This is my old Hunter tire and wheel balancer. You can find these for less than $500. There are adapters to fit different sizes and styles of wheels. Nothing does a better job than this style does.
How do you use that?
the wheel gets spun by the motor in the base. the adaper on the wheel has 4 rings that you grab while it's spinning to either add or subtract weight or move the weight clockwise or counter clockwise. you just add or subtract weight and move it untill you find the least vibration.How do you use that?
a bubble balacer is very easy to use but it's static not dynamic. it isn't as accurate.I considered the static/bubble balancer but I'm not sure. I just don't want it to be so frustrating that I don't even want to deal with it and then it'll just take up room in the garage.
..........we only used ours for problem vehicles.........
I've watched many shops balance my tires, have them zero balance it, then have them rotate the wheel 90* on the machine and spin them again...calls for weight 50% of the time.
In fact, the whole reason I got interested in the balancers (again) is because I just got new tires at tirerack.com and got them locally mounted and balanced at the Big'O tires nearby and guess what? yep shimmy above 60mph and it's missing weights on one wheel altogether and weights on the inside of another wheel. The other two have weights on both sides. I paid $90 for this, between 4 cars, travel trailer and a motorcycle I think I spend $200-300 a year on just mounting and balancing tires.
The guy that balanced your tires might have been selling burgers at McDonalds last week. That's why I always do you own tires and balancing. The nice expensive machines are only as good as the guy doing the work. YMMV But if you are having problems, they should balance them again.
Not sure what John Bean is, the more famous ones that I know of are Coats, Hunter and Snap-On. If it looks abused I'd be careful buying anything without checking the parts availability. Some of the "computer balancers" have been around since the 80s...
I did go back and as soon as I got home another weight fell off so I went back the third time. Turned out that lead weights are now banned here and the steel weights are not as malable and hard to keep on. They used the stick on weights but the balance doesn't seem as good now, I have a slight vibration still sigh!
So do you have a bubble balancer too and you get good results with it even with wider wheels (7-8" wide)?
Lead weights are banned now?![]()
Good info Fordcrager. How do you change the tires? do you have a nice tire changing machine or do you do that by hand (spoons) or using the HF tire changer?
I take it you don't have the Coats for sale do you?![]()
That snap-on one above is an absolute turd. We have one at work, and it's awful. It never shows weight at the same spot.
It will tell you to add .5 ounce, you do, then it tells you to put another 1 ounce in the same spot. Do that, then it tells you to add 1.5 ounces 180* out.
I wouldn't worry about a bubble balancer myself. In theory, new balancers will be more accurate. In practice, throw in poor calibration times, and some ******* that doesn't care one way or the other, not so much. (Don't take offense, I was a tire monkey, too. There are a few good ones, but far and wide most aren't.)
Many, many times I've bought a set of new tires with balance, had them shake like a *******, took them home, chucked them on the bubble balancer, and a static balance on one of them came out WAY better than the dynamic balance on the electronic machine. Go figure.
Also, if it's WAY off, the correct fix (IMHO) is to try and spin the tire 180* and see if it gets better. I've gone so far as to spin the wheel, weight the wheel so it spins zero (static), put the tire back on and spin the assembly up, mark where it's calling for weight on the tire, and align that and the wheel weight 180* apart, remove the wheel weight, then balance from there. Aircraft wheels and tires are already marked for this, and for the life of me, I can't figure out why they don't do it with car wheels/tires.
Just my $.02.
I'm really interested in buying one but I can't seem to find one in my price range ($500 max).
What about the bubble balancers if I dare ask?
