Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 05-18-2010, 07:16 PM   #1
Jim Sideways
Junior Member
Jim Sideways's Avatar
Default Building a car body Dolly
Ok Guys, I'm building a dolly for the body of my car for when I'm working on it.
My question is will 4x4's hold up running about 10' by 5' with about 18"s of up right with 6" casters to roll it with. I'm going to run 2x4's for extra support on the bottom from leg to leg with 2x4's running at 45's also. I have no idea how much the body weighs, I just want it to be safe and stable. I put a picture so maybe you can see whats going on it.....Thanks for the help!!! Jim
Jim Sideways is offline   Reply With Quote
Old 05-18-2010, 09:49 PM   #2
whowutwut
Junior Member
Default Re: Building a car body Dolly
Hi Jim,
I built one and posted pics on this thread:
http://www.garagejournal.com/forum/s...ad.php?t=25170
Make sure to go with solid casters, easy to roll around.
Victor
whowutwut is offline   Reply With Quote
Old 05-19-2010, 03:05 AM   #3
RAYJAY
Senior Member
RAYJAY's Avatar
mine are on this post ...
http://www.garagejournal.com/forum/s...ad.php?t=24529
__________________
Quote:
A bolt doesn't care where the wrench was made.
Quote:
Thank You Snap On, I now know how it feels to be toilet paper
Quote:
People complain that "Craftsman warranty depends on who you talk to at the store"....
"SNAP-ON warranty depends on your dealer - at 10x the cost."
Quote:
Originally Posted by TAMPAGT07 View Post
Your SHO has a PP?
RAYJAY is offline   Reply With Quote
Old 05-19-2010, 03:15 PM   #4
Jim Sideways
Junior Member
Thanks guys. I plan to roll the body out in the back yard. I was going to use the 6" northern tools casters. They are rated at 250lbs each. In your post you said they were junk what about putting tubes in them?
Old 05-19-2010, 04:10 PM   #5
whowutwut
Junior Member
Oh I'm not sure what you should use if you're rolling it into the backyard, maybe pneumatic ones are the way to go... I rolled mine around in the garage and onto the driveway and found that with the pneumatic casters, there's alot of bounce to the car dolly and it felt sluggish when rolling around... basically becasue it's on air. Plus one of the casters had a flat after a few weeks, just sitting there.. At that point i replaced them with solid casters.
Old 05-19-2010, 11:42 PM   #6
LIVELY
Senior Member
LIVELY's Avatar
4 x 4 [wood]framework will hold the body fine-----if your rolling on the grass and rocks you need rubber tires[you can get foam filled wheelbarrow tires for the dolly if you do not like flats] i have one framework with metal frames and one with 4 x4 [wood] framework
it usually takes two buddies to roll around the grass
LIVELY is offline   Reply With Quote
Old 05-20-2010, 08:53 AM   #7
Jim Sideways
Junior Member
Thanks for the help guys.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
