Go Back   The Garage Journal Board > The Garage > Garage Gallery
Reply
Thread Tools Display Modes
Old 02-26-2010, 07:04 PM   #1
widerberg
Senior Member
widerberg's Avatar
Default Pics of crushed stone parking pads?
Hi, All:
Strange request . . . could those with crushed stone/rock parking pads, or sheds/barns with crushed stone floors post pics?
With quotes I've been getting (west central Florida), I'm really leaning towards crushed stone for my parking pad (which eventually will have a lean to built over top of it) rather than concrete. The quotes for concrete are twice that of crushed stone, and money is tight.
I'm just not sure quite what crushed stone will look like.
Many thanks!
Bo
__________________
22' x 30' attached, not quite ready for prime time. 12' x 20' shed. 12' x 21' enclosed carport.
widerberg is offline   Reply With Quote
Old 02-27-2010, 09:24 AM   #2
Nighttrain
Senior Member
Nighttrain's Avatar
Default Re: Pics of crushed stone parking pads?
Widerberg- I will post a picture for you tomorrow when I have my camera. I have a 15'x60' area under my lean-to which I filled with crushed granite. I had the parameter curbed in concrete. It’s about 6” of this gravel. It works very well and is a future base for when I can afford to pour a slab on top of it. Only problem so far which isn’t too bad is the compaction of the gravel. I only used my small tractor to level it than drove my truck back and forth on it to compact it. With the weight of my 5th wheeler (14K #) the tires and landing gear sink pretty deep into the gravel. I would recommend for a more finished job, would be to rent a small roller compactor. Also maybe go with a larger gravel base and then finish with a smaller aggregate and water and roll that to a smoother finish.
Nighttrain is offline   Reply With Quote
Old 02-27-2010, 01:14 PM   #3
Grizz1963
Senior Member
Grizz1963's Avatar
Try Google Images.
http://www.garagejournal.com/forum/n...ote=1&p=797226
http://images.google.co.uk/imgres?im...26tbs%3Disch:1
Hope this helps.
__________________
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 02-27-2010, 09:25 PM   #4
widerberg
Senior Member
widerberg's Avatar
Thanks, guys. Nighttrain, I'm looking forward to seeing your pics. Grizz, I like that. I'd found some driveway-type pictures, too, but that particular one looks really good. I guess I was hoping someone out there had a lean to or shed with a crushed stone floor to reassure me :-) I sure like the price of crushed stone in my area, but don't recall ever seeing it used for anything but a driveway.
__________________
Old 02-27-2010, 09:27 PM   #5
widerberg
Senior Member
widerberg's Avatar
Doh! And as soon as I say I haven't found anything, I take your advice on Google Images and fine what I was looking for. I searched 'gravel parking pad' rather than 'crushed stone parking pad' and that did it.
http://carphotos.cardomain.com/ride_...0006_large.jpg
__________________
Old 02-28-2010, 02:07 AM   #6
Grizz1963
Senior Member
Grizz1963's Avatar
Glad you got what you wanted.
I often forget the search function on sites and begin new threads, and GOOGLE really is my friend
Sure there are loads more images out there if you try various word search combos.
__________________
Old 02-28-2010, 07:47 AM   #7
uniongoon
Senior Member
uniongoon's Avatar
My crushed stone driveway is over 300 feet long
__________________
My Shop updated http://tinypic.com/m/el1t2s/4
uniongoon is offline   Reply With Quote
Old 02-28-2010, 08:12 AM   #8
BioHazard
If they're only charging half as much for gravel as they are for concrete, you're either getting raped on the gravel or an amazing deal on the concrete. Locally crushed gravel is $11/yard + $30 per dump truck for delivery. Concrete is well over $100/yard + delivery. Gravel finishing consists of a single man with a compactor, instead of an entire crew of concrete finishers...
BioHazard is offline   Reply With Quote
Old 02-28-2010, 07:18 PM   #9
widerberg
Senior Member
widerberg's Avatar
Quote:
Hi, BioHazard:
My quote for 6 yards of 3/4" crushed stone, delivered, was $350 ($50/yard plus $50 delivery). The quote for concrete site-prepped, forms, delivered, finished, yada yada, was $600. Not sure which is a good deal and which is a bad one in west central Florida, but I know right now I can't afford the $600 after paying for the new project car So, $350 sounds like the better deal at the moment.
But, I'm still not totally loving the idea of stone because of moisture issues, even though I'll be doubling up on the polyethylene moisture barrier. So . . . the stone may serve as a base for a concrete pad in a year or two. My first priority after the parking pad, though, will be to get a lean to roof over it, to keep the rain off. Luckily, I've got a 12x20 shed a few feet to the south of the pad, and an 8ft privacy fence to the north and west, so the area is pretty protected from the elements.
__________________
Old 02-28-2010, 07:21 PM   #10
widerberg
Senior Member
widerberg's Avatar
Quote:
Wow, Uniongoon, that's nice. Very well compacted. I'm going to have to check out the smaller grades of crushed stone. They seem to compact much nicer.
__________________
Old 03-01-2010, 07:38 PM   #11
uniongoon
Senior Member
uniongoon's Avatar
Trick is to mix up the size of gravel, example which I did, B gravel base which is 3/4 stone with lots of sand, then a load of 3/4 gravel and topped with the limestone screening stone. The assorted stone aparently weaves together and makes for a better, adhesive pack. What I was told by the quarry guys, not that I am an expert.
Good luck and have fun, I really enjoyed this work.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
