Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 02-21-2005, 06:19 AM   #1
keperkey
Senior Member
Default Double Decker Garage
Ultgar,
If you are still around, what are your thoughts of a double deck garage (entry on main level, and entry below at basement level)? What must to be done for the main level to support the weight of the cars?
Thanks
keperkey is offline   Reply With Quote
Old 02-21-2005, 08:26 AM   #2
danski0224
Senior Member
Default
It can be done easily with Span Crete. Span Crete is a brand of precast concrete panels, DynaCore is another. Depending on the strength needed, the panel depth changes and prestressed cable is placed in the form. There are hollows that run through the length of the panel, or you can have it insulated with foam.
The bottom of the panels are smooth, and the top will need a coating of "grout"- a pumpable cement. The panels are set in place with a crane.
Span length and load will dictate panel construction. It may be possible to eliminate any supports in the center.
Openings and steel framing for things like stairs can be engineered in.
It is very strong, many multi-story condos are built with this construction, so are parking garages. A five story condo complex I worked on had an unsupported (center) span of about 50 feet, the panels were 12 inches thick and 4 feet wide.
It should be cheaper than conventional formed in place construction.
For the square footage they occupy, cars do not weigh much. A pile of boxes filled with papers occupying the same space as a car would weigh much more. Make sure the engineer (and you) know the intended use of the space.
Consult an engineer/architect to run a cost analysis.
danski0224 is online now   Reply With Quote
Old 02-21-2005, 10:01 AM   #3
ultgar
Senior Member
Default
Danski is right.....steel, precast/pre-stressed concrete, a competent engineer and installation crew and a healthy checkbook is all you need. I will be working on one of these project shortly (residential) and should have some pictures along the way. SD
ultgar is offline   Reply With Quote
Old 02-21-2005, 11:28 AM   #4
armoredsaintt
Garageaholic
armoredsaintt's Avatar
Default
Quote:
everytime I see your garage/showroom I start to drool and get that warm and fizzy feeling I'm still working on mine
armoredsaintt is offline   Reply With Quote
Old 02-21-2005, 12:10 PM   #5
sca037
Senior Member
sca037's Avatar
Default
We looked into this as well, but the desire to have a lift in the future meant that the weight of 2 cars (in storage mode ;-) plus the lift itself would present quite a load footprint.
Brian
sca037 is offline   Reply With Quote
Old 02-21-2005, 01:35 PM   #6
keperkey
Senior Member
Default
Thanks for the information. I look forward to seeing the pictures once you do this Ultgar. I would also like some idea of cost if possible.
We are lot shopping now and I am trying to figure out how to achieve all of my garage goals in keeping with the lot restrictions, building requirements, etc and this idea came to mind.
The top part would be for parking daily drivers. The "basement" would be storage. My dream plan is to use a porte co concept where I have a single garage separated from the house by the porte co which would be for the shop. We'll see.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Living area in a Garage? MAK General Garage Discussion 7 11-23-2011 09:28 AM
New Guys garage DaveL. Garage Gallery 26 06-06-2008 10:33 AM
My garage transformation begins - ongoing questions... Cebby General Garage Discussion 1 08-07-2005 10:31 AM
Garage remodel update... SANDOVAL Garage Gallery 5 07-21-2005 08:32 PM
My Garage plans... SANDOVAL General Garage Discussion 2 03-21-2005 08:44 AM
