Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 04-20-2010, 07:48 PM   #1
biscuit141
Senior Member
Default Are the older model Craftsman air compressors any good?
I have found a couple lately on CL and the specs seem to blow the newer Craftsman air compressors out of the water. Now before everyone tells me I need to buy a bigger unit, this is my first compressor and I am working with a $100-$125 budget. For the most part right now it will be for airing up tires and blowing off equipment, with occasional impact gun or air ratchet use.
Both compressors I found are older craftsman 20 gallon, oil-lubed units, both $125. one is a 4hp 220volt, the other is 3 hp 110 volt. the 3 hp is rated at 40/90 psi at 8.8/7.7 s.c.f.m (is this different than cfm?) and I saw it printed on the unit in a picture. the 4 hp is 11.2 cfm, according to the seller, no picture.
I know the HP is higher on these older models than the newer ones, does that also mean the cfm should be higher? did the older models typically put out more cfm than the newer ones do? Are these numbers even accurate?
The 3hp 110 model is about 30 min away from me, while the 4 hp unit is over an hour away. Any advice appreciated. BTW, I'm a new member hear and love reading about all the tools as I build my collection.
biscuit141 is offline   Reply With Quote
Old 04-20-2010, 08:13 PM   #2
Krusty
Default Re: Are the older model Craftsman air compressors any good?
Sears was sued a few years back specifically for being "creative" with their compressor ratings so you might take a grain of salt with those numbers.
Krusty
Krusty is offline   Reply With Quote
Old 04-20-2010, 08:25 PM   #3
Joe B.
Senior Member
Joe B.'s Avatar
Quote:
Krusty
Yeah, those older hp numbers can't be compared to current numbers. It seems as though this has resulted in some of those older models being overpriced. It was not just Sears that was full of BS, it was the whole industry.
Joe B. is offline   Reply With Quote
Old 04-20-2010, 08:26 PM   #4
Kev442
Senior Member
Kev442's Avatar
Are older Craftsman decent? Yes. Are these HP ratings total BS? Yes. Pay attention to the 90 PSI rating, everything else is a waste of time.
Kev442 is offline   Reply With Quote
Old 04-20-2010, 08:34 PM   #5
biscuit141
Senior Member
Quote:
The 3 hp model is what I am leaning towards since I am closer to it. It was rated at 7.7 at 90 psi, that still seems a little high to me for this size, but even if it is lower, it should still work for what i need right? Should 110 vs 220 matter to me as far as output is concerned?
Old 04-20-2010, 08:57 PM   #6
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
CFM and SCFM are used interchangeably. The SCFM stands for "standard" cubic feet per minute. Thats unpressurized, normal atmospheric pressure, cubic feet of air. When you compress air, you can pack lots of SCFM's in a rather small space. The higher the pressure, the more SCFM's will fit.
The one compressor you are describing, a 4 hp 20 gal, oil pump (aluminum, steel sleeves, mine was) is a decent compressor. Bought it used and I used it for several years till I bought a large stationary compressor. Gave it to the Animal Shelter to sell in their auction to raise money. I still have a small, even older Craftsman 12 gal 1 hp iron pump compressor that I keep because it is 120v and can "go anywhere" (yea right, its so darn heavy I have to roll it up ramps into the back of the truck).
Charles
Charles (in GA) is offline   Reply With Quote
Old 04-20-2010, 08:58 PM   #7
harvero
Senior Member
harvero's Avatar
I had purchased "Sears Best" horizontal portable compressor back in the early 80's. I used it to sand blast a 2 story masonry 2 family and I've painted many cars with it. I really gave it a work out last summer with my HF blast cabinet. It finally bought the farm this past Christmas running my die grinder when I was doing the ball joints on my blazer . Even thought the DeVilbiss air pump has a 50% duty cycle I ran compressor for weeks for hours straight.
I could have fixed this unit, but it needs a crank and a rod, the parts still can be ordered from sears, but run about $200.
harvero is offline   Reply With Quote
Old 04-20-2010, 09:39 PM   #8
Kev442
Senior Member
Kev442's Avatar
Quote:
There was a popular mechanics or some other magazine article that explained how the manufacturers took the HP ratings to the edge on these units. The 3hp and 7.7 @ 90 psi are actually pretty close on those models to reality. I personally recommend 220v as it seems the motor runs somewhat cooler in that configuration and it's much easier on the garage wiring. As for what it will run, everything up to a sander, then the catch up waiting starts. But as shown above, many of these were advertised as "paint pros", so they knew people were going to run them for an hour or more straight painting/grinding/sanding stuff.
Old 04-21-2010, 12:00 AM   #9
biscuit141
Senior Member
Can these be configured to run on either 110 or 220?
Now I'm worried its going to be crap and break like harvero's did. However I dont think I'll be using it quite as much as he did.
Is there a better compressor that fits what I need it to do for not much more money I should be looking at or for?
I attached photos of the compressors. the 3hp 110v is the first 2, 4hp 220v is the 3rd.
Old 04-21-2010, 12:58 AM   #10
lwlobo
Senior Member
lwlobo's Avatar
I'd say a consumer grade air compressor that lasts almost 30 years and finally breaks after some really heavy use doesn't qualify as crap!
I have a very similar, if not identical, Sears Best compressor to what harvero had, and it works great. I remember when my Dad got it in the Mid 80's. I snagged it when he finally got a new bigger upright about 7 years ago. I fixed some plumbing and replaced the pressure switch, and now it runs great. I'd prefer it over any newer noisy, oiless Craftsman or Husky or whatever.
Mine is set up 220V, I'd suggest going the same way.
lwlobo is offline   Reply With Quote
Old 04-21-2010, 01:14 AM   #11
Lhorn
Senior Member
Yeah I'd say a nearly 30 year old compressor used for hard work like sandblasting and for hours at a time owes you nothing. Using for lighter duty like impact guns, etc and it'd probably last a lot longer.
I got a used Sears compressor on CL a few years ago. It looks to be one of their bigger portable oil lubricated compressors and it's held up great.
Lhorn is offline   Reply With Quote
Old 04-21-2010, 08:39 AM   #12
biscuit141
Senior Member
the seller of the 4 hp unit emailed me another pictures this morning. I can see the plug in this pic better and it looks to be a normal 110 out outlet plug. Anyone used one of these before?
Old 04-21-2010, 09:06 AM   #13
GTO
Senior Member
GTO's Avatar
Krusty
It wasn't just Sears,there was a Class Action Suit settled against a number of compressor manufacturers for inflating(no pun intended) their HP ratings on compressors.
GTO is online now   Reply With Quote
Old 04-21-2010, 12:45 PM   #14
wineslob
Senior Member
wineslob's Avatar
It cannot be 3 or 4 HP on 110v.
Just for reference using motor name plates (numbers are approx for true HP):
1/2 hp 110 v should be 8 amps.
1 HP @ 110v would be 16 amps.
so you can see that you CANNOT run 3 or 4 HP on 110 v, ain't gonna happen.
Also a good "rule of thumb" for cfm: 3.5 cfm per HP, that is for a decent compressor and not counting the tank volume.
wineslob is offline   Reply With Quote
Old 04-21-2010, 12:55 PM   #15
Major Ramifications
Senior Member
Major Ramifications's Avatar
Either of these would be fine, they were both good units, probably made by Devilbiss. In your price range, you really can't be too picky. I would lean toward the 220V, but condition is important too. Also, can the 110V unit be configured to run on 220? Also, do you have 220?
Major Ramifications is offline   Reply With Quote
Old 04-21-2010, 01:30 PM   #16
Aberdale
Senior Member
Aberdale's Avatar
Either would be fine for the use you described. I have a 3hp 220v Craftsman that I bought new in 1981. It was my only compressor for 20 years. About that time, I got a pin hole in the tank from not draining it on a regular basis. I replaced it with a new oilless diaphram Craftsman compressor that only lasted about 6 months. I took the old compressor and motor and put it on the new tank. It's still compressing air, although it leaks a bit at the regulator. Although I now have a new 2 stage compressor in the shop, I keep the Craftsman in the garage to do the types of things that you will be doing. For the use I've gotten out of mine with little or no maintenance, I would say it's been a great compressor, and would much rather have an older piston compressor than any of the newer oilless ones.
Dale
Aberdale is offline   Reply With Quote
Old 04-21-2010, 01:54 PM   #17
biscuit141
Senior Member
Quote:
I do have 220 in the garage. I will probably go with the 3hp, it is closer and looks in a bit better condition.
Old 04-21-2010, 03:36 PM   #18
Kev442
Senior Member
Kev442's Avatar
They all look like the decent ones, so it's mostly the luck of the draw that it was not abused too badly. That's a pretty honkin motor on the 4 hp, no way that runs on 110. The others are probably rewirable between 110 and 220. Be prepared to put a pressure switch or a back valve on the one you buy, they are pretty crispy after 20-30 years.Good Luck!
Old 12-10-2010, 10:43 AM   #19
ihkrawler
Junior Member
ihkrawler's Avatar
Can anyone tell me the model of compressor shown in harveros pics? I have the same compressor that needs a couple small parts but cannot find a valid model # anywhere, making it difficult to find the appropriate parts.
ihkrawler is offline   Reply With Quote
Old 12-10-2010, 02:25 PM   #20
truckdriver
Senior Member
truckdriver's Avatar
Quote:
What kind of parts do you need? Usually the only thing to go bad is the check valve/unloader combo and that is a usually a CA 12 Load Genie and the pressure switch which you can use any switch with the correct rating.
truckdriver is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
