Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#1 |
Senior Member
As promised in my previous thread of the same title I have conducted more tests to show the contact areas of various combination wrenches I own.
This test was more controlled than the previous one. In this test the wrench was held in a vise between two pieces of wood and a torque wrench was used to torque a nut in the box end to 30 ft-lbs. The nut was colored using a Sharpie marker to better show the contact areas. Here is a picture of all the wrenches used in this test. ![]() The wrenches were assigned numbers from top to bottom and are as follows: 1. Snap-On SOEX18 - Date code 1999 2. Wright 1118 - New Kindly donated by TRTOOLSUPPLY to be tested 3. Craftsman Professional 45978 - New 4. Snap On OEX18 No date code. Flank drive. Purchased used. 5. Craftsman Raised Panel 12pt Date Code: -V(inverted V)- 1990s Lightly used 6. Craftsman Raised Panel 12 pt Date Code -VV- From my grandfather. 7. Craftsman Raised Panel 6pt Date Code: -V(inverted V)- 1990s Lightly used 8. Promark Taiwan made wrench received sometime in the 90s. Unused 9. GearWrench Ratcheting Reversible Purchased early 2000s Lightly Used Here are some pics of the box ends of the wrenches: 1. Snap-On SOEX18 ![]() 2. Wright 1118 ![]() 3. Craftsman Professional ![]() 4. Snap On OEX18 ![]() 5. Craftsman Raised Panel 12pt (Newer) ![]() 6. Craftsman Raised Panel 12 pt (Older) ![]() 7. Craftsman Raised Panel 6pt ![]() 8. Promark ![]() 9. GearWrench Ratcheting ![]() To try to get more consistent results each wrench was tested with two different nuts. One additional nut was tested on the first two wrenches holding with the torque wrench in the vise to compare the results to nuts tested with the wrench in the vice. No significant differences were noted. Here is a picture of all the nuts tested: ![]() Below are two pictures of the nuts used in each wrench showing the most complete contact areas. 1. Snap-On SOEX18 - A good contact area on the face near, but not on, the edge. Flank drive doing what it is supposed to! ![]() ![]() 2. Wright 1118 - A very wide contact pattern on the face. I ran several more tests to make sure this wasn't some fluke. This is called Wright Drive. Looks to work well too. ![]() ![]() 3. Craftsman Professional - Contact pattern on the face pretty far way from the edge. ![]() ![]() 4. Snap On OEX18 - Very similar to wrench #1 ![]() ![]() 5. Craftsman Raised Panel 12pt (Newer) - Very similar to wrench #3 ![]() ![]() 6. Craftsman Raised Panel 12 pt (Older) - Contact areas are directly on the edges. This has a higher potential to round a fastener than other wrenches with contact areas on the face. ![]() ![]() 7. Craftsman Raised Panel 6pt - Contact area is in the same location as the new craftsman 12 pt but wider. ![]() ![]() 8. Promark - Contact area on the edge. Similar to wrench #6. ![]() ![]() 9. GearWrench Ratcheting - Contact areas seems to be very close to those seen on the Snap-On wrenches. ![]() ![]() I would have liked to have a new Snap-On for the test but can't justify the cost of a new one just for this testing. I'm not a professional mechanic and only work on a couple newer GMs so most of my SAE stuff is very lightly used. If I happen to get some more wrenches I'll test them and post the results. I PMed Mike Wren and GearWrench here on the board asking if they'd like to send a wrench to be tested. I haven't heard a response from either, but I don't think they have been online here since I sent the messages. So, keep your fingers crossed that they'll respond positively and I'll have some more wrenches to test. Please post any comments or questions and I'll do my best to answer it. Got a wrench you want tested with the results posted here? Let me know. Thanks again to TRTOOLSUPPLY for sending me a wrench to test. As an aside: the thick beam and fully radiused edge makes for a comfortable wrench. Hope you have found this entertaining. |
#2 |
Senior Member
Another great thread! Keep the tests coming
Scott
__________________
WTB: International Harvester tools. (the automotive mechanic's style tools made by Wright) Also looking for other IH items of interest. |
#3 |
Senior Member
You might get easier to see and better results on your test by using Prussian Blue instead of a sharpie. That's what we use in the machining field to transfer surfaces.
http://www.amazon.com/Prussian-Blue-.../dp/B0009RM8VI
__________________
"Any man who thinks he can be happy and prosperous by letting the American Government take care of him; better take a closer look at the American Indian." Henry Ford If I’m texting while I’m drinking and driving, do they cancel each other out? |
#4 |
Senior Member
My non-pro eye thinks the Wright and the C-man pro did the best, and I'm a Snap-On koolaid drinker. That Wright is quite nice. If only they made a long version...
#5 |
Senior Member
DavidB,
Thanks for conducting the wrench test. I have learned lots from Garage Journal members over the last couple of years about hand tool technology or usage. I appreciate it and keep these hand tool tests coming too! Dave |
#6 |
Senior Member
Very informative,I always appreciate your work.
__________________
"....Give me neither poverty nor riches" |
#7 |
Senior Member
nice testing.
__________________
Cheap,fast,reliable. You can chose only 2. Rip Ryan Dunn http://www.usenglish.org/ |
#8 |
Senior Member
nice post! Thanks for the write up!!!!
__________________
"Hammer to shape, Grind or File to fit, Paint to match!" Posted by Fedwrench "As a tool whore, it is my duty to have wrenches for every possible occasion".Posted by TAMPAGT07 "I like my ratchets how I like my women, the more teeth the better". Posted by stricht8 "When life is over as we know it there will be cockroaches eating Twinkies using craftsman RHFT ratchets." |
#9 |
Senior Member
Thats interesting how different they all are.
#10 |
Senior Member
Thanks for your time in performing this test.
How would you rate the wrenches in terms of its friendliness to the flank area of the nuts? Did the non-flank drive wrenches leave a clear impression on the nut? |
#11 | |
Senior Member
Quote:
With that out of the way here are results from another test! Here are some more nuts tested in three different wrenches. From left to right we have nuts tested in wrench #1, #2 and #8. ![]() You can see the marks here but lets take a closer look... Here is an extreme close up of a nut tested on wrench #1, the newer Snap-On. The area of contact is clearly seen. ![]() Here is an extreme close up of a nut tested on wrench #2, Wright. The patch is wider but doesn't appear to be as deep. I will note that when I first did this test with the Wright wrench there were a couple scratches on the nut. I assumed this was due to a burr or two since this is a new wrench and light touched up the inside of the box end with a rolled piece of 600 grit sand paper. Problem solved. ![]() Here is an extreme close up of a nut tested on wrench #8, Promark. This has the smallest area of damage since it is directly on the corner. Though if you round the corner that won't look good either. ![]() The extreme close up images and to a small extent the group shot show the marks more clearly than you'd see without a magnifying glass. The extreme close up images also start showing marks on the nuts that were there before I tested them. There were fine scratches, pits, and you can see the less than perfect edges of the nuts. Looking at the nuts with just my eyes the SO shows a clearly defined line, the Wright shows a lightly scuffed area, and the Promark shows rough edges. Due to the fact that I'm not able to torque the nuts perfectly the corners of some of the edges show a larger contact area. On the Promark this area is starting to round the nut. So, to finally answer your question... I'd say the Wright wrench would be the nicest to the flank area because it has a larger contact area. All things equal the larger the contact area the lower the pressure which would result in less deformation to the face. After that it's probably a toss up among the the wrenches who have copied flank drive since they all have similar contact areas. I suppose it could be argued that the non-flank drive wrenches do the least damage to the flank area since they don't contact there. On the other hand they have a higher chance of rounding the edge off which would do bad things to the flank area. In the end though the wrench with Wright Drive, Flank-Drive, or a copy of Flank-Drive stands a much greater chance of getting that rusty nut off than the ones that contact at the edge. Hopefully, I've provided pictures to where anyone can draw their own conclusion. |
#12 |
Senior Member
To everyone else: Thanks for reading! I'm glad you find it interesting. I'd like to get some marking blue at some point I'm just not sure where to find it around here. I'm sure a machinist supply house would have some but I haven't drug out the phone book to track one down yet.
If anyone has some tests they'd like to see speak up and I'll see what I can do. I'm not sure what else I'll do though obviously I found something to do as evidenced by the post above this. Maybe I'll run the numbers to show how much additional force is required for a shorter wrench. David |
#13 |
Very well done; fascinating results.
Seems to reinforce that there isn't much point to a six-point box wrench with flank-drive-ish 12-points. It's also unsurprising (but nice to have proven) how much better pretty much anything is to the generic Taiwanese wrench. I was surprised at how well the Craftsman raised-panel and GearWrench did. Does anybody know the OEM for the Craftsman Professional wrenches? S-K, Danaher? |
#14 | |
Senior Member
Interesting stuff
![]() Quote:
, the Snap-on.I'd like to see the same done with a current production Harbor Freight wrench. My guess is that the results would be very close to the Snap-on and GW. The same test with 6 and 12 point sockets might be illuminating (and perhaps controversial), too. Danaher. Last edited by Jononon; 02-26-2010 at 04:58 AM. |
#15 | |
Senior Member
Quote:
#16 | |
Senior Member
Quote:
Socket tests would be interesting as well but I only have some Craftsmen ones to test. |
#17 |
Senior Member
Great post & info. I`m glad to see someone with only a few posts contribute great info.
#18 | ||
Senior Member
Quote:
Quote:
*puts on flame proof suit* That being said, some of the highest quality wrenches you can buy today are made for Facom in Taiwan. Unfortunately I don't have a wide enough range either, perhaps someone could be persuaded to pick up the reins for that test? |
#19 |
Senior Member
Good Job, I too enjoyed this display.
I was surprised to see that Wright Drive seems to do the best in these tests, while Flank Drive appears to be a close second. Adam
__________________
I would like to know why everyone on G.J. is so wrapped up with screwdrivers and plastic handle ratchets... |
#20 |
Senior Member
Thankyou for taking the time to conduct the tests, very impressed.
__________________
Cornwell Tools U.K Dealer |
| Thread Tools | |
| Display Modes | |
