Go Back   The Garage Journal Board > The Garage > Flooring
Reply
Thread Tools Display Modes
Old 01-03-2010, 05:03 PM   #1
shearhod
Junior Member
Default enclosed trailer flooring
We are going to put a floor covering in our 24ftx8ft trailer. we don"t want place and stick tiles, any recomendations would be appreciated. john
shearhod is offline   Reply With Quote
Old 01-03-2010, 05:27 PM   #2
tigmusky
Senior Member
tigmusky's Avatar
Default Re: enclosed trailer flooring
alum d-plate that would look sweet $$$$$$
daye
tigmusky is offline   Reply With Quote
Old 01-03-2010, 05:36 PM   #3
thinkracing
thinkracing's Avatar
I put down the Rustoleum garage sealant that you can get from Lowes in my 20ft trailer. It comes with flakes. I should have put down a thicker coat, but it looks great and has held up to the wear and tear of race weekends.
__________________
www.sunoco.com
thinkracing is offline   Reply With Quote
Old 01-03-2010, 05:42 PM   #4
TCScustoms
Junior Member
My father-in-law put down 4x8 sheets of aluminum diamond plate in his race trailers holds up great and looks freakin sweet...we have also done it on one he sold that they did it 4 ft up the sides, great for a racing trailer not sure what you haul but just an idea
TCScustoms is offline   Reply With Quote
Old 01-03-2010, 05:47 PM   #5
R1chy
Senior Member
R1chy's Avatar
I used interlocking black hard rubber "Coin" pattern tiles sold at Lowes, which met my needs. The only problem is direct sun will expand the tiles, so you have to install them lose on the floor so they can float to adjust for any expansion/contraction. They were a little pricey but I really like how it looks. Below is not the best picture of the floor and I have more pictures but they are on one of my computers that is currently not working (blown power supply) - if/when I get it fixed I'll post them. On the ramp I used outdoor porch flooring paint, which is ok for the ramp but I suspect would pull up on the tires if you use it on the trailer floor.
I noted recently a similar but in a "Diamond Plate" pattern available at Home Depot. It also seems to be a harder rubber which may not expand as much.
Another option is Line-X sprayed directly onto the wood flooring.
Good Luck, R1chy
R1chy is offline   Reply With Quote
Old 01-03-2010, 08:14 PM   #6
NUTTSGT
NUTTSGT's Avatar
Probably doesn't matter what you use, you'll wish you went with something else.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 01-03-2010, 08:30 PM   #7
CamarosRus
Senior Member
CamarosRus's Avatar
Richy, Can WE please see close-up pics of your over the tire strap set up.....The E track and idler piece and rachet.
What vendor did you buy from ?????
Thanks,
__________________
Chuck Sharin
Auburn,WA (between Seattle & Tacoma
CamarosRus@Gmail.com
ILWU Longshore member
Viet-Nam 68'/69'
Collect/Restore/Judge
69'/70' Camaros
CamarosRus is offline   Reply With Quote
Old 01-03-2010, 08:49 PM   #8
djjsr
Senior Member
djjsr's Avatar
I had a 37' gooseneck and found aluminum diamondplate too expensive to cover the entire floor. I used 2 ft wide strips of it just where the tires and engine/trans would sit. The rest of the floor I covered with gray "garage carpet" from HD.
djjsr is offline   Reply With Quote
Old 01-03-2010, 08:56 PM   #9
trailwart
Senior Member
trailwart's Avatar
on my 8x20 i had, i used rolled checker flooring from HD, had less than 300 into it with glue and never had any issues. the floor was little over 8 wide and was cut to length, there were no seems, 1 solid floor.
trailwart is offline   Reply With Quote
Old 01-03-2010, 09:16 PM   #10
Matt M, PA
Senior Member
Matt M, PA's Avatar
I carpeted mine too.
Matt M, PA is offline   Reply With Quote
Old 01-04-2010, 10:06 AM   #11
robin1731
Senior Member
robin1731's Avatar
Send a message via Yahoo to robin1731
I used industrial floor paint with sand mixed in on the floor of my race trailer. I got it at Lowes about 5 or 6 years ago. The sand comes in a packet sold in the paint department. It has held up very well. I do have aluminum diamond plate where the tires set.
robin1731 is offline   Reply With Quote
Old 01-04-2010, 10:10 AM   #12
Cobra4B
Senior Member
Cobra4B's Avatar
Buddy of mine use the self-stick but had 2 strips of diamond plate for tire paths... looked awesome. He used to to transport his Corvette show-car around for a few years.
He let me borrow the trailer to tow to VIR when he was selling it (good place to advertise, eventual buyer saw it at VIR), but when I was loading up my car it turns out that V710s tires covered with paddock gravel and nice polished diamond-plate don't mix well I really did a number on them when the tires spun some getting the car up the ramp.
Luckily the new buyer was using it as a race car hauler.
__________________
Brian
New 30x20
Old 20x20
Cobra4B is offline   Reply With Quote
Old 01-04-2010, 07:20 PM   #13
Ray-CA
Senior Member
Ray-CA's Avatar
Send a message via Yahoo to Ray-CA
I just had the Line-X guy coat the floor.
Ray
__________________
Knowledge is knowing that F=ma. Wisdom is knowing why that is important.
Ray-CA is offline   Reply With Quote
Old 01-04-2010, 08:37 PM   #14
R1chy
Senior Member
R1chy's Avatar
Thanks,
The detail pictures I have are on my desktop computer's hard drive, but due to a power supply problem I can't get to them. Further regret my trailer is out in the barn, about 1 hr away in the Shenandoah Valley, so I can't quickly take more pictures. But the manufacture's web site has some good pictures of them, which should provide you a good view of the set up. There is even a video of how a basket type style works with vertical E-Track, but I've got the single strap with rubber grippers for Horizontal E-Track ->http://www.autohaulersupply.com/inde...duct_list&c=83.
I really like this style of tie-down, but there are pro's/con's to this style, vice a frame tie down method. Specifically, this method allows the suspension to travel and thus a tight fitting car may bounce around to the point to hitting the side walls (or more likely the wheel wells). Some even claim it will "blow out" the shocks, or at the very least contribute toward premature failure. But I have not had any of these problems after towing for hundreds of miles.
Frame strapping is another method (not sure if there are any others). And the con's here include the stress placed on the vehicle's suspension when pulled down tight (alternatively not strapping it tight will allow the vehicle to potentially "hop" around and hit a side wall).
Since I don't trailer any one car alot my choice was the former, especially since this is the method mostly used by Auto-Hauler trucks. That said, you should research your options.
Regarding the E-Track - I love it and bought several extra strap Idlers to use with my conventional straps to tie down other objects in the trailer (http://www.autohaulersupply.com/inde..._detail&p=5155). Another item I bought is a set of brackets that snap into E-Track and used to hold a 2x4 wood board (actually they can hold any size 2x). I have seen them listed as a Wood End Socket (http://www.amazon.com/Wood-End-Socke...0&sr=8-1-fkmr1). I use a couple of these on the floor, with a 2x6 between them, to keep other things I haul from sliding around on the floor. Combined with the flexibility of the extra strap Idlers, I can keep anything firmly in place. These are hard to find, and I have also gotten them from AutoHauler, but you have to ask for them.
One word of caution, quality is important when you are hauling around your prize possession for hundreds of miles before opening the door at the destination. The last thing you want to find is a broken strap or bracket that has allowed your "baby" to get dinged. Or worse yet, have problems when you go into a panic stop along the highway. I have bought many items from AutoHauler.com - I'm happy with their quality and I would not doubt others out there are also good, but confident to say AutoHauler is very good ("http://www.autohaulersupply.com/" ).
Also, what you don't see in the picture in my prior post is my "Oh 5hit" strap that goes over the axel to/from my reinforced floor D-rings. And if you do use E-Track, make sure it is securely attached to the frame members of the trailer and not just to the plywood flooring.
Once again, if (hopefully more like when) I get my other computer back up and running I'll post my pictures.
Good luck, R1chy
Old 03-21-2014, 02:46 PM   #15
GarageFlooringLLC
Alliance Member
GarageFlooringLLC's Avatar
I found this post from 2010 on trailer flooring. G-Floor just updated their offering and it now includes felt backed product. We have not found a way to get sizes that are convenient for someone doing a single trailer but we do have some great 8'6x100' rolls for manufacturers who are using it for their OEM flooring.
Many DIY customers are still using the original PVC G-Floor and I am looking for a way to make cut piece of the new product available.
GarageFlooringLLC is offline   Reply With Quote
Old 03-22-2014, 08:21 AM   #16
sunsation288
Senior Member
sunsation288's Avatar
VersaRoll Pro from costco , i love the finish
__________________
I will try my best to be understood
MY DREAM GARAGE
http://img.photobucket.com/albums/v235/25outlaw/Garage/a1a31bf3-469a-4a37-b2f8-4683a6760389_zpsb8fa3ff7.jpg
sunsation288 is offline   Reply With Quote
Old 03-22-2014, 09:48 PM   #17
jeepinjz
Senior Member
I diamond plated mine wish I would of went a different way dont shine in some spots now and don't look as good as it did at first guess depends on what your going to do with it
jeepinjz is offline   Reply With Quote
Old 03-22-2014, 11:43 PM   #18
unslow1
Senior Member
I used the specked garage floor paint from Menard's on my last one. I just ordered another enclosed and will do it again.
unslow1 is offline   Reply With Quote
Old 03-23-2014, 09:23 AM   #19
R1chy
Senior Member
R1chy's Avatar
In a couple of weeks I will pick up a new enclosed trailer so I'll be revisiting the floor cover issue.
I really liked the rubber coin flooring I used last time, so I plan to use it again for the rear car portion - only this time I will use sheet flooring instead of the tiled stuff. Up front I will use black and white 9 inch square checker for the work area of the trailer - again sheet vice tile.
I'm still undecided on what I will use for the rear ramp, but I'm leaning toward using Aluminum Tread Plate (ATP), which I may also use for the tire path outside of the E-track. I couple of other racers I know have this in their trailers appearing to both work well and look good.
If I remember, I'll take some pictures of the install and post them.
R1chy
Old 03-23-2014, 09:56 PM   #20
OldNeons
Senior Member
Curious if anyone else has tried the spray on bed liner type material? I had a trailer mfgr tell me NAPA sells a DIY kit for about 1/8 the cost that does a nice job and is durable? I use my enclosed trailer to haul a little of everything including sliding around 300# machines on steel leveling legs, etc. it will see heavy use and I'd like it to stay looking decent or years to come. How about ATP on whole ramp door floor? Is it slick if wet? Any suggestions? Thanks
OldNeons is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
