Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 01-02-2010, 12:02 PM   #1
dawg
Senior Member
dawg's Avatar
Default waste oil heater plans
http://www.journeytoforever.org/biof...arth/me11.html
plan on building one soon.
dawg is offline   Reply With Quote
Old 01-02-2010, 06:08 PM   #2
tigmusky
Senior Member
tigmusky's Avatar
Default Re: waste oil heater plans
I've been wanting to make one for a few years now. I need to get on it, got about 100 gals. of oil .
I think the whole key is atomize oil . the dip style work just not as good and clean.
Daye
tigmusky is offline   Reply With Quote
Old 01-02-2010, 06:40 PM   #3
walrus
Senior Member
walrus's Avatar
I burn it in my woodstove, use a suction gun to spray it in there, light it
walrus is offline   Reply With Quote
Old 01-02-2010, 09:08 PM   #4
tigmusky
Senior Member
tigmusky's Avatar
Quote:
Let's see some pix please
Daye
Old 01-03-2010, 07:00 AM   #5
walrus
Senior Member
walrus's Avatar
Quote:
Daye
There no pictures, I build a fire out of wood, open the door spray oil in there. I've been thinking of just drilling a hole in the top of my stove, running a steel tube in, setting up a bucket with a ball valve and just letting it drip in while a fire is going. Not very elegant but will get rid of oil and make heat
Old 01-03-2010, 10:23 AM   #6
shocksystems
Senior Member
shocksystems's Avatar
Send a message via MSN to shocksystems
Quote:
Originally Posted by dawg View Post
Please post pictures when you do. Quite a write-up he did on this design.
Cheers!
Jim
shocksystems is offline   Reply With Quote
Old 01-03-2010, 10:52 AM   #7
bazzateer
Senior Member
bazzateer's Avatar
Excuse my ignorance but does the oil create more heat than you'd get from burning just the wood? If not, what are the benefits apart from disposing of the oil?
__________________
If I told you I was a pathological liar, would you believe me?
My garage story: http://garagejournal.com/forum/showthread.php?t=50588
Quote:
Originally Posted by Abbott View Post
I think the cop made a good decision.
bazzateer is offline   Reply With Quote
Old 01-03-2010, 11:04 AM   #8
brokenknee
Senior Member
brokenknee's Avatar
Quote:
You can usually get used oil for free, wood you have to pay for or have a place to cut it (which is time consuming and labor intensive).
__________________
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 01-03-2010, 11:15 AM   #9
krusty the clown
Senior Member
krusty the clown's Avatar
yes, the oil burns hotter than the wood. i would like a drip system on my stove. it beats using a coffee can and throwing a pint of waste oil in every once in a while
__________________
DEGENERATE Main Entry: 1de·gen·er·ate
Pronunciation: \di-ˈjen-rət, -ˈje-nə-, dē-\
Date: 15th century
1 a : having declined or become less specialized (as in nature, character, structure, or function) from an ancestral or former state b : having sunk to a condition below that which is normal to a type; especially : having sunk to a lower and usually corrupt and vicious state c : degraded 2
krusty the clown is offline   Reply With Quote
Old 01-03-2010, 11:22 AM   #10
walrus
Senior Member
walrus's Avatar
Quote:
I use it to get a fire going also.
I was in a commercial shop the other day where they a drip system going. Couldn't believe it, working on cars with this homemade wood stove sitting on the floor. A windshield wash jug bungeed to a post, half full of oil and a brake line out of the jug into the stove. TF
Old 01-06-2010, 08:42 PM   #11
s_ontario
Senior Member
s_ontario's Avatar
Best one i have seen used a truck brake drum with the center hole sealed of course with second drum with center removed ontop of that for the burning pot oil tank was under air pressure and they had air piped from a small fan directed at the burning pot looked like 1.5 inch exhaust pipe curved to make flame swirl
this was inside of home made wood stove that was then cover in tin making it look like regular furnace with squire cage fan to blow air down heat was amazing just looked time consuming and rather Redneck safe
s_ontario is offline   Reply With Quote
Old 09-14-2010, 05:34 PM   #12
demondriven
Dawg, Did you ever build this? I have started building the original version but was wondering if you build this one and how its working for you?
demondriven is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
