Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 01-02-2010, 03:44 PM   #1
Teikas Dad
Senior Member
Default Price comparison t1-11 vs rough shiplap
Trying to narrow down the interior wall covering for my shop. I read all the posts about using OSB, but I'm not too crazy about the look. I'm looking at either using t1-11 (5/8") or trying to find a local sawmill and buy rough cut 8" shiplap. What I'm trying to figure out is which is the more cost effective way to go.
Is it less expensive to go with the t1-11 panels or the sawmill supplied shiplap? I'm doing the install so installation costs are not an issue. I know a 4X8 sheet goes up a lot quicker than 1X8 boards, but I've got an air nailer so that's not a big issue.
Teikas Dad is offline   Reply With Quote
Old 01-02-2010, 04:11 PM   #2
BlindViper
Senior Member
Default Re: Price comparison t1-11 vs rough shiplap
I think your gonna kinda need to know what the mill is gonna charge. I would imagine your gonna use more nails too. But around here a 1/2 sheet of osb is about 11$. That would mean you would have to pay less then 1.83$ a 8' board of the 1x8. 15/32 sheathing is about 16$ a sheet its what I would use if I was worried about the osb "pattern".
BlindViper is offline   Reply With Quote
Old 01-02-2010, 05:02 PM   #3
Matt M, PA
Senior Member
Matt M, PA's Avatar
We used "Smartpanel" or Smartside..I think it depends on who makes it. It's what they use on the exterior of sheds. It looks rustic with a nice grain pattern and is primed so it paints easily.
Matt M, PA is offline   Reply With Quote
Old 01-02-2010, 06:27 PM   #4
e3pres
Senior Member
e3pres's Avatar
I've been pricing T1-11 and SmartSiding or whatever it is called. 4X8 sheets are going for $16-21 here in TN. Not sure on the shiplap. I haven't priced it yet.
e3pres is offline   Reply With Quote
Old 01-02-2010, 06:56 PM   #5
Teikas Dad
Senior Member
I looked up the smartpanel. Lowes and HD carry it (or can get it). That might fit the bill for me as it can be ordered in 10' lengths.
Old 01-03-2010, 09:01 AM   #6
Bender78
Senior Member
Bender78's Avatar
I recently bought some native rough sawn 1x12's. Price was $.70 per board foot. Not more than a couple of years ago it was $.45 or $.50. When I built my barn/shop, using the native lumber for siding was a no brainer, now not so much.
Bender78 is offline   Reply With Quote
Old 01-03-2010, 09:07 AM   #7
Teikas Dad
Senior Member
Quote:
OK, that brings up another question. Seeing that I'm not a match wiz or a full time carpenter....how do you convert board feet to square feet? I figured that would be a good way to comparison shop. A 4X8 sheet of anything is 32 square feet...how many board feet of something 1 inch (actually 3/4) thick by 8 inches wide equals 32 square feet? Or...is there a formula to figure it out?
Old 01-03-2010, 11:52 AM   #8
Matt M, PA
Senior Member
Matt M, PA's Avatar
I just had to go down to my garage and was reminded of this thread.
Depending on how you want to finish the interior...using T1-11 or shiplap is more work later if you want to paint or finish the inside. A friend has T1-11 in a workshop that was stained. It's a barn that's 100 years old and it "fits" the look of the building. That being said, it also is not exactly smooth. I supposed using wood you'd need to seal it before painting unless you stained.
For my garages...I want white walls. Helps with light, looks clean...just my preference. Finishing Smartpanel should only required painting as it's already primed. Saves alot of work if you choose to paint.
Just my .02.
Old 01-03-2010, 01:55 PM   #9
BlindViper
Senior Member
[QUOTE=Teikas Dad;715165]OK, that brings up another question. Seeing that I'm not a match wiz or a full time carpenter....how do you convert board feet to square feet? I figured that would be a good way to comparison shop. A 4X8 sheet of anything is 32 square feet...how many board feet of something 1 inch (actually 3/4) thick by 8 inches wide equals 32 square feet? Or...is there a formula to figure it out?[/QUOT
board foot is for lumber not plywood. 1 board foot is 1" x 12" x 12" so his 1"x12" was .70$ a foot. If you got a 2"x12" it would have been 1.40$ a foot.
Old 01-03-2010, 01:57 PM   #10
Bender78
Senior Member
Bender78's Avatar
Quote:
A 12" long piece of 1x12 is 1 board foot. If it was a 2x12, it would be 2 board feet. 12 inches of 1x6 is .5 board feet. Think of it as a cubic measure.
Old 01-03-2010, 01:59 PM   #11
Bender78
Senior Member
Bender78's Avatar
great minds think alike BV!
Old 01-03-2010, 03:26 PM   #12
Teikas Dad
Senior Member
OK, just got back from Lowes. They have 3/8 smart side panel (8' long) for about $20 a sheet. I checked with the special order desk to find out if they can order 10' lengths. They can...but they told me that the 10' panels are $40 each. I guess I'm going with 8' panels with a 2' filler on top. I'll just put a piece of trim on the seam. I like the smart side panel because it's primed already. That will make painting it a lot easier. Two of my four walls are 24" OC, the inside wall against my existing barn is 16" but it's covered with plywood already so there's plenty of support there. The front wall was supposed to be 24" OC, but with the 6' wide door and the windows I put in the only 24" wide bays in the walls are directly above the door. The rest are spaced out at 17", so I think that wall will support the 3/8" panel without a problem. I thought about two walls that are spaced 24" OC and not wanting to have the 3/8" panel bow in or out I came up with a solution. Once I insulate I'm going to put 2X3 studs horizontal with the wide edge flush with the 2X6 studs in the 24" bay at 2', 4', 6' and 8'. That way where I have the 24" OC bays there will be a bunch of 2' X 2' squares. I only need about a dozen 2X3s to do it because of the extra framing for the windows, so it's only $25 extra to do it that way. I end up with R19 insulation in the walls with 3/8" smart side panels on the wall. If anyone sees any reason why it won't work that way, please let me know.
Old 01-03-2010, 03:34 PM   #13
WinFred
Senior Member
anoter .02 worth...
unless you want the wood look or gotta have it....
10' sheets of 5/8 OSB smooth side out and paint it....
1/2" even but not 7/16"...
it's a shop.. the OSB would service you best when comes time to "hang" "stuff" on the walls...
__________________
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming
WOW!!! What a Ride!
Forget the primal scream, just ROAR!!!
WinFred is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
