Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 04-29-2010, 02:34 PM   #1
SocketDeviler
Senior Member
SocketDeviler's Avatar
Default When should you replace a grinding wheel?
I have little experience in this area. I have a used 5" wheel that is now 4-1/2". I don't have a grinder but plan on getting one in the future. It looks like a good wheel. Other than obvious damage at what point should a wheel be replaced?
SocketDeviler is offline   Reply With Quote
Old 04-29-2010, 02:44 PM   #2
arkangel06
Send a message via MSN to arkangel06
Default Re: When should you replace a grinding wheel?
When you cant grind with it anymore because the the metal disc that holds it on keeps hitting the material (basicaly when its about 1.5'' in dia
Or when its chipped or cracked.
arkangel06 is offline   Reply With Quote
Old 04-29-2010, 03:10 PM   #3
SocketDeviler
Senior Member
Nice. Good to know. I figured the wheel still had some miles on it but just wanted to make sure. Thanks!
Old 04-29-2010, 03:11 PM   #4
arkangel06
Quote:
No problem Thats what we are here for
Old 04-29-2010, 05:09 PM   #5
TheGrooveking
Senior Member
TheGrooveking's Avatar
Your cutting/grinding effeciency goes down as the diameter reduces. The SFM (surface feet per minute is greater the further you go out form the rotating axis. So grinding something with a 2" wheel will be only 40% as fast as a 5" diameter wheel.
TheGrooveking
TheGrooveking is offline   Reply With Quote
Old 04-29-2010, 08:11 PM   #6
SocketDeviler
Senior Member
Good info. Thanks, TheGrooveking.
Old 04-29-2010, 08:22 PM   #7
mkdive
Senior Member
mkdive's Avatar
Trick I learned and have used for the last few years.....
Before I install a new bench top grinder wheel (new, used or just changing back from one off my shelf) I will to the "ring test". I take two screwdrivers, the first driver I hold the wheel with the driver through the grinder wheel hole. With the other screwdriver I tap the wheel....you should hear a clear somewhat high pitched ring. If it sounds like a thud it has a crack....sometimes the cracks are not easily seen. I guess I'm just a little cautious when it comes to things turning at such high RPMs near my hands & body!!
__________________
"Hammer to shape, Grind or File to fit, Paint to match!"
Posted by Fedwrench
"As a tool whore, it is my duty to have wrenches for every possible occasion".
Posted by TAMPAGT07
"I like my ratchets how I like my women, the more teeth the better".
Posted by stricht8
"When life is over as we know it there will be cockroaches eating Twinkies using craftsman RHFT ratchets."
mkdive is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
