Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 01-01-2010, 10:07 PM   #1
jonepark
Junior Member
Default car alternator can be used to generate a 110 v output
Hi,
I was searching for this but I didn't found anything.Does anyone know if a standard car alternator can be used, or modified, to generate a 110 v output? Does the output voltage depend on the rotational speed?Any help is appreciated.
Thanks.
__________________
r4 dsi
jonepark is offline   Reply With Quote
Old 01-01-2010, 10:22 PM   #2
rsanter
Senior Member
rsanter's Avatar
Default Re: car alternator can be used to generate a 110 v output
if memory serves me, an altenator is a constant voltage, variable amperage device.
you can get a small engine (like a briggs) and a couple of batteries and an inverter.
the altenator will keep the batteries charged and the inverter will make your 110v
bob
__________________
my wife says that I have never met a tool I havent liked. people on the other hand......
rsanter is offline   Reply With Quote
Old 01-01-2010, 11:21 PM   #3
HotRodKush
Senior Member
HotRodKush's Avatar
The voltage, at least in part, is regulated by the voltage regulator on the alternator. Even without it though, I don't think it'll put out much more than 14 volts. Like rsanter said, you can get a power inverter that'll convert the 12-13V automotive system to a 110v source.
HotRodKush is offline   Reply With Quote
Old 01-02-2010, 12:47 AM   #4
Torque1st
Senior Member
Torque1st's Avatar
When alternators had external regulators there were kits to make 110VDC from an alternator. 110VDC can be used to run universal motors (the ones with brushes). I have no idea what is available today.
Inverters are the way to go nowadays.
__________________
Faster, Better, Cheaper: Pick Two
The FairTax
Follow the Money. -72chevy
Yes, I am insensitive and yes, not politically correct, and yes, Im sure I offended someone,... -Busted_Knuckles (Me too, plus I am old, tired, and grumpy!)
Read "The Marching Morons" Here
"Works" <> Safe, Good, or Right
"You can't fix stupid." -Ron White
Torque1st is offline   Reply With Quote
Old 01-05-2010, 02:47 PM   #5
CarterKraft
I don't have the particulars but the answer is yes, I think,
A car alternator is putting out AC current, it is rectified to DC by the diode bridge.
As to how to do it, don't know. You could always just buy one ready to go, premierpower is a company that sells them, I think.
CarterKraft is offline   Reply With Quote
Old 01-06-2010, 02:17 PM   #6
dipper
Senior Member
dipper's Avatar
Send a message via AIM to dipper
buy an inverter for the power you need. No reason to re-invent the wheel here.
Ebay is your friend, search 12vdc 110vac inverter
__________________
-Dipper
20x22 Build Pics: http://s630.beta.photobucket.com/use...e/1_Demolition
dipper is offline   Reply With Quote
Old 01-06-2010, 04:05 PM   #7
HOTFR8
HOTFR8's Avatar
Location: Castlemaine, Victoria. The Hot Rod Centre of Australia.
Quote:
Originally Posted by jonepark View Post
Hi,
Thanks.
bob
This is what I would suggest and use the alternator to charge a decent battery then run the inverter from that battery.
__________________
1966 (Aussie) XP Falcon Sedan, 1923 T Roadster, 1948 F4 Truck, Home Built Teardrop Camper, 1969 International 4 X 4 truck (Classic),
84 x 30 Colorbond Shed with Showroom, Workshop, Car storage and Office.
www.streetrod.com.au
The Beast Runs>http://www.garagejournal.com/forum/s...0871&showall=1
Sheddwellers>http://www.garagejournal.com/forum/s...0063&showall=1
The International> http://www.garagejournal.com/forum/showthread.php?t=32307&showall=1
"V8's are Great, But Six inlines Just Fine" - CUMMINS Advertising.
HOTFR8 is offline   Reply With Quote
Old 01-06-2010, 09:15 PM   #8
lawfarm
Senior Member
lawfarm's Avatar
If you pull the voltage regulator (whether internal or external), you will get variable voltage depending on the speed at which you spin the shaft. As noted above, at the right speed, you can generate 110V, but it is DC (as noted above). That does work with some motors, but not with most modern electric motors. Also, anything with variable speed (variable speed trigger or adjustment) will burn out almost instantly.
lawfarm is offline   Reply With Quote
Old 01-07-2010, 12:37 AM   #9
krooser
Senior Member
krooser's Avatar
Alternators produce ALTERNATING CURRENT by design... the rectifiers/diodes convert it to DC. And yes they used to offer 110V AC kits for automotive alternators.
krooser is offline   Reply With Quote
Old 01-07-2010, 09:29 AM   #10
sberry
Senior Member
sberry's Avatar
Yes, they used to make a voltage regulator bypass, make AC power from an alt.
sberry is online now   Reply With Quote
Old 01-07-2010, 11:46 AM   #11
Tom McDermott
The alternator usually produces 3-phase AC power, which is rectified by a 6-diode bridge. The battery filters the resultant ripple (which is quite small [something like 6%] with a 3-phase full-wave rectfier). A couple of problems:
1) The diodes are rated for 12 DC output. If you try to up the DC voltage a lot, they are likely to suffer breakdown. you would need different diodes.
2) If you try to produce AC, it won't be 60 hertz. The frequency will vary with the shaft speed of the alternator, and I think it's up in the few hundred hertz to maybe one thousand hertz range at normal engine speed.
Using an inverter is by far the easiest solution. They are mass produced and thus relatively cheap compared to 30 years ago.
-- Tom
Tom McDermott is offline   Reply With Quote
Old 01-08-2010, 01:47 PM   #12
veno
They make these new fangled tings called house hold generators.. gasoline powered and all.. man are they cool..
add gas start it up.. and the generator makes either 240 volts 60hz single phase or 120 volts 60hz single phase or a combination of both.....
holy smokes.. what a great Ideia.... when the gas engine dies?? the generator is still there.. and you install a new one.. or get on you bicycle and spin the generator to 1600 rpm
veno is offline   Reply With Quote
Old 01-11-2010, 08:41 AM   #13
BackAgain
Power inverter is definately the way to go. I built my own generator with an 8hp engine, a 180 amp 12v truck alternator, and a 3000w inverter. I also have a deep cycle battery so I can use some power when the engine isn't running, and I have electric start with a remote. Best generator ever! It will surge 6,000w for 5 seconds, which is WAY more than a 3kw standard generator can surge. I can also use it to jump start/recharge anything 12v.
I did; however, spend a ton of money to build this thing. I could have bought a generator off the shelf for cheaper...but I like mine better.
BackAgain is offline   Reply With Quote
Old 01-11-2010, 04:09 PM   #14
HOTFR8
HOTFR8's Avatar
The FUN is in the building and the result is when it does what you want it to do
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
