#1 |
Senior Member
Here are a few before and after pictures of a shop I restored 4 years ago. It was built in the late 1930's and used by a father as a blacksmith/welding shop and later in the 50's one of his sons did automotive repair there until his death in the mid 1970's. The father carried on until his retirement in the 1980's.The shop was then was slowly under used and finally abandoned.
![]() ![]() ![]() ![]() ![]() ![]() As you'll see nothing was ever thrown out is seems. So far I've removed 48 tons of steel scrap that was recycled. ![]() ![]() This was his welding corner. Note the Lincoln arc welder on the right. It's the same welder in the after picture. Same place where it's been for decades and will be cosmetically restored as it works very well as is. ![]() .![]() The project was done mainly with my son and one other friend. Couldn't have done it without their help. Outside took about a year and the inside a second year. I'll post some more pictures if there is any interest. Thomas |
#2 |
Very cool to see that the outside looks just restored, but interior is very clean and neat! Great work!! I'd like to see more pics.
#3 |
Senior Member
Man that is one awesome setup, Those before pictures really make a person sit back and ponder all the stuff that shop has seen in its day. Im sure it would have been financially beneficial to start from scratch but thanks for bringing it back to life. Im sure More pics and some more history would greatly be apreciated.
__________________
Hein-Werner "Born in Waukesha.... Raised all over the World." Made in the USA? Its Wright thing, You Dual 80 boys wouldnt Understand. My Import Jack Repair Tutorial, Enjoy... Your Sticky consolidation cant stop me.. http://garagejournal.com/forum/showthread.php?t=51105 |
#4 |
I am in love with both incarnations of this place.
Post as many pics as you have, and tell the story of how/what you did to the structure and cosmetics of the building. Old barns are an obsession of mine, as are old buildings of any kind, but especially old shops!
__________________
Looking for Cornwell hard blue handled tools Looking for Blackhawk tools and tool boards. #1 Priority at the moment. Looking for old tool boards/displays |
#5 |
Senior Member
nice work...........was the hoist the original one?.........and did you reposition it as it looks like there is more roomin front of it from before..........all in all very impressive............by all means, more pics...........
#6 |
Senior Member
The shop lift had a slow leak.Here is what I had to do to restore the in ground Rotary lift. It had been located outside the original shop for over 30 years. That's why there is clap board siding in the back ground since that was the outside of the original building. The lift was then enclosed in 1962. Three concrete block walls were built around it and it was then " grafted " to the original shop.The family gave me pictures of that enclosure being built by the way.
![]() ![]() ![]() I unbolted the ramps and rolled them out the door on 4" PVC pipe. ![]() ![]() I had to dig down about 9'. Digging was done mostly with a backhoe with very little hand work. Clay subsoil hard as nails. We kept a close eye on it since there was no room to put any bracing. ![]() I found two pin hole leaks in the outer cylinder which were repaired. Then I had 1/4 inch steel, 8' long, rolled to match the outer diameter of the post and this was welded around the post completely surrounding it so if it leaks in the future it will all be contained in new metal. Also put undercoating material on the outside of it to slow rust and reinstalled it. ![]() The sign on the wall was restored from the one outside the original shop. It can be seen if you go back to the first picture of this post showing the front of the shop above the two overhead doors to the left side of the picture showing the front of the shop. ![]() The control cabinet was restored as well. The motor sits above the hydraulic pump which I had rebuilt and everything was rewired. The back half of the cabinet holds a 30 gallon fluid reservoir. The lift is strictly hydraulic, no air. ![]() Rotary lift is still in business and their records show this lift was made before 1935. That's as far back as their records go. I had Rotary install one of their new modern 2 post lifts in my new " barn" I built this fall. They make great equipment! Thomas |
#7 |
Senior Member
WOW! Nice work! Where abouts you located? I see "Near Chamapign, IL". I am actually Near Champaign as well.
#8 |
Senior Member
Here are a few more. I grew up less than a mile from this shop. It was out in the country back then. One of the owners kids was my age and we always hug around together. My first go kart was made here and this is where I learned power mechanics. The family gave me this picture from the late 1960's. The owner was a little organizationally challenged to say the least but he knew where everything was. He raised his family of 6 with the money earned here so I would call that successful. Note the sign over the doors. That's the sign I restored and relocated inside by the lift.
![]() The shop was concrete block on all walls except the front and part of the west side. When the lift area was enclosed that too was done with concrete block. I removed the two walls that were wood frame and replaced them with concrete block so now the whole exterior is block. ![]() Here you can see through the overhead door opening how the roof line of the original shop extends to inside the area where the lift is located. Also can be seen the clapboard siding and window of the original building. ![]() ![]() ![]() ![]() ![]() The shop is located on 5 acres and is heavily wooded. ![]() This might be one of those " where's Waldo?" pictures! The more you look the more you see. There's a go kart on the left with the front wheels pointing up. Just like my first one! I saved the 30 ton floor press seen behind the go kart. In fact I saved an awful lot of material. The roof had holes in it so much was lost due to water damage. There were many NOS auto parts from the 40's, 50's and 60's. A few flat head engines, with parts galore as well as modern engines. Saved them all and slowly evaluating what I need and selling the rest. ![]() This is the same space as the above picture. I made the benches in the shop (3 of them ) using 12 gauge stainless steel 10' long for the tops. I do have more photos and will post them. Thomas |
#9 | |
Senior Member
Quote:
![]() I've done some drag racing at your strip in Charleston. My grandmother went to college at Eastern in 1908-1912. Thomas |
#10 | |
Senior Member
Quote:
Thomas |
#11 |
Senior Member
Nice rebuild !! The before and after pic are great.
#12 |
Absolutely, totally awesome...one of the coolest garages on GJ. Nice job on the restoration!
__________________
1963 Corvette 1968 Firebird 1969 GTO |
#13 |
ummmmmmm what to say
Holy crap. Great work
#14 |
Junior Member
This is the coolest shop on the site. Is the metal lathe in the new shop original to the old shop?
#15 |
Junior Member
Great job! Are those 4x8 sheets of melamine on the wall?
#16 |
Senior Member
nice shop. i enjoyed the before pics since that how the last shop i worked at looked.
__________________
DEGENERATE Main Entry: 1de·gen·er·ate Pronunciation: \di-ˈjen-rət, -ˈje-nə-, dē-\ Date: 15th century 1 a : having declined or become less specialized (as in nature, character, structure, or function) from an ancestral or former state b : having sunk to a condition below that which is normal to a type; especially : having sunk to a lower and usually corrupt and vicious state c : degraded 2 |
#17 |
Senior Member
Amazing. Just looking at the first pic, I would have never imagined being able to restore that.
Makes a lot of other garage restorations look like a joke. |
#18 |
That hole is exactly deep enough to be a grave. Stay out of deep excavations!
#19 |
Senior Member
What a great job! I hope your Town recognizes your efforts in some way.
#20 |
Junior Member
You were busy! It looks great!
| Thread Tools | |
| Display Modes | |
