Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 12-26-2009, 10:42 PM   #1
crashbumper
Senior Member
crashbumper's Avatar
Default Bluepoint AT325C 3/8" impact teardown and rebuild.
Yesterday I got a Bluepoint AT325C 3/8" impact.
There was some deep grooving on one side (looks like from a grinding wheel?) and quite a bit of gunk clogging up the built in filter.
I decided to pull it all apart to clean it up, polish it and make it look all pretty before I use it.
As I've mentioned in other posts, this is something I prefer to do for fun; functionally this gun was ok. I just wanted it to look nice.
On with the photobomb!
Start:
Deep grooving:
Rear housing comes off with four 4mm allen bolts:
Remove the end cap:
Removing the rotor:
Removing the reversing pin:
Reversing pin assembly (along with the screws that hold in the detent):
Hammer & Anvil assembly (where the actual impacting comes from):
Disassembling the hammer assembly:
Removing the air regulator assembly (after driving out the roll pin):
Here's a handy method for polishing up smaller round pieces:
A light touch of scoth brite to remove the surface rust, and some polish:
Cleaning up the grooving with a 3" surface pad:
After some sanding with abrasive sponges and 800 grit:
It's looking pretty good so far. I'm going to go over the housing some more with finer sandpaper to really clean it up before I polish it tomorrow.
Thanks for stopping by!
__________________
I <3 industrial finish tools!
Current WTB: Pink 3/8" Snap-On ratchet (F836?) for daughter.
Money Pits:
1929 Ford Roadster (dry lakes project)
1969 VW Bug (Cal-Look)
1984 Toyota Cressida (4-door Turbo sleeper)
1990 Toyota Cressida (VIP cruiser)
crashbumper is offline   Reply With Quote
Old 12-26-2009, 10:50 PM   #2
Joelfke
Senior Member
Joelfke's Avatar
Send a message via AIM to Joelfke Send a message via Yahoo to Joelfke
Default Re: Bluepoint AT325C 3/8" impact teardown and rebuild.
by polishing the insides does that give it back its power? i "rebuilt" an IM6500 because it had a broken hammer but it seems like it doesn't have nearly as much power as it should.
__________________
"The bolt doesn't really care who made your wrench, its going to be a stubborn prick reguardless"
Quote:
Originally Posted by Merkava_4 View Post
Sears = [fill in the blank] problem. :lol:
Joelfke is offline   Reply With Quote
Old 12-26-2009, 11:01 PM   #3
crashbumper
Senior Member
Quote:
Well, I'm just polishing up things like the air regulator and reversing pin. There is some scoring inside the rotor which you can see in the above pics. I would think that heavy scoring would cause some loss of performance; but "heavy" is open to interpretation.
I don't anticipate any gains in performance, but maybe smoother and quieter.
__________________
Money Pits:
Old 12-26-2009, 11:28 PM   #4
kartracer55
Senior Member
kartracer55's Avatar
I like it! I would say get a brake caliper cylinder hone (Break it in first) and polish up the inside of the rotor, first with the hone then with some fine abrasive. Next, clean up the edges of the vanes,keeping them all equal for balance. Should restore Lost power. Don't forget about seals and gastets. Cool project
__________________
Add yourself to the official Garage Junkies map!
http://www.frappr.com/garagejunkies
kartracer55 is offline   Reply With Quote
Old 12-26-2009, 11:32 PM   #5
crashbumper
Senior Member
Dang, that's a good idea using a brake hone! I may just do that. The vanes do have ridges where they have worn in.
Thanks!
__________________
Money Pits:
Old 12-26-2009, 11:56 PM   #6
Joelfke
Senior Member
Joelfke's Avatar
hmm...i wonder if replacing the vanes on mine would increase power...hmm...nice project nonetheless crashbumper
__________________
Old 12-27-2009, 12:07 AM   #7
kartracer55
Senior Member
Default Re: Bluepoint AT325C 3/8" impact teardown and rebuild.U
If they have ridges then yes it might, bit it would also require that the inside sutface of the motor be smooth As well. The original poster may be better off ordering new ones, As it would be difficult to both keep the edges perfectly flat and square with the ends, but also to maintain balance which could result in vibrAtion. More critical in a sander or grinder, buy still an unwanted side effect of badly out of balanced blades. In this application, it would likely
be masked by
the impacting. Just a thought.
__________________
Old 12-27-2009, 06:54 AM   #8
peter_x
Senior Member
Great to see someone make a DIY for the "rear cap" style of impact guns. I did my IR231-style DIY a few months back. If you try to rebuild those, be careful to put the rotor back in straight!
peter_x is offline   Reply With Quote
Old 12-27-2009, 04:50 PM   #9
crashbumper
Senior Member
Got the housing polished, definitely looks better.
Also, picked up a brake cylinder hone and cleaned up the scoring on the rotor housing.
Cleaned up rotor:
Reversing pin installed (much smoother now):
Good as new!
This one was fun; I hope I score another air tool in need of a rebuild.
__________________
Money Pits:
Old 12-27-2009, 05:04 PM   #10
rsanter
Senior Member
rsanter's Avatar
looks good
I have rebuild many air tools and to me it looks like you have done everything right.
there may be some benifit to new vanes, but most of the time I would reuse the old ones after a little sanding on the sides and contact edge.
be sure to bevel the sides of the contact face a bit or sand them with a little bit of a crown to reduce the surface friction
bob
__________________
my wife says that I have never met a tool I havent liked. people on the other hand......
rsanter is offline   Reply With Quote
Old 09-26-2010, 10:57 AM   #11
lineage404
Junior Member
hey i got a question guys. you know where i could get new parts for mine. the two pins in the hammer i need the most. it runs great but i broke one of the pins on the hammer. and very nice rebuild. looks good! maybe i will do it to
lineage404 is offline   Reply With Quote
Old 09-26-2010, 04:27 PM   #12
BlindViper
Senior Member
If you look at your 3rd picture you can just barely see the marks from a engraver. It had its owners mark adjusted.
Eww old post
BlindViper is offline   Reply With Quote
Old 09-26-2010, 07:12 PM   #13
babzog
Senior Member
babzog's Avatar
You buffed out those gouges with a brillo pad set on high? Wow! Nice job!
__________________
Quote:
Originally Posted by jmh21586 View Post
You'd never call someone to tell them you just had your first cup of coffee for the day. Why would you tell the world on FB???:wtf:
babzog is offline   Reply With Quote
Old 09-26-2010, 08:44 PM   #14
Even 11
Senior Member
Even 11's Avatar
I am looking into doing this with an IR i found in a pawn shop closeout bin for $5. Mine looks to be a lot more heavily used and is damaged at the moment. Thanks for the pics though!
-Dane
Even 11 is offline   Reply With Quote
Old 09-27-2010, 04:06 AM   #15
Monte
Senior Member
Monte's Avatar
nice pics !!
Monte is offline   Reply With Quote
Old 12-27-2010, 10:16 PM   #16
roktoy
Senior Member
Great job on the rebuild. Thanks for posting.
I have one that is running a bit weak, so would like to rebuild it.
I found some parts still available at Snap-On:
http://buy1.snapon.com/catalog/parts...&group_id=5738
Anyone else know where parts might be available?
roktoy is offline   Reply With Quote
Old 12-28-2010, 09:21 AM   #17
fordbroncodave
Senior Member
fordbroncodave's Avatar
i replaced a hammer pin in my im31 impact not long ago. works good. now i will probably pawn it and buy a new ingersoll rand
__________________
with a putt putt here, a putt putt there, hear a putt theres a putt, everywheres a putt putt... a john deere farms this land E I E I OH
my needs list:
http://garagejournal.com/forum/showt...fordbroncodave
fordbroncodave is offline   Reply With Quote
Old 12-28-2010, 10:11 AM   #18
Interex
Senior Member
Interex's Avatar
Great write-up! I've a couple of impact that could use a refresh like this.
Interex is offline   Reply With Quote
Old 01-06-2011, 09:51 PM   #19
roktoy
Senior Member
Well.....the regulator assembly was stuck in mine. I tried to turn it with pliers and it snapped off also found a busted hammer pin inside.
If anyone wants a parts gun cheap, send me a PM.
Old 06-23-2013, 04:44 PM   #20
Rhyno
Senior Member
Location: Salt on the left, Mormons on the right, Yup, "This is the Place!!"
Subscribed....
Rhyno is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
