Go Back   The Garage Journal Board > The Garage > Free Parking
Reply
Thread Tools Display Modes
Old 03-17-2010, 01:52 PM   #1
fordbroncodave
Senior Member
fordbroncodave's Avatar
Default ford windstar car alarm
for some reason what ever we do, our 1999 ford windstar alarm will go off randomly and cannot get it to shut off.
if we leave all the doors unlocked it will go off at night or if we lock all the doors it will still go off. sometimes when we are driving it will go off.
is there a fuse to pull or somthing to disable the whole alarm system?
it is kind of sad that we can no longer drive this vehicle because of the alarm problem.
does anyone know where the alarm speaker is located on one of these? it is a different tone then the 2 steering wheel horns.
__________________
50 transactions and counting!
my needs list:
http://garagejournal.com/forum/showt...fordbroncodave
fordbroncodave is offline   Reply With Quote
Old 03-17-2010, 02:10 PM   #2
Mr.Nutcase
Senior Member
Mr.Nutcase's Avatar
Default Re: ford windstar car alarm
Is the alarm aftermarket?
__________________
cheap tools give me pain and headaches...... he he
Mr.Nutcase is offline   Reply With Quote
Old 03-17-2010, 02:20 PM   #3
fordbroncodave
Senior Member
no it is factory from ford
__________________
my needs list:
Old 03-17-2010, 04:07 PM   #4
devilphrog
Senior Member
devilphrog's Avatar
My neighbor's Expedition does that... It's really awesome when it happens for hours at a time (intermittently)!
devilphrog is offline   Reply With Quote
Old 03-17-2010, 05:09 PM   #5
twisted654
Senior Member
Quote:
Expert: ALARMTEK - 10/17/2007
Question
i have a 1998 ford windstar recently the alarm goes off itself for no reason even when the van is not locked. it is a factory alarm. it seems to stay off if i just lock the van once but still goes off from time to time like that. if i honk the horn it goes off almost every time within 20 mins. if you can give me any insight to the problem that would be great thanks
Answer
Normally, you would insert the key in
the drivers door, turn left, then right
to disarm and reset it. If yours is malfunctioning,
you can disable it for good by doing the following:
The FACTORY ALARM DISARM WIRE IS
green/purple |-| located in either kick panel.
Once Located, splice into this wire with
a simular guage wire, and put it to
a solid chassis ground. This terminates
the alarm functions entirely.
However, at this point, this car would be exceedingly
easy to steel, so I suggest you get an aftermarket
alarm system to protect it from here on in.
Have a good day.
ALARMTEK
CARALARMSTORE.com
http://en.allexperts.com/q/Car-Alarm...arm-reason.htm
twisted654 is offline   Reply With Quote
Old 03-17-2010, 06:54 PM   #6
fordbroncodave
Senior Member
why would it be easier to steal? if i can lock it is enough to keep theives out.
who is gonna steal a socker mom van anyways? its got almost 200,000 on it
__________________
my needs list:
Old 03-17-2010, 10:19 PM   #7
ManicMechanic
ManicMechanic's Avatar
Seems like I remember seeing a TSB on this problem, I will check in the morning and see what I can find out for you.
ManicMechanic is offline   Reply With Quote
Old 09-02-2012, 12:41 PM   #8
edaw
Junior Member
Quote:
Hi ManicMechanic
I am also having trouble with this alarm. I have grounded the green/purple alarm wire, and the alarm still goes off. Any word on that TSB you spoke of?
edaw is offline   Reply With Quote
Old 09-02-2012, 01:49 PM   #9
61falcon
Senior Member
61falcon's Avatar
if your willing to pay some diag, a ford dealer or anyone with a scanner with the ability to get into the gem module (i believe its the gem module on that vehicle) you can see the last 8 alarm events. that will tell you what door switch is triggering the alarm. most likely you have a door ajar switch failing and tripping a false alarm event. its an easy diag with the right scanner.
61falcon is offline   Reply With Quote
Old 09-02-2012, 07:55 PM   #10
jwillis
Smile Re: ford windstar car alarm
Maybe they're wanting to steal the soccer mom?
jwillis is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
