Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 04-24-2010, 09:23 AM   #1
peterp
Default Teflon tape on compressor hose connections?
I'm a first time compressor owner, so apologies for this "Compressor 101" question.
I bought a Makita compressor, Goodyear rubber 50 foot hose, and Craftsman Accessory Kit. I'm trying to use the blow gun, but air leaks on both ends of the hose (compressor side and air gun side) at the quick connects. I just tightened the hose connection way more than I thought necessary and most of the leak is gone, but it still leaks a little. Is it customary to put Teflon tape or something else on the fittings to eliminate leaks?
peterp is offline   Reply With Quote
Old 04-24-2010, 09:27 AM   #2
Joe B.
Senior Member
Joe B.'s Avatar
Default Re: Teflon tape on compressor hose connections?
Yes.
Joe B. is offline   Reply With Quote
Old 04-24-2010, 09:37 AM   #3
Scout Driver
Senior Member
Scout Driver's Avatar
Yes. Use teflon tape. Teflon paste is messy.
Scott
__________________
WTB: International Harvester tools. (the automotive mechanic's style tools made by Wright) Also looking for other IH items of interest.
Scout Driver is offline   Reply With Quote
Old 04-24-2010, 09:49 AM   #4
Zrexxer
Senior Member
Zrexxer's Avatar
As a general rule, any tapered pipe threads require some kind of sealant to be gas/liquid tight. Personally I like to use the yellow teflon tape made for natural gas use; it's heavier and seems to seal better although it's about 3x as expensive.
__________________
I find some people work harder trying to justify doing things wrong than it would have just taken to do them right to begin with...
Zrexxer is offline   Reply With Quote
Old 04-24-2010, 10:22 AM   #5
rodm1
Senior Member
leave 2 threads at end untaped it helps prevents the tap from getting into system and plunging up stuff.
rodm1 is offline   Reply With Quote
Old 04-24-2010, 11:36 AM   #6
kbs2244
Senior Member
I use the blue Locktight gasket cement.
kbs2244 is offline   Reply With Quote
Old 04-24-2010, 11:58 AM   #7
A29
Senior Member
A29's Avatar
Been known to use permatex #2 on pipe threads. Just a little does it
A29 is offline   Reply With Quote
Old 04-24-2010, 01:05 PM   #8
peterp
Thanks everyone for the feedback -- will use the tape. I had a hunch it was required, but didn't see anything the in compressor owners manual talking about it. I appreciate the help.
Old 04-24-2010, 01:32 PM   #9
rsanter
Senior Member
rsanter's Avatar
thin smear of silicone
bob
__________________
my wife says that I have never met a tool I havent liked. people on the other hand......
rsanter is online now   Reply With Quote
Old 04-24-2010, 04:29 PM   #10
xscorex
Senior Member
xscorex's Avatar
tape works best but ive used blue loctite, just make sure you let it dry good before using the hose or it will just blow it out
__________________
Knives, Bats, New Tats
xscorex is offline   Reply With Quote
Old 04-24-2010, 04:35 PM   #11
mjozefow
Senior Member
mjozefow's Avatar
Tape is fine if the heat doesn't get to the joint. I used Teflon tape on the compressor-to-tank line and it was great until I was running it hard (sandblasting) and now it hisses. Guess what I'm doing tonight?
__________________
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
Lots of Vise Info
Vise restoration Tips
The Vises of GJ! (dial-up death)
A_Pmech makes replacement jaws, ask him!
My Website:
www.mitchscustomcarpentry.com
mjozefow is offline   Reply With Quote
Old 04-25-2010, 02:13 AM   #12
ehauptma
Junior Member
Home Depot sells a yellow teflon tape that is a bit thicker and more heavy duty (and a bit more expensive) than the cheap white stuff they and others sell. It is in the area around the black piping. After I changed to the yellow stuff from the cheap white stuff all my leaks in the compressor system went away.
Eric
ehauptma is offline   Reply With Quote
Old 04-25-2010, 04:02 AM   #13
DanCo
Senior Member
DanCo's Avatar
Location: In a house, on a block, somewhere in Queens New York
Send a message via AIM to DanCo Send a message via Yahoo to DanCo
I've always used the white tape, but after reading this thread I'm gonna switch up to the yellow. I've seen it at Home Depot, its like $3 a roll. I usually retape all my air tools every 6 months anyway. Great Suggestion Guys!!!
__________________
Quote:
Originally Posted by Muffduster View Post
Get rid of that damn signature!!!!!!!!!
Looking for Snap On Pearl Handled Screwdrivers, PM me if you want to sell
DanCo's For Sale Items
DanCo is offline   Reply With Quote
Old 04-25-2010, 04:12 AM   #14
socketjockey
Senior Member
Air line hiss is like music why eliminate it? It gives a shop ambiance.
socketjockey is offline   Reply With Quote
Old 04-25-2010, 09:33 AM   #15
TheGrooveking
Senior Member
TheGrooveking's Avatar
Remember to wrap the teflon tape in the direction of the threads, meaning wrap in the direction the fitting tightens, otherwise you'll unwrap the teflon tape as you tighten the fittings together.
TheGrooveking
TheGrooveking is offline   Reply With Quote
Old 04-25-2010, 09:59 AM   #16
NUTTSGT
NUTTSGT's Avatar
I use tape occassionaly, when I don't, I use liquid thread sealer, like ARP.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 04-25-2010, 10:08 AM   #17
steamfitter
Junior Member
teflon tape or pipe dope is mainly a lubricant to help you get the joint tight enough the threads themselves make the seal. you can use the regular teflon tape for any application as long as you stay a thread back. only use tape on pvc threads never dope or paste.
steamfitter is offline   Reply With Quote
Old 04-25-2010, 07:37 PM   #18
peterp
Thanks for the tips on application (thread back and wrapping in direction of tightening). I did it this morning and all the leaks are gone. I picked up the Craftsman 50 foot manual hose reel. It comes with a PVC hose, which is junk, but after replacing it with the Goodyear rubber hose it works great. It took some time to take the PVC hose out and to put everything back together with Teflon tape, but everything works great now so I'm very happy with the setup. It's really great to have a compressor, should have done it many years ago.
Old 04-25-2010, 07:43 PM   #19
mrb
Senior Member
mrb's Avatar
i prefer rectorseal 5
mrb is offline   Reply With Quote
Old 04-25-2010, 08:10 PM   #20
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
Quote:
I gave up on tape on PVC a long time ago. Tried everything to make IP thread on PVC seal up with tape, nothing worked. Tried a couple of wraps, tried more, tighter, everything. Gave up. Couple of friends said they had the same experience and found dope to work. Since then I use pipe dope and usually don't have any problems.
Charles
Charles (in GA) is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
