Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 03-29-2010, 06:08 AM   #1
BioHazard
Default Stick built or pre-engineered 20x20 shed?
I'm thinking about building another 20x20 "shed", I like to keep my main shop as empty as possible besides what I'm working on, and I'm running out of room.
Whatever I build will probably have a concrete block footing, and a gravel floor. I've been looking at pre-engineered kits like this:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
$4500 isn't bad for a complete building delivered. I haven't really shopped around yet to see if anybody can beat that price.
But I wonder...if I did a simple stick build, same 20x20 and covered in the same tin walls/roof...is that going to be cheaper? Seems like the materials might be, but the plans, engineering, and trusses probably are a deal killer. Do you think I could do a stick built 20x20 for under $4500?
What would you do?
BioHazard is offline   Reply With Quote
Old 03-29-2010, 06:56 AM   #2
little d
Senior Member
Default Re: Stick built or pre-engineered 20x20 shed?
boi, draw up a rough sketch and take it around to the local lumber yards, they will break it down and give ya a price, might or might not beet the price.
little d is offline   Reply With Quote
Old 03-29-2010, 08:54 AM   #3
38Chevy454
Senior Member
38Chevy454's Avatar
I think you can beat that price if you build it yourself. Since it is a shed, you could go with pole barn style on 4ft centers. The 20 ft size makes it easy for using 4x8 sheets for the walls if you can live with 8 ft height. You can buy pre-made trusses for the roof.
__________________
If one has problems with their neighbors..........they did not buy enough land
My detached garage project:
http://www.garagejournal.com/forum/s...ad.php?t=66932
USA made high quality bear claw style latches - cheap:
http://www.hotrodlatches.com
38Chevy454 is offline   Reply With Quote
Old 03-29-2010, 10:30 PM   #4
BioHazard
Quote:
How much are we talkin' for a nearly no weight bearing truss with a 20' span?
Old 03-30-2010, 08:17 AM   #5
cj7jeep81
Senior Member
i had some 16' trusses built by a local place when i built my 16'x16' shed. i had the trusses on 2' spacing with a 5/12 pitch, and they were $33 each.
mine was stick built, and I think right around $2k to build (and that included an 8'x7' steel roll up door).
cj7jeep81 is offline   Reply With Quote
Old 03-31-2010, 01:26 PM   #6
rustycarr
Junior Member
i bought one of those cheap 20x20 sheds for $695 , they deliver and told them to just leave materials, bought some 2x2 and extended the height and roof angles to where i wanted and welded them up, (metal cost about 100) , built the forms my self and had a concrete truck come and finished it with my two brothers, slab was $450 for 6 yards, currently i am skinning the metal with 2x4s and just installed 4 windows ($250) and ive done all but the slab myself, had to build a scaffold but very cheap and sturdy too!! i will post pics soon..
rustycarr is offline   Reply With Quote
Old 03-31-2010, 01:43 PM   #7
dipper
Senior Member
dipper's Avatar
Send a message via AIM to dipper
Bio,
You could probably build that up pretty cheap. I wasn't busy at work today so I used my garage planner program and sent you a quick sketch. You should be able to look it over and use the materials list to get quotes from local lumber yards. My experience in my shop build was the price of the concrete. That was $$$, but if you get it on a block wall and don't worry about the floor right now, you should be able to get it up for well under 4500 assuming 2x4 construction, stick build the roof if trusses are alot of money, t1-11 siding etc etc. Hope this helps.
pm sent with info for you.
__________________
-Dipper
20x22 Build Pics: http://s630.beta.photobucket.com/use...e/1_Demolition
dipper is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
