Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 12-11-2009, 08:38 PM   #1
Fhunter1
Fhunter1's Avatar
Default Old Propane tank change to a new type valve?
I've got an old propane tank that seems to have a leak around the valve stem. It is from the mid-50s and in good shape(other than the leaking valve stem) It is also a 100 pounder.
Is it possible to get someone to change out the valve to the new type valve on a tank that old? The second problem is that it is full
Can a reputable place evacute the propane, replace the valve and refill it for a reasonable price? I hate to lose the propane, but I don't dare use it since it leakes.
No leakes when the valve is closed but I need to get this fixed so I can get some heat in my garage.
Thanks for any input
__________________
Frank
1956 Chevy 210 Delray Sedan
1963 VW Type 1 1600 cc lowered
1965 IHC with a SBC and Turbo 350
1981 Case 446 Garden Tractor
lots of other junk in the garage
Fhunter1 is offline   Reply With Quote
Old 12-11-2009, 08:42 PM   #2
Red Green
Senior Member
Red Green's Avatar
Default Re: Old Propane tank change to a new type valve?
I once borrowed a tank that would leak when the valve was open part way. If you opened the valve all the way it would quit leaking.
__________________
"If the women don't find you handsome, they should at least find you handy."
"Unlike love respect can't be bought" H. Simpson
Red Green is offline   Reply With Quote
Old 12-11-2009, 09:29 PM   #3
Fhunter1
Fhunter1's Avatar
Red Green -
I thought of that one already and tried to tighten the "packing". No lUck
__________________
Frank
Old 12-11-2009, 09:35 PM   #4
tonydanzah
Senior Member
tonydanzah's Avatar
when you go to get the tank recertified they pressure test it and change the valve. i just had my 15yr old 100 pounder. pressure test was 20, valve was 24 and the fill brought my total to 125 with tax.
tonydanzah is offline   Reply With Quote
Old 12-11-2009, 09:39 PM   #5
neverenoughtools
Senior Member
neverenoughtools's Avatar
You will lose the propane, the cylinder will be checked for corrosion & it may require a paint job. The next step will be a new valve , pressure testing then restamping the expiry date. This is done on the thickest part of the cylinder , usually at the top where the valve is screwed into.
neverenoughtools is offline   Reply With Quote
Old 12-11-2009, 10:50 PM   #6
tonydanzah
Senior Member
tonydanzah's Avatar
they actually didnt stamp mine, the put on a foil decal and stamped the date into that
Old 12-11-2009, 10:52 PM   #7
GB Hicks
GB Hicks's Avatar
I had a tank that looked like crap, the neighbor gave it too me bacaude it looked real rusty and he thought it leaked. I took it to a convenince store that sold propane in canisters, ou left your old tank as a core instead of refilling. They didn't even look at the old tank, just set it in the trade in cage and gave me a new one. I am sure there is somewhere near you.
GB Hicks is offline   Reply With Quote
Old 12-11-2009, 10:54 PM   #8
tonydanzah
Senior Member
tonydanzah's Avatar
I've never seen a place that swaps 100 pound tanks.
Old 12-11-2009, 11:05 PM   #9
D.J.
Senior Member
Red Green you are correct, that is a common occurance with valves on cylinders. Also guys a part of the recertification is a internal visual inspection. As a rule I believe NFPA phamplet 58 ( lp gas code) also includes a new coat of paint on the 12 recertification process. A reputable LP gas dealer in your area can usually fix you right up! As always "ALL HAIL PROPANE" Just like Hank Hill Says I recomend propane and propane accesories.
________
bald pussy Webcams
D.J. is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
