Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 03-16-2010, 09:33 PM   #1
KCarGuy
Senior Member
KCarGuy's Avatar
Default Under Sidewalk Drilling
Tonight I had to tackle a job that I was putting off, I had to dig a trench from my House, under a concrete sidewalk behind the house...next to the driveway and finish next to my garage to run a new (larger) Gas Line.
Digging under the sidewalk was a real Pain in my rear...all clay and stone.
So....I took a piece of 3 foot 1/2" steel tubing, slit the front end and inserted a 1/8 steel 4" x 4" piece of metal. Welded that up and ground the plate like a large Butterfly Bit. then welded an old broken Bit inside the other end, so I could chuck it in my Electric Drill...Worked like a charm!
Drilled from one side to the other and scooped out the loose dirt and rocks with my wifes extention garden tool.
Anyone else come up with some quik...low tech tools that made their life easier?
Lets hear about them, or see em!
Mine will make a great paint mixer also...
KCarGuy is offline   Reply With Quote
Old 03-16-2010, 10:57 PM   #2
texasOFT
Senior Member
texasOFT's Avatar
Default Re: Under Sidewalk Drilling
Another way to drill under a sidewalk is to attach pvc pipe (4'-5' of 1/2" or 3/4") to your garden hose and let the water drill the hole while you direct the pipe underneath the walk.
texasOFT is offline   Reply With Quote
Old 03-17-2010, 07:54 AM   #3
KCarGuy
Senior Member
KCarGuy's Avatar
TexasOFT
Great idea, Thanks for the tip.
Now I want to try it!!!
Old 03-17-2010, 08:43 AM   #4
1320stang
Senior Member
1320stang's Avatar
Buddy used to have a device that went on the end of an air hose, you twisted the hose one way and turned it on and a piston inside would ram it forward, then you twisted it the other way and the piston would drive itself back out of the hole. This was on a big compressor like you'd use a jackhammer on, and the device was about 3" in diameter.
__________________
_________________________________________________
Larry Hampton
1963 Fairlane 2 door post
1965 Mustang Coupe
1973 F-100 longbed
2002 Pontiac Grand Prix
2003 Explorer SportTrac
2005 Honda Accord
2008 Mercury Mountaineer
2015 F-150 Screw 5.0 2wd
Quote:
Originally Posted by raccoon View Post
PS: I'm a girl..
1320stang is offline   Reply With Quote
Old 03-17-2010, 01:19 PM   #5
rodnok1
Senior Member
rodnok1's Avatar
Quote:
This works great, I've gone under numerous sidewalks and a few driveways also, I put a adapter fitting for a nozzle on the end of my PVC as I was going through clay. While you are going through the trouble you may want to run an extra PVC for later, I did under the driveways.
__________________
Some people are like Slinkies... They're really good for nothing.
...But they still bring a smile to your face when you push them down a flight of stairs!
rodnok1 is offline   Reply With Quote
Old 03-17-2010, 02:45 PM   #6
ddawg16
Senior Member
ddawg16's Avatar
The water/PVC works quite well....messy...but easy.
One trick to make sure your going straight....insert the longer water filled PVC pipe into a larger pipe that acts like a guide....the reason is that in many cases you need a really long pipe to make across a driveway....well, unless you dig a really big hole on the start side....you have to bend the pipe....
Having the guide pipe lets you bend the smaller pipe and still keep it aimed straight.
__________________
John
"Don't try to lead me to temptation, I know the shortcut."
In Progress...2-Story Addition link
2-Story Garage Complete My Garage Build Link
Home for.....
84 CJ7 - With a 'few' modifications.. My Jeep Build Link
And my wife's art Studio...
and 3 kids with more energy than we have...
ddawg16 is offline   Reply With Quote
Old 03-17-2010, 05:47 PM   #7
DHCrocks
Senior Member
I used the PVC pipe and water hose trick before but ran into problems when I hit base course. The stones would not wash out easily like dirt. What I ended up doing was using a shop vac and stuck the 2-1/2" hose extension (plastic tube for floor attachment) into the hole to suck out the rocks, dirt and water. that worked pretty good.
DHCrocks is offline   Reply With Quote
Old 03-17-2010, 08:34 PM   #8
nutjob
Senior Member
Combine drilling and water:
http://www.borit.com/
nutjob is offline   Reply With Quote
Old 03-20-2010, 08:01 PM   #9
tcianci
Senior Member
tcianci's Avatar
Send a message via AIM to tcianci
Be aware that many "drilling" techniques will leave you with a bore that could cause settling of a blacktop surface. I have always driven pipe under driveways or walkways that way there is no chance for anything to cave in in the future.
__________________
People are doing either what they THINK is right or what they KNOW is wrong.
tcianci is offline   Reply With Quote
Old 03-20-2010, 08:40 PM   #10
KCarGuy
Senior Member
KCarGuy's Avatar
Thats a good point tciani,
I didnt even think of that, not really an issue with concrete, but blacktop would be another issue.
Thanks, KC
Old 03-21-2010, 02:40 AM   #11
d33pt
Senior Member
yeah i was thinking about the settling. do you try to backfill it after you run your pipe or wires?
d33pt is offline   Reply With Quote
Old 03-21-2010, 09:45 AM   #12
KCarGuy
Senior Member
KCarGuy's Avatar
I Backfilled Mine with sand...It packs up nice and tight. Instead of added back the stone and Dirt-Clay mix.
But, it also was a Concrete slab.
KC
Old 03-23-2010, 12:51 AM   #13
kartinkent
Junior Member
There are some situations where water pressure from a garden hose WILL NOT BE ENOUGH. I've got heavy clay soil with lots of rock. The only water pressure that's going to work here is a pressure washer. With a pressure washer, I was able to make quick time in drilling out a hole for a 4" PVC Sleeve going under a 5' wide sidewalk.
__________________
acekard
kartinkent is offline   Reply With Quote
Old 03-29-2010, 09:54 PM   #14
6768rogues
Senior Member
I have a neighbor who uses a long drill bit like quarries use to drill for blasting. He can drill through and pull a pipe back through. He has to dig a big hole with his backhoe to make room, but he can cross an entire roadway for a water service.
__________________
Why a cool garage? Chicks dig 'em. Alcohol may intensify the effect. As John Belushi said in Animal House, "I suggest you drink and drink heavily."
6768rogues is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
