Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 01-31-2010, 06:34 PM   #1
eyezlee
Junior Member
Default Sharpening a UniBit / Step Bit
I've got a set of Uni bits from Irwin and 2 of the 3 won't get started. Once I get a hole drilled with a regular bit, the step bit takes off and works correctly.
What's the proper way to sharpen these kind of bits?
Thanks.
eyezlee is offline   Reply With Quote
Old 01-31-2010, 07:21 PM   #2
mcdtommy23
Senior Member
Default Re: Sharpening a UniBit / Step Bit
I sure hope someone can answer this, I've got about 6 or 7 uni-bits that we burnt up in stainless. I saved them hoping to be able to resharpen, or I figured they could be used for something, I just didn't/don't know what.
mcdtommy23 is offline   Reply With Quote
Old 01-31-2010, 07:51 PM   #3
Mickey O
Senior Member
Mickey O's Avatar
I just sharpen the tips and file any burrs off in the opening along the side.
__________________
Cheap tools are for chumps.
...the wealthy can currently “accumulate many millions of dollars in these accounts, substantially more than is needed to fund reasonable levels of retirement saving.”
Mickey O is offline   Reply With Quote
Old 01-31-2010, 08:03 PM   #4
eyezlee
Junior Member
Sharpen the tips? Can you expand please.
Old 01-31-2010, 08:08 PM   #5
wreckercologist
Senior Member
wreckercologist's Avatar
A tool sharpener is really the right way to do this and maintain the proper angles. That said, I take them to the bench gringer with a 6" wheel. I hold them by the shank and grind them on the side of the wheel. This isn't really the correct way because the side of the wheel is 90 degree's to the face which yeilds a zero degree rake angle. Most unibits I've seen are a positive rake. Not right, but it puts a fresh edge on the tool and does it quick. These things are too $$ to throw out. I'll go to work and snap some pics.
__________________
Pride is dead
wreckercologist is offline   Reply With Quote
Old 01-31-2010, 09:01 PM   #6
Diablo
I use my uni-bits daily and have found that using a file can make it a bit better but there is no real good way. I have just settled with making a 3/16 pilot hole for pretty much everything.
Diablo is offline   Reply With Quote
Old 01-31-2010, 09:44 PM   #7
E.rodz
Senior Member
E.rodz's Avatar
you can send them out to fastenal to get sharpened. you realy should pilot the hole before using a unibit to prevent walking anyways. you can use a 4" grinder to sharpen theese also or a grinding stone for tool room bit sharpening. hope this helps.
__________________
Follow Us on Facebook!
http://www.Facebook.com/ErodzCustoms
Visit Our Website!
http://www.ErodzCustoms.com
Follow the Belair Build!!
http://www.pro-touring.com/showthrea...ner&highlight=
E.rodz is offline   Reply With Quote
Old 01-31-2010, 10:04 PM   #8
cheap bastard
Senior Member
I have used a rotory chain saw sharpener and a steady hand. It only works to the length of the stone.
cheap bastard is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
