Go Back   The Garage Journal Board > The Garage > Flooring
Reply
Thread Tools Display Modes
Old 12-04-2009, 04:48 PM   #1
Garyl53
Default How to drain off winter snow melt?
Well I have been thinking about finishing my garage floor this spring with VCT but I am wondering how to handle the water from the snow melt off the cars in the winter. Yesterday morning there was a bit of snow on the cars and as expected it melted off into puddles on the concrete floor. The floor is pitched toward the garage door as most are however the garage door is acting as a damn so the water collects in a large puddle. When opening the door it is quite a mess dripping off of the door onto the cars. What have people done to control this a bit with or without finished garage floors? There are no floor drains in the garage and it looks like it would be difficult to add them after the fact. Is it possible to create drain holes under the garage door without letting in too much cold air? any suggestions appreciated.
Gary
Garyl53 is offline   Reply With Quote
Old 12-05-2009, 04:51 PM   #2
Garyl53
Default Re: How to drain off winter snow melt?
I thought I would add that I always try to brush off the cars before putting them into the garage to minimize the water. I was thinking that perhaps the best way to handle this would be to cut or modify the seal at the bottom of the garage door to create a small outlet area for the water to flow. I am concerned about the VCT standing up to water sitting on it over night though since many times I wouldn't be able to sweep the water out until the next morning. Will the VCT withstand some water sittting on it without damage? Any opinions from those with VCT would be appreciated.
Thanks
Old 12-05-2009, 05:58 PM   #3
Mark-in-NH
Senior Member
Location: On a planet with alot of really Stupid people
You could always use something like this mat that you park your car on. There may well be better ones then this, this is just the first one that popped up in a random search.
http://www.elite-xpressions.com/floo..._cleanpark.htm
Mark-in-NH is offline   Reply With Quote
Old 12-05-2009, 07:19 PM   #4
nate379
Cut slots in the slab under the door.
nate379 is offline   Reply With Quote
Old 12-08-2009, 03:43 PM   #5
Fish-man
I bought some BLT mats this fall... it takes forever to dry the water from rain run-off, and I think snow/cold will make it worse. However, I didn't have much of a choice, since my concrete is disintegrating due to road salt... so I'll see what happens when the snow starts to fly.
Fish-man is offline   Reply With Quote
Old 12-08-2009, 05:37 PM   #6
sledmods
Senior Member
My situation is that my garage isn't pitched enough so water just pools and flows everywhere. I'd like to do VCT also but i don't know how it will hold up. Epoxy is probably my only solution right now. I may look into one of those parking mats.
sledmods is offline   Reply With Quote
Old 12-08-2009, 08:20 PM   #7
thelews
Senior Member
thelews's Avatar
Here's what I did. Cut a trench before the door, connected outside to the underground gutter drain system. Works well, but I have to run hot water down the drain when it really gets cold to keep the pipe to the gutter drain open.
thelews is offline   Reply With Quote
Old 12-09-2009, 12:18 AM   #8
Garyl53
Quote:
Does the trench go all the way through the garage concrete floor or is it just a ground out area of concrete? Also was this installed when the garage was built or was it a retrofit? This would work really well for me since the pitch of the floor would drive the water into the drain.
Old 12-09-2009, 08:11 AM   #9
thelews
Senior Member
thelews's Avatar
Quote:
It was a retrofit. We sawed out a channel about a foot wide and 6 or so in. deep and then set a plastic drain channel (most landscapers have them) in fresh concrete with some rebar. The drain exits the front of the garage via buried PVC and connects to the underground gutter drain system right around the corner. I did this before some brick work was done in front of the garage door and before the floor was shot blasted and epoxy slurried. Works well, but I have to keep the PVC drain tube from freezing. It's not buried 4 ft. going out of the garage.
This type of drain http://www.plastictrenchdrain.com/
Old 12-09-2009, 10:19 AM   #10
Bojans
Senior Member
Since I have installed the ceiling fan in my garage the floor has always been dry by morning.
Bojans is offline   Reply With Quote
Old 12-09-2009, 05:24 PM   #11
Garyl53
Quote:
In winter with temps arround 30* to 40*?
Old 12-11-2009, 01:59 AM   #12
MNMuskie
Junior Member
The water in my garage also pools at the threshold. "thelews" drain looks to be the ideal solution.
I'd love some type of drain, but for now I just use the trusted floor squeegee. It's sometimes a pain, but it works great. Like you, I try to kick or brush off as much ice and snow in my driveway. I usually let the cars thaw out for a while and then just crack the door and squeegee out the water. If I do this just before going to bed, it's usually bone dry by morning.
I'm not sure where you are from, but you may be underestimating the amount of snow and slush that comes into the garage in the northern climates. In fact, I'd be willing to bet I had about a gallon of water come from the ice buildup of just one wheel well after our last storm.
MNMuskie is offline   Reply With Quote
Old 12-11-2009, 03:31 AM   #13
35mastr
Senior Member
35mastr's Avatar
This is you best bet. They also sell them in metal that are about 4 to 5 inches deep.
__________________
If I could only remember what I have already forgotton.
Mac tools For Sale Here
George
35mastr is offline   Reply With Quote
Old 12-11-2009, 11:32 AM   #14
Garyl53
I have conlcluded that I need to have some drain mechanism before I do anything to the floor. I just don't see me taking the time to squeegee the floor every time. I like what"thelews" did although the way the floor is sloped I may only need a single drain (round) toward the door area near each car. Thanks for all the input.
Old 12-12-2009, 05:30 AM   #15
nate379
The easy fix is just to cut some slots under the door.
I'm too lazy to get some pics but I just cut a 1/4" wide, 1" deep "trench" with my angle grinder that runs about 3" before the door to outside. I did it every 4-5 feet I believe.
It's not as effective as an actual drain like the pics on here show, but I wasn't ready to cut up my slab and figure out a way to drain it outside and not have it freeze when it's -20* outside. Not to mention I was worried about hitting the pex lines which I'm not exactly sure how deep they run or where they are.
Old 12-12-2009, 10:37 AM   #16
t. jones
Senior Member
I just drilled a hole in a low spot near the door. It was just temporary 7 years ago, works good.
Thanx Trevor
t. jones is offline   Reply With Quote
Old 12-12-2009, 12:59 PM   #17
Garyl53
Thanks Nate379, I think I will try your recommendation now so I can see how it works out. It will be a lot easier than adding an actual drain and if it works out it would be easy to just cut arround the slots when laying VCT. The slots could actually run under any threshold that is needed to protect the edge of the VCT.
Old 12-12-2009, 05:36 PM   #18
Treeman
Senior Member
Wouldn't the slots freeze and back up during the winter, when you want them the most?
Treeman is offline   Reply With Quote
Old 12-12-2009, 07:18 PM   #19
t. jones
Senior Member
Treeman yes it will especially if the door faces north ( south for our Austrailian friends)
Thanx Trevor
Old 12-14-2009, 08:57 AM   #20
Dodge
Senior Member
I had the same problem with standing water in my garage from melting snow and rain water off vehicles. I had no floor drain. What I did was put in a drain. The low spot in the garage where the water would sit, I cut the concrete with a cement saw. I cut a square 3'X3'. Dug it down about 3'. Filled it with river rock. Bought a 9" catch basin at Menards. Placed it in the opening, before completely filled with rock of course. The one I bought had 2 holes on the side, I put a 90 degree elbow on each one, keeps the rocks out and lets the water flow out. Serves as kind of a sludge catcher. I kept the top of the basin slightly below grade for flow, finished off with sakrete. I still have to squeezee to the drain some. Better than opening the door and pushing the water to the driveway to freeze. Drain works great, have had it about 10 years, well worth it. Good Luck
Dodge is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
