Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 09-12-2007, 06:41 PM   #161
Sanctifier
Junior Member
Sanctifier's Avatar
Default Re: Compression - Show Off Your Compressor
Quote:
Originally Posted by Roospike View Post
Thanks ,
The drill press is a JET JDP-17MF / 354169 Drill Press , great unit and works very well with steel. I normally drill 1/4" - 1 1/8" thick steel wih it and works great.
http://www.amazon.com/JET-JDP-17MF-3.../dp/B00004T9L0
Really nice. No way I could afford a new Jet on my Workshop upgrade buget.
Just too much equipment and tools to buy... So many tools... So few $$$!
A new 20" VS drill-press costs $2,000-4,500 US... x 6.35 for $TT.
e.g. over here, a JET 20" VS drill-press = $42,000 TT with VAT (tax.)
Even a used Clausing on eBay is $1950.00 US. Still too "rich" for my blood.
Bought a "demo" Turn Pro 20" variable speed... the one ENCO sells for $2000.
Couldn't resist... Paid... [drum-roll]... $500.00 US
BRAND SPANKIN' NEW!... Yup, miracles still happen.
__________________
Walk softly... and carry a BIG stick!
Sanctifier is offline   Reply With Quote
Old 09-12-2007, 10:42 PM   #162
HacksawsGarage
HacksawsGarage's Avatar
Quote:
Originally Posted by Junkman View Post
They ran me off TBN when I teamed up with Doc to start www.forumsforums.com . They said that if you wanted to say anything that was political to go somewere else, so we started our own site. They didn't like the fact that a lot of TBN people joined our fun place and were sharing there time between sites. I stayed away for a while and did ask to come back, but they never responded. If they don't want me, I can live with that. It is there loss, not mine. There are a lot of good websites out there, and this is one of them. Come on over and visit at our www.forumsforums.com and see if it is for you. We allow politics and a whole lot of other subjects, and we don't have any of the politically correct moderator mentality to harass you. We welcome all types of people with lots of different opinions. If you join, just put Junkman in the referral slot. I am the Senior Moderator, so you know what that means..... Nothing but good fun.
well, i can understand the feeling. i have been banned from jockey journal, why, i dont know. the administrator, ryan?, never told me why and to this day refuses to answer any inquirey on the subject. its really fustrating despite my efforts to convince myself i dont care.
__________________
www.hacksawsgarage.com
HacksawsGarage is offline   Reply With Quote
Old 09-25-2007, 11:13 PM   #163
bmwpower
bmwpower's Avatar
Send a message via AIM to bmwpower Send a message via Yahoo to bmwpower
Finally got a new compressor (new to me). It's a mix of manufacturers, but seems to work well. I've yet to get any tools on it since I don't have a regulator or filter, but I finally completed the installation and pressurized it up. Supply line from the head to the tank is temporary. Waiting for some bigger tubing...(thanks Herb)...and a better way to bend it...
Anyway, specs are as follows:
Quincy QR-25 pressure lubricated pump, model 216, single stage (10.7CFM)
80 gallon IR tank (again, thanks Herb)
3 HP, 240v TEFC motor
Quincy belt guard
IR auto drain (once I hook it up)
Pump is older than me (1965), but was rebuilt 8 years ago...should be good for another 20 or so years.
__________________
bmwcca 147895 | 99 m3 | 90 535i | 89 325is | 04 sienna le awd | 88 f250 4x4
my garage build | my wanted list
bmwpower is offline   Reply With Quote
Old 09-26-2007, 12:12 AM   #164
Steve in Mi
Senior Member
Steve in Mi's Avatar
Quote:
Great and probably better than most offerings available today. I used an old 1947 DeVilbiss 3 HP 2 stage for years and my neighbor continues to use it today. I think maybe a new 220V drop in conduit from the ceiling might be in order, unless you can navigate in one of the walls.
Interesting detail in your cement floor around the overhead door track - I'd like to see more.
__________________
Work safe, have fun, enjoy the sport.
Remember that a guy never has to come down out of the clouds if he keeps filling the valleys with peaks. Steve
Steve in Mi is offline   Reply With Quote
Old 09-26-2007, 12:31 AM   #165
bmwpower
bmwpower's Avatar
Thanks. Yea, I'm going to probably run conduit down the ledge coming from the left (the panel is ~25 feet to the left. I figure I'll come out from under the panel and run it down to the compressor. I want to run bigger wire (#8 or bigger) in case I upgrade the compressor someday. Running the wire through the wall, although my first choice, I'm not sure I feel like taking on such a project right now - too much work. The compressor "area" was to be between the doors, but I opted to stick this one over in the corner to see how I liked it (out of the way). I think it will stay here.
The floor near the doors drops down about 3/4" to an apron. This keeps the water out of the garage. Nothing fancy really. Somewhat common around here.
__________________
Old 09-26-2007, 02:17 AM   #166
Steve in Mi
Senior Member
If you build a trench for water inside the door then the water will come in that far, right? I have a ~3/4" drop in elevation and then a taper downward skirt but the drop is at the outside edge of the door bottom not behind (inside) it. I would guess that you experience some freezing of your door seal to the floor unless you don't get freezing temperatures. I used a piece of 1-1/2" pipe across the door opening to maintain a straight line and make the transition in elevation. Any future builds will have a better thermobreak directly below the door sill.
__________________
Old 09-26-2007, 09:34 AM   #167
chad pickens
Senior Member
chad pickens's Avatar
I wanted to show off my new toy. I got the compressor of my dreams. I watched ebay for about 3 months. Then found this c/h extreme series 10hp 4 cylinder 2 stage 120 gallon tank compressor, luckily it has the cast iron made in USA pump. The good part is the guy who bought this didnt know it was 3 so he paid an electrician to put a brand new baldor 10 hp 1 motor on it. The compressor has very little time on it. I got it with the contactor and all for 787.77 it pumps up very fast , kicks on at 140 and shuts off at 175that takes about 90 seconds. It shure is alot quieter than that old craftsman I had.That is not my garage in the pic Im not quite done with that yet.
chad pickens is offline   Reply With Quote
Old 10-17-2007, 11:08 PM   #168
Nightshift
Senior Member
Nightshift's Avatar
Default Compression - Show Off Your Compressor
Just adding mine to the collection here boys. A 2-stage industrial unit. Surprisingly quiet running for unit this large. Sits on hockey pucks, but not bolted thru to the floor (never moves). Auto-drain on the tank. I lowered the pressure from 175, so now it kicks in @ 125 and out @ 150.
Output goes first thru a short hydraulic flex hose, then into 1" iron pipe ... first vertical for 10', then sloped downhill for another 30', then into 1/2" iron pipe for another 30'. Hose reel and outlets at the filter/reg/oiler are overhead and about 60' from the compressor. I've never seen any water there at all ... or in the drain downleg at the farthest end for that matter.
Nightshift is offline   Reply With Quote
Old 10-17-2007, 11:23 PM   #169
bmwpower
bmwpower's Avatar
Cool. You may want to put a drain leg before or after that flex hose or change it's orientation. Water will collect at the bend of the hose.
__________________
Old 10-17-2007, 11:30 PM   #170
Nightshift
Senior Member
Nightshift's Avatar
Thanks for the suggestion. When I installed the 1" pipe, I forgot to have that 10' vertical piece shortened by a couple feet so it's inlet was higher than the outlet on the tank. One of these days, I'm going to take it off and shorten it to eliminate that "trap" the flex hose creates.
Old 10-18-2007, 02:19 PM   #171
Nightshift
Senior Member
Nightshift's Avatar
Well, thanks to bmwpower's prompting ... I finally got off my ass today and decided to fix the "water trap" in my flex hose. I cut 24" off the 1" vertical pipe, rethreaded the end and reconnected the flex hose. I'm annoyed at myself for not doing this when I first installed it ... took all of 30 minutes!
Thanks again bmwpower for the push ...
Old 10-18-2007, 02:54 PM   #172
bmwpower
bmwpower's Avatar
No problem. That's what we're here for!
Now if I just off my ass and actually started to pipe my system...
__________________
Old 10-19-2007, 03:18 PM   #173
russlaferrera
Senior Member
This is my little 2hp, Quincy 310, with a 60 gal tank. I have it since the mid 70s. It still runs strong.
russlaferrera is offline   Reply With Quote
Old 10-20-2007, 09:13 AM   #174
winks2
winks2's Avatar
Send a message via AIM to winks2
Here's the compressor I decided on... I love it! I don't have a filter yet, however I don't have any other air tools yet either, besides a tire chuck and a blow gun.
winks2 is offline   Reply With Quote
Old 10-21-2007, 09:23 AM   #175
dragginbalz
Senior Member
dragginbalz's Avatar
I guess I will finally post mine (even though it is dusty as heck)
Eaton 220V single stage 80gal
I love it. I was spraying some primer with a Sata KLC HVLP primer gun and the compressor not only kept up when I was spraying it also continues to build pressure and actually shut off a few times. (while constantly spraying) I was impressed!
dragginbalz is offline   Reply With Quote
Old 10-21-2007, 09:25 AM   #176
dragginbalz
Senior Member
Old 11-03-2007, 10:07 PM   #177
Itzkwik
Senior Member
Itzkwik's Avatar
IR 5hp/80gal. Still need to run the air lines and wire it to the disconnect.
Itzkwik is offline   Reply With Quote
Old 11-04-2007, 12:13 PM   #178
enginerd
Senior Member
What have others been doing for the compressor feet mounts for something like the IR- SS5L5?
The hockey puck thing is interesting, although they will be prone to crack over time i'd think. That rubber vulcanizes and becomes brittle.
Mcmaster sells these, and it lists air compressors as an application. PN: 6423K611
$25/ea, 1/2-13 thread, it'll take 600lbs (so total of 2400max with 4), and it has a good temperature working range (-20 to 225F).
And if you want overkill, they also have these isolators available, over twice the load capability, and twice the price. Same neoprene bonded between steel plates.
enginerd is offline   Reply With Quote
Old 11-04-2007, 04:49 PM   #179
Nightshift
Senior Member
Nightshift's Avatar
Well enginerd ... I've been using hockey pucks under my compressor for about 35 years. I think during that time, I did put fresh ones under it one time about 20 years ago when I moved and in the process, the short lag bolts holding them on got pulled off.
I can assure everyone they are very effective, cost nothing (if you don't have some, check with any neighbourhood kid who plays hockey and they'll have a bag full), and in spite of what you might think, they last probably longer than you want them to!
Old 11-04-2007, 05:32 PM   #180
RWD
Here's my Speedaire 30 gal compressor I picked up a few weeks ago. It's kinda old but is in good condition. I haven't run it in 2 weeks and it still has 135 lbs in it. It is fairly quiet which is the main reason I bought it instead of a new, oil-less compressor. I HATE noise, lol.
Bob
RWD is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
