Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 03-12-2010, 11:29 PM   #1
BobbyK
BobbyK's Avatar
Default Price of laminated beams
Looking into using a 30' glulam. trying to design a garage space with out any post's in the middle of the floor space.
Wondering if anyone could supply a link or know a ballpark price.
I'm also open to a steel I-beam.
BobbyK is offline   Reply With Quote
Old 03-13-2010, 08:16 AM   #2
Doug B
Senior Member
Doug B's Avatar
Default Re: Price of laminated beams
More info would be helpful.....length and width you are hoping for,wall height,roof pitch etc.
Doug B is offline   Reply With Quote
Old 03-13-2010, 08:34 AM   #3
KMR Construction
Senior Member
steel is going to be cheeper and stronger. LVL and gluelam are nice but expensive
KMR Construction is offline   Reply With Quote
Old 03-13-2010, 12:18 PM   #4
BobbyK
BobbyK's Avatar
Here is a very rough sketch of my proposed Garage.
the Beam would run the length of the garage and support the short wall on the 12' section as well as the roof of the 18' section. The glulam or steel beam would be 30' long
Old 03-15-2010, 08:50 PM   #5
KMR Construction
Senior Member
your gonna need an engeneer for that. You have alot of loads there
Old 03-15-2010, 11:56 PM   #6
kwb
Senior Member
You are carrying most of a 30x30 area, being from canada I would guess you have a decent PSF for snow load to carry - and with as flat of a pitch as you have shown you would be wise to overbuild since the snow is not very likely to be sliding off.
30x30 is 900sf I know the snowy areas around here use 100PSF load for roof loads so your beam will be carrying ~50,000# load (walls will carry the other parts).
Probably going to be something like a 30-36" tall beam as a gluelam.
Your choice of roofline is big limiting factor here- Storage truss would get you the upstairs you have shown and not need a beam.
Trusses for a 30' deep building and only 30' wide should be less than $1800 delivered
kwb is offline   Reply With Quote
Old 03-16-2010, 01:26 AM   #7
ddawg16
Senior Member
ddawg16's Avatar
As a reference....the beam in my garage is 20' long (7" x 16")...it cost me about $600....
If you end up with a beam you might want to consider PSL...I believe it has a higher loading than gluelam.
__________________
John
"Don't try to lead me to temptation, I know the shortcut."
In Progress...2-Story Addition link
2-Story Garage Complete My Garage Build Link
Home for.....
84 CJ7 - With a 'few' modifications.. My Jeep Build Link
And my wife's art Studio...
and 3 kids with more energy than we have...
ddawg16 is offline   Reply With Quote
Old 03-16-2010, 07:40 AM   #8
ixlr8
Senior Member
I am building a 30x30 garage with 11' walls. I want to put in a loft storage area in half of the garage. I also want it to be clear span, no middle supports. All 3 contractors I have talked with say with a 30' span... it will need to be a steel I beam, if I want to have any headroom left over. A gluelam or wood engineered I beam would have to be some 30" deep. The quotes I have gotten are in the $9500 range for a 15x30 storage loft!! So I am looking to get prices and sources for a steel beam to see about building this myself.
__________________
Jim
Toys;
16 BMW X5 3.5i
15 GMC Sierra 2500
13 Kioti CK40 TLB
02 VW TDI Golf, 288,000 miles, 56 mpg
01 550
00 Toyota Solara
ixlr8 is offline   Reply With Quote
Old 03-16-2010, 08:45 AM   #9
ersatzs2
Senior Member
ersatzs2's Avatar
My biggest regret is that I used engineered wood instead of steel for my 40' ridge, for the simple reason that the I-beam allows you to use a trolley hoist. The only major disappointment with my build. Go with the I beam!
__________________
My Shop, begun 8/06
http://www.garagejournal.com/forum/s...ead.php?t=5272
My 'second' shop, begun 9/13 at NJ Motorsports Park
http://www.garagejournal.com/forum/s...d.php?t=217642
Ready to go racing? Formula Ford (F1600) highly developed, for sale:
http://www.apexspeed.com/forums/showthread.php?t=53152
Collecting all things related to Mercer Motors of Trenton, NJ, 1909-1925. Automobiles, signs, stock certificates, tools, photos...
ersatzs2 is offline   Reply With Quote
Old 03-16-2010, 08:50 AM   #10
jwith68
Senior Member
Yes, in terms of a gluelam/LVL beam, you are looking at a pretty large beam.
You asked about a ballpark price - Disclaimer: I am in no way suggesting that the following size of LVL is in any way adequate for your application - locally, here in Missouri, a 1.75" x 14" LVL was $4.82/lineal ft as of this past October. That's the only size I priced or bought.
jwith68 is offline   Reply With Quote
Old 03-16-2010, 09:53 AM   #11
Ironcrow
Senior Member
Ironcrow's Avatar
As I recall, I paid well under $2000 for a 26 foot I-beam 16 inch section depth about 5 years ago.
Ironcrow is online now   Reply With Quote
Old 03-17-2010, 12:29 AM   #12
BobbyK
BobbyK's Avatar
I have no problems using a steel I-beam.
I was also thinking about it's other uses as well.
I do appreciate the info. so far,thanks.
Old 03-17-2010, 08:23 PM   #13
mastech08
look at socketsystems.com they can get you a 30' steel beam w/welded on foor joist tabs for about $950.00 each
mastech08 is offline   Reply With Quote
Old 03-17-2010, 09:15 PM   #14
ket-tek
Senior Member
ket-tek's Avatar
I have two LVL's my garage to support the full height second story above. The beams are 28' long and are about 22"x10". They were about $800 each.
The county engineer told me I had two options for a clear span with no posts after reviewing my plans, 2 LVL's and stick built joists above or use 14" TJI's for floor joists. The TJI route would have cost more and also ate down into my garage ceiling height some..
I didn't ask or pursue steel at the time. It was nice that the LVL's could just be wrapped with sheetrock without the extra framing needed. But having a trolly to pull an engine would be cool.. Just make sure to get the i-beam rating spec'd for your building load plus like 1000lbs or whatever..
ket-tek is offline   Reply With Quote
Old 03-18-2010, 12:03 AM   #15
swharris
Senior Member
swharris's Avatar
Send a message via Skype™ to swharris
Pictures of the 67 Miura?
swharris is offline   Reply With Quote
Old 03-18-2010, 09:22 AM   #16
Ezzie
Senior Member
Since you live in Petrolia, ON I would question your choice of a 12:2 roof pitch. Snow loads need to be taken into consideration as well so I suggest you talk to a structural engineer. He might recommend a greater pitch such as a 12:4 or 12:5.
Ezzie is offline   Reply With Quote
Old 03-18-2010, 11:35 AM   #17
BobbyK
BobbyK's Avatar
I'm in the process of getting the local building code.
My design is subject to change as required by code.
Talked to a local lumber yard. He gave me a few leads as far as steel beam suppliers goes.
They can provide full plans to the inspector for your average pole barn but is unable to help with any type of design requiring custom engineering.
I specifically need to find what our local snow load is. this will determine the beam I need.(as already stated by others)
Old 03-18-2010, 01:34 PM   #18
blkhonda1991
Senior Member
Quote:
i have the same concern and the fact that you'll be more susceptible to moisture problems with a lower slope roof
__________________
8-29-09 - Finally done renting and will finally have a garage!
blkhonda1991 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
