bob Heine
Senior Member
Bob Heine's Avatar
Thanks.
I would spend the extra $150 for the 68127. There is a huge difference in these two machines.
The cheaper one (67847) is a direct drive single piston pump so it runs at motor speed. In this case that's 3,400 rpm and 3,400 compression strokes per minute. I expect it's going to sound like a 50cc dirt bike at cruising speed.
The more expensive one is a belt drive two-piston pump that appears to run at about 1/4 motor speed. For the same motor, that's 850 rpm -- but because it's two cylinders, it's still giving you 1,700 compression strokes per minute. It probably gets its higher CFM output from a longer stroke. Expect it to sound more like a lawn mower at idle.
__________________
Hire the handicapped - we're fun to watch!
Bob Heine is offline   Reply With Quote
Old 06-22-2011, 04:51 PM   #1006
PDACPA
PDACPA's Avatar
Thanks Bob. I was leaning to the more expensive one. I just put the two up (I skipped the "oil less" ones as everyone has said steer clear of them) to see what everyone thought. They also have the bigger ones that require 220.
No issue doing what I need though? My little nail gun compressor cannot even tighten a lug nut.
__________________
2003.5 BMW M3 Dinan
Photo Gallery
Old 06-22-2011, 05:18 PM   #1007
Bob Heine
Senior Member
Bob Heine's Avatar
The tools you want to use need PSI rather than CFM. Once your tank is at 150 psi, your impact wrench should work just fine. You will be waiting for the compressor to catch up if you are breaking free all 20 lug nuts in a row.
You will have the same problem as the rest of us. The compressor is handy, the air tools are cheap and you'll find more things that need the compressor. Don't go overboard on this one because you'll want a really nice one when you do upgrade and have the 220 outlet installed (probably the same time you decide to get a welder).
__________________
Old 06-22-2011, 06:34 PM   #1008
Antique Engine
Champion- Not real cheap but 100 percent made in the USA.
Antique Engine is offline   Reply With Quote
Old 06-22-2011, 07:41 PM   #1009
A_Pmech
A_Pmech's Avatar
Quote:
Don't snap your tailgate links.
__________________
Your Finest Hammer
Building The Paulding Racer - My Blog
My Garage Machine Shop
Quote:
Originally Posted by Sir Stanley Hooker
One stroke to produce power and three strokes to wear it out.
A_Pmech is online now   Reply With Quote
Old 06-22-2011, 07:52 PM   #1010
brianpgriset
Senior Member
brianpgriset's Avatar
My new Quincy 7.5hp. It makes some serious air!
brianpgriset is offline   Reply With Quote
Old 06-22-2011, 08:25 PM   #1011
rotty
Senior Member
My home made compressor made out of a mid eighties Chrysler rv2 ac compressor.
rotty is offline   Reply With Quote
Old 06-23-2011, 01:43 PM   #1012
Lhorn
Senior Member
Nice Quincy and Champion.
Lhorn is offline   Reply With Quote
Old 06-23-2011, 03:38 PM   #1013
89GLH
Senior Member
Neither did I, $80 for cable, $5 for a breaker, $8 for a box and an outlet and a few minutes on here doing some research and I was ready to go. Cost me less than $100 to run the cable and add the new breaker. NBD.
89GLH is offline   Reply With Quote
Old 06-24-2011, 08:40 AM   #1014
PDACPA
PDACPA's Avatar
89GLH - you are way braver than me! I will install lights and swap out switches and plugs, but I am a bit out of my league when it comes to the BREAKER BOX! Though seeing how cheap the parts are, I do have a buddy who is a GC so maybe a 6 pack and everything all mounted, he can dig around in my box and make the connection!
__________________
2003.5 BMW M3 Dinan
Photo Gallery
Old 07-11-2011, 11:07 PM   #1015
keen
Brought this guy home saturday - 1996 SpeedAire 5v401b - it's a 10hp 40cfm 4 cyl 2 stage pump. It was a real too good to be true deal, but I took a risk on it and brought it home.
Alas, pulled it apart and found that someone ran it for a loooong time either full of water or without oil. Spun rod bearings on all 4 rods.
Only put $100 bucks in it, should be able to recoup my loss selling the tank and motor (3 phase, so unless I want use it as the generator in a rotary phase converter, it doesnt do me much good at home...)
Got a good set of heads and lines for the 5v405 pump, if anyone needs them, too.
keen is offline   Reply With Quote
Old 07-11-2011, 11:24 PM   #1016
blue dog
1971 Hill bros. compressor.
blue dog is offline   Reply With Quote
Old 07-11-2011, 11:39 PM   #1017
bobadame
Senior Member
Here's my old compressor. Still need to plumb air lines through out the shop.
bobadame is offline   Reply With Quote
Old 07-12-2011, 08:28 AM   #1018
PsRumors
Senior Member
Here is mine. It came out of the Coke restoration shop in Atlanta. Haven't been able to find anything about the company so I assume it is either a rebadged pump or chinese knock-off. Either way it does pretty good providing 15.5 CFM at 165 PSI (per my calculations).
And for $500 who can complain.
PsRumors is offline   Reply With Quote
Old 07-12-2011, 08:38 AM   #1019
FlameOut
Senior Member
Quote:
Nice! I wish I had gone with that one. I bought the Quincy model right below that one
FlameOut is offline   Reply With Quote
Old 07-12-2011, 11:11 AM   #1020
kartracer55
Senior Member
kartracer55's Avatar
If the tank, motor, pressure switch, etc are still good, why not spend a couple hundred on a new pump?
__________________
Add yourself to the official Garage Junkies map!
http://www.frappr.com/garagejunkies
kartracer55 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
