Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 01-03-2010, 04:54 PM   #1
Moremph
Junior Member
Default 1 ton truck crane, How can i make the turning mechanical?
I have a truck crane similar to the picture below, It is very handy when by your self, However if you are not on perfectly level ground and pick up a load it will swing around to the low side and hit the truck. (my driveway is a hill so it makes it next to impossible to load by your self.
A you can see in the picture the top of the crane slides over the tube of the bottom (just add some grease), I was trying to think up of a way that i could tie these two pieces together and make the swivel action be mechnical with a hand crank or something? any ideas? I m drawing a blank on this one
Thanks Travis
Moremph is offline   Reply With Quote
Old 01-03-2010, 05:03 PM   #2
nissan_crawler
Senior Member
nissan_crawler's Avatar
Default Re: 1 ton truck crane, How can i make the turning mechanical?
worm gear...
__________________
If guns cause crime, all mine are defective. Ted Nugent
"A man with a gun is a citizen. A man without a gun is a subject. " John Lott
"Taking my gun away because I might shoot someone is like cutting my tongue out because I might yell `Fire!' in a crowded theater." Peter Venetoklis
nissan_crawler is offline   Reply With Quote
Old 01-03-2010, 05:08 PM   #3
srmofo
Senior Member
Quick and dirty method would be to attach a come-along to the end of the boom then to the bed up near the cab somewhere. then just ratchet it up
srmofo is offline   Reply With Quote
Old 01-03-2010, 05:18 PM   #4
skipskip
Senior Member
skipskip's Avatar
How did you attach it to the bed?
I have the same one. works great on the level.
I am interested in how you solve this too.
Skip
__________________
Quote:
Originally Posted by fliffy42 View Post
Looks like there's hay in that there tool box. You find it in the barn?
skipskip is offline   Reply With Quote
Old 01-03-2010, 05:26 PM   #5
z28snksknr
Senior Member
z28snksknr's Avatar
Why not just drill a hole in the post and add a t-handle so you can add some resistance? Just tighten down the bolt and it won't swing. You could even drill some holes in the crane for pre-set positions if you want to lock it in place.
__________________
Quote:
Originally Posted by qmt2 View Post
Can I come over and lay naked in your screwdriver drawers?
My garage renovation: http://www.garagejournal.com/forum/s...ad.php?t=43030
My '54 Ford Resto:
http://www.garagejournal.com/forum/s...ad.php?t=62416
z28snksknr is offline   Reply With Quote
Old 01-03-2010, 05:47 PM   #6
Moremph
Junior Member
It does have holes to lock it in 4 positions 90 degrees of each other. But when you are trying to pick something up straight off the side of the truck, Then swing it around onto the bed (up hill) it is tough.
I thought about making a spot to stick a long bar in it from the backside for some leverage so i can spin it, But then you would only be able to sping, or winch and you would have to stop and try to lock it into the small holes
I was trying to come up with some kind of gear desighn so when you crank it you would have an bunch of area to stop. so you could spin a little, raise a little etc etc
I have it mounted on this flatbed right now, I Started by making a adapter that will slide into the stake pockets so i can move the thing to diffrent spots on the bed, However the Stake pockets are not strong enought, My plan is to mount 2" reciever tubes like on a trailer hitch in each corner of the bed, I think that it will be alot stronger!
Travis
Old 01-03-2010, 05:56 PM   #7
nissan_crawler
Senior Member
https://www.surpluscenter.com/item.a...atname=winches
cut the center out of the gear, weld it to the stationary post, weld the crank to the side of the boom so it contacts the gear.
__________________
Old 01-03-2010, 07:20 PM   #8
Moremph
Junior Member
Good idea, i actually have a brand new one of those around here somewhere,ill have to go dig it up. My only concern is the crane is prolly 4" tube and i am thinking that those winche are like a 3" gear
Gotta find a beefed up version somewhere!
Travis
Old 01-03-2010, 09:02 PM   #9
Jared
Senior Member
Jared's Avatar
you could use a chain and sprocket so you could turn it with a boat trailer winch.
__________________
1972 yamaha ct-2
1997 Toyota Tacoma 4x4 3.4l
2006 kawasaki klr 650
Jared is offline   Reply With Quote
Old 01-04-2010, 12:30 AM   #10
rsanter
Senior Member
rsanter's Avatar
go to HF
they have a number of different hand winches
select one that uses a work gear
steal the worm and handle, then steal the ring gear off the hub of the winch.
cut out and weld the ring gear to the upper part of you winch
weld part of the body of the winch that holds the worm and handle to the lower part
bob
__________________
my wife says that I have never met a tool I havent liked. people on the other hand......
rsanter is offline   Reply With Quote
Old 01-04-2010, 06:36 AM   #11
Kevin54
Senior Member
Kevin54's Avatar
I'd weld a small receiver to put a handle in it to turn it. Then for a locking mechanism, look at a small flywhell off of a riding mower and then fabricate a latch. Basically about like a cheap Come-a-long locking mechanism. Or a round disc that has a series of holes every so many degrees apart. Turn the hoist with a handle, then drop a pin into the corresponding hole where you want it to lock.
__________________
THE ADDITION
Kevin54 is offline   Reply With Quote
Old 01-04-2010, 10:21 AM   #12
jonny o
Ring and pinion?
jonny o is offline   Reply With Quote
Old 01-05-2010, 12:14 AM   #13
Racecarl
Senior Member
Racecarl's Avatar
I was looking on Burden Surplus's web site and thought that their p/n 13-1399-R would work pretty good. I would bore a 1 1/4" hole in the top of the existing winch boom, allowing clearance for the 1 1/8" gearbox output shaft to go through. The output shaft would mate with a hub of some sort that is welded to the inside of the inner stationary pipe. A fabricated bracket would secure the base of the gearbox to the top half (the turning part) of the boom.
When you turn the crank on the gearbox, the output shaft is held stationary by the base pipe. The gearbox's output torque is then transmitted to the case, which then turns the top half of the winch.
I built a similar truck winch but I used a wheel gearbox for an irrigation center pivot as a base. These are large, heavy, and TOUGH gearboxes. I welded a 4" pipe to the wheel hub and designed the rest of the winch similar to the one in the pictures above. It worked very well and would actually pick up stuff that was too heavy. I once picked up a 4" Berkley centrifugal pump with a 10hp electric motor. I had to put blocks under the bumper to keep from springing the pickup frame.
Good luck with whatever you decide to do.
Racecarl is offline   Reply With Quote
Old 01-05-2010, 02:58 AM   #14
nissan_crawler
Senior Member
Quote:
Originally Posted by rsanter View Post
go to HF
bob
I already said that. The problem with your setup however, is that the handle will hit the boom support if it's rotated the right direction. Welding the ring gear to the lower part and putting the handle/worm gear on the boom, eliminates that problem.
__________________
Old 01-05-2010, 03:04 AM   #15
nissan_crawler
Senior Member
Quote:
Several issues with this.
One, that handle isn't going to be easy to use to swing around, or as steady.
Two, a ratcheting mechanism will only go one direction, if he has to turn the load to a point where it switches angle and heads back the other way, it will freewheel.
Three, if it's pinned, that means A. It has to line up with a hole, B., he has to hold the load with one hand on the handle, and try to get a pin in with the other hand.
Four, he has to do all of this while trying to be sure said handle doesn't A. Flip him out of the truck, or B. Smash him into the truck.
The mechanism should take the force, not the user.
Quote:
Originally Posted by jonny o View Post
Ring and pinion?
and how would that change anything?
__________________
Old 01-06-2010, 09:41 AM   #16
jonny o
Quote:
Was a pretty basic thought. Common discarded auto parts that transfer rotation from one axis to another. Or did you mean how could it be adapted to be used?
Or... did you think I was asking about the drivetrain in the truck?
Old 01-06-2010, 02:21 PM   #17
nissan_crawler
Senior Member
No, I meant it won't change his situation in the slightest, except for the fact that he would now have a handle whizzing around like mad while the crane also swung uncontrollably.
__________________
Old 01-06-2010, 02:50 PM   #18
jonny o
I'm with you now. In my opinion it would be easier to stop a handle with a huge amount of gear reduction from whipping the bed of the truck off with some sort of mechanical stop.
The hope was to use some mechanical advantage to overcome the weight and leverage of an off-kilter arm, but I guess since there is no way to stop or lock the motion he should tear out his driveway and repave it flat. Or maybe deflate the tires on the high side of the truck.
Old 01-06-2010, 03:39 PM   #19
nissan_crawler
Senior Member
or...install a worm gear mechanism that needs no extra lock that you have to try and engage with one hand?
My point is, if he's doing this for safety, which he is, the system should not be dependent on him having to do something to make it safe. What if his hand slips off the crank? It would go flying. What if he drops the pin? If it's a ratcheting mechanism, what if he goes past where it angles one way, and it starts heading the other way?
With all those designs, he's holding all the weight with one hand, and trying to secure it with the other.
With a worm gear, he's holding no weight, ever, and has a free hand.
__________________
Old 01-09-2010, 11:16 PM   #20
t. jones
Senior Member
These types of cranes were originaly shop built from old truck rear axles. Handle was attached to driveshaft yoke to rotate load, drum brake was often used with cable. I realize this doesn't help with Moremph dilema now but maybe next time.
Thanx Trevor
t. jones is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
