Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 05-12-2010, 01:00 AM   #1
StinkBug
Default Copper pipe for compressor lines.
Gettin ready to plumb the new shop for air, and wanna do it right the first time. Went to check prices on copper pipe, and didn't realize that there were 2 different types. Lowes had type M and Type L. Only difference I could tell was wall thickness. Question is, will the thinner stuff be ok for running compressed air lines? Any other suggestions?
__________________
Dallas Ashley
Crew Chief, RedBull Rockcrawling Team
StinkyFab Racing Custom Fabrication
StinkBug is offline   Reply With Quote
Old 05-12-2010, 04:50 AM   #2
rodm1
Senior Member
Default Re: Copper pipe for compressor lines.
Quote:
NO!
rodm1 is offline   Reply With Quote
Old 05-12-2010, 04:54 AM   #3
35mastr
Senior Member
35mastr's Avatar
I prefer the thicker stuff.
__________________
If I could only remember what I have already forgotton.
Mac tools For Sale Here
George
35mastr is offline   Reply With Quote
Old 05-12-2010, 05:12 AM   #4
bosskong
I can't see any reason why the thinner type M pipe wouldn't work fine and I've heard of plenty of people using it for compressed air. According to Lowes, the 1/2" Type M copper pipe that they sell is rated to 850 psi.
I'll agree that bigger is usually better and if money were no object, I'd get the thicker stuff. But money is tight atm, so I'm about to install type M piping in my garage unless I hear of a good reason not to. Has anyone actually had a failure while using compressed air in type M copper piping or are you all just being anal?
bosskong is offline   Reply With Quote
Old 05-12-2010, 06:25 AM   #5
GeorgiaHybrid
Senior Member
GeorgiaHybrid's Avatar
The 850 psi rating is for static liquid pressure, not compressed air pressure. When you heat copper pipe to solder it, the pipe properties will change (you are annealing it) and it will become softer and the pressure values will change.
Having said that, I used type "L" when I ran my lines but if you use type "M", the worse thing that will happen is the pipe will split. Unlike other line types (the white stuff), the line will not shatter and send out shards of metal. I prefer the thicker material as my compressor is on 24/7 (which is why I plumbed the shop....) and I did not want to have a failure in a line that would cause the compressor to run for 24 to 48 hours without me knowing about it.
GeorgiaHybrid is offline   Reply With Quote
Old 05-12-2010, 06:31 AM   #6
Wingnut65
Senior Member
Wingnut65's Avatar
I just researched that yesterday and found info at copper.org. Go with Type L!
Here is a link to their online 'Copper Tube Handbook' for identification of copper tube. Clikc on the "(See Table 1)" blue link and a table will pop up with info on approved applications. They do not list Compressed Air for Type M copper, only Type L and Type K. http://www.copper.org/applications/p...1stand_id.html
If I use copper, I am going to follow their recommendation.
Wingnut65 is offline   Reply With Quote
Old 05-12-2010, 09:00 AM   #7
spongerich
Senior Member
spongerich's Avatar
Just use PVC. What's the worst that could happen?
__________________
Tool Junkie
Check out my YouTube Channel for machine shop videos.
See my eBay listings here.
spongerich is offline   Reply With Quote
Old 05-12-2010, 09:11 AM   #8
1969
Senior Member
1969's Avatar
Devilbiss recommends black iron over copper. My shop is plumbed with black iron, the new stuff, plastic or aluminum with the special fittings looks easier to install, no threading or sweating of joints. More $$$$$$ though.
1969 is offline   Reply With Quote
Old 05-12-2010, 09:23 AM   #9
rburke65
Senior Member
rburke65's Avatar
PVC is good enough......kidding of course. This topic has been covered to death and back.
rburke65 is offline   Reply With Quote
Old 05-12-2010, 10:49 AM   #10
sirsloop
Senior Member
sirsloop's Avatar
use garden hose
sirsloop is offline   Reply With Quote
Old 05-12-2010, 03:07 PM   #11
Steve in Mi
Senior Member
Steve in Mi's Avatar
The tables indicate all 3 will handle the pressure however the thicker wall may offer an added measure of protection from physical abuse.
__________________
Work safe, have fun, enjoy the sport.
Remember that a guy never has to come down out of the clouds if he keeps filling the valleys with peaks. Steve
Steve in Mi is offline   Reply With Quote
Old 05-12-2010, 03:48 PM   #12
StingRay
Senior Member
Type M is fine. I have worked in many shops with plain old M. There has never been a pipe blow out. We've had regular solder joints get yanked off from abuse though. I'm talking 75,000 square foot shops that have been in operation for 20 years. Now if you are going to run 175 PSI or larger diameters than 3/4" then L would be appropriate. Use a silver bearing solder and away you go. Like said if it did let go then all it would do is split and you'd have a helluva noise. You will not get a brittle fracture with schrapnel like you would with some plastics. If you get a bargain on L go for it otherwise it's a waste of money. I'm about a anal as you get when it comes to safety and doing it right and am a Mech Eng Tech by profession. I researched all of this and yes I consulted the copper handbook. I plumbed my shop in M and I'm not losing any sleep.
StingRay is offline   Reply With Quote
Old 05-12-2010, 05:52 PM   #13
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
Go to the Copper Tube Handbook, by the Copper Development Association.
http://www.copper.org/publications/p...e_handbook.pdf
Page 9, lower RH corner will tell you to use either K, L, or M pipe for compressed air, depending on pressures.
Pages 25 and 26 will have charts of L and M pipe in various sizes and pressure ratings at various temps for both drawn and annealed condition.
The table on page 28 will show you that it is probably unsafe (due to pressure ratings of the joints) to solder with 50/50 Tin-Lead solder and that you should use 95/5 Tin-Antimony solder.
LOOK AGAIN!
Select the "select the right tube for the job" link
http://www.copper.org/applications/p...ect_recom.html
Then scroll to the bottom. Blue links there take you to the same tables I reference above in the complete handbook, pages 25 and 26.
Charles
Charles (in GA) is offline   Reply With Quote
Old 05-12-2010, 08:55 PM   #14
trbomax
Senior Member
trbomax's Avatar
When I built my shop in ohio in 1973 I used "M" and 50/50 solder.I put all the lines in the walls.Never had a leak or failure,its still working now because my son is there useing it.
trbomax is offline   Reply With Quote
Old 05-12-2010, 10:04 PM   #15
Wingnut65
Senior Member
Wingnut65's Avatar
Thanks Charles for the info on the copper selection table. When I first found that table, it was in Greek. Now, after research, I understand the difference in the Annealed VS Drawn pressure calcs. Looks like Type L or Type M would work for small DIY sized compressors.
jeff
Old 05-12-2010, 10:43 PM   #16
Grumpy365
Senior Member
I am using ACR for my air lines. Go to your local refrigeration supply company for a price. Also refrigeration supply houses carry 20' sticks.
__________________
I like whiskey. I always did, and that is why I never drink it.
Robert E. Lee
Grumpy365 is offline   Reply With Quote
Old 05-12-2010, 11:10 PM   #17
Joe B.
Senior Member
Joe B.'s Avatar
I just use those cardboard tubes that come wrapped around wrapping paper.
Joe B. is offline   Reply With Quote
Old 05-13-2010, 07:39 AM   #18
nehog
Senior Member
nehog's Avatar
Quote:
Originally Posted by sirsloop View Post
use garden hose
Years ago I used air-hose when I had no money but a few extra hoses. Lasted about 10 years before I ripped it out. Most of it was still 'good' when it came out, a couple of spots were swelled a bit.
Uh, no I'm not recommending that as a solution!
__________________
My name is Peter, and I'm never going to grow up.
30 x 60, oops, 30 x 72 (it got larger!) with a Rotary 10K lift.
Volvo S80
Holiday Rambler Ambassador 40 DFD
Mercedes Benz Sprinter RV
Saab Turbo Convertible
VW Cabriolet
nehog is offline   Reply With Quote
Old 02-11-2017, 04:48 AM   #19
NewShockerGuy
Senior Member
NewShockerGuy's Avatar
Arrow Re: Copper pipe for compressor lines.
LOOK AGAIN!
Charles
EXCELLENT information.
I'm glad I found this so that I wouldn't buy/do the incorrect things! Now to price stuff out!
-Nigel
__________________
________
-....-> ~ NSG ~ <-....-
NewShockerGuy is offline   Reply With Quote
Old 02-11-2017, 04:56 AM   #20
bixxjs
Senior Member
bixxjs's Avatar
Why use copper pipe? I work in a heavy industrial environment and we use plastic pipe and pushfit fittings.Fabrication is easy as you only need a simple alligator type cutter for the pipe and various bends,adaptors and fittings are available.
If you need to move the pipe work it's just a matter of isolating the air and simply pulling the pipes/fittings apart.
bixxjs is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
