Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 05-21-2010, 01:40 PM   #1
sk8louisville
Junior Member
Default Proper way to attach a vise to a drill press?
This may be a dumb question, but here goes:
What's the proper way to attach a vice to a drill press table? I scored a tabletop drill similar to this one from a college votech shop
and I picked up a vice similar to this one.
But I'm 2nd guessing how to attach it properly. I can bolt it down, but I have to offset my table in order to get the center of the vice on center with my drill bit.
Is this normal?
(if you can't tell, this is my first press/vice combo)
Cheers!
Mike
sk8louisville is offline   Reply With Quote
Old 05-21-2010, 02:08 PM   #2
Mickey O
Senior Member
Mickey O's Avatar
Default Re: Proper way to attach a vice to a drill press?
I can't recall ever bolting down a vise on a drill press table, clamps or nothing but make sure what ever is in the vice, if large, is up against the column (or clamp), watched a guys belly get torn open, wasn't pretty.
__________________
Cheap tools are for chumps.
...the wealthy can currently “accumulate many millions of dollars in these accounts, substantially more than is needed to fund reasonable levels of retirement saving.”
Mickey O is offline   Reply With Quote
Old 05-21-2010, 02:23 PM   #3
larry_g
Senior Member
Typically the vise is bolted with a bolt and t-nut under the table. But like Mickey said the vise is not typically bolted down unless you are doing some production work where you want repeatable position in many parts. A c-clamp may be used or a regular bolt through the table to provide a bump stop to keep the vise from spinning if the torque on the vise is more than the operator can hold. No one way to do this, each setup requires its own solution.
lg
no neat sig line
larry_g is offline   Reply With Quote
Old 05-21-2010, 02:46 PM   #4
Packard V8
Senior Member
A true drill press vise will have a center bolt with a shoulder which matches the hole in the center of the table. Often, this bolt is on a rotary table, with the vise bolted to it. The vise is removable if some specialized setup requires an off-center vise mounting without using the rotary table.
thnx, jack vines
Packard V8 is offline   Reply With Quote
Old 05-21-2010, 02:51 PM   #5
sk8louisville
Junior Member
C-clamp it is!
Thanks guys.
Old 05-21-2010, 03:04 PM   #6
jpilgrim
Senior Member
jpilgrim's Avatar
I use a 1/2-13 bolt&nut and some washers. The 1/2 is overkill as far as strength, but it fits the slots in the vise nicely and that makes for faster setup.
jpilgrim is offline   Reply With Quote
Old 05-21-2010, 03:07 PM   #7
rsanter
Senior Member
rsanter's Avatar
bolt it to the table
you see the slots on the side of the vise, those are for adjustment.
you can also offset or rotate the table for added adjustment
I have seen a bit grab and spin the object and the drill press vise because it was not bolted down. now you have a bigger chunk of metal flopping around that can really hurt you or the machine
bob
__________________
my wife says that I have never met a tool I havent liked. people on the other hand......
rsanter is offline   Reply With Quote
Old 05-21-2010, 03:10 PM   #8
bobadame
Senior Member
I don't usually bother to clamp it (Jed). Just turn it so that the long end of the vice rests against the column to resist the torque.
bobadame is offline   Reply With Quote
Old 05-21-2010, 03:35 PM   #9
A_Pmech
A_Pmech's Avatar
Many times when using a drill press vise, it is useful to allow the drill to find the center of the pilot hole or center punch prick. Bolting or clamping the vise to the table makes this impossible.
Instead, consider installing a bolt and nut with a number of washers though the left side slot on the table. Run your vise up against this "stop" when drilling and hold it there. Doing so will prevent the vise from spinning should the drill grab, yet allow the vise to "float" on the table.
__________________
Your Finest Hammer
Building The Paulding Racer - My Blog
My Garage Machine Shop
Quote:
Originally Posted by Sir Stanley Hooker
One stroke to produce power and three strokes to wear it out.
A_Pmech is offline   Reply With Quote
Old 05-21-2010, 03:42 PM   #10
lilredex
Senior Member
Use two setups on my DP. First vise slides on a track, second can be clamped or can swing against a bolt in the table.
Second vise is a kid's shop project (from across the street) that his old man tossed out after he moved, I added the angle brackets. Guess he didn't realize what a good project it really was.
lilredex is offline   Reply With Quote
Old 05-21-2010, 03:46 PM   #11
lametec
Senior Member
lametec's Avatar
I use one of these to clamp the vise down.
lametec is offline   Reply With Quote
Old 05-21-2010, 03:54 PM   #12
MotoDave
Senior Member
MotoDave's Avatar
Send a message via AIM to MotoDave
Our machine shop in college had these vises attached to the drill presses:
http://www.heinrichco.com/sdvise.htm
They hold onto the part and keep it flat against the table, but won't let it grab and spin out of your grip. I really wish there were a less expensive version, I'd love to have one for my home shop.
MotoDave is offline   Reply With Quote
Old 05-21-2010, 04:04 PM   #13
A_Pmech
A_Pmech's Avatar
Ooooooooo! I like that!
They're also kind enough to provide a dimensioned drawing:
http://www.heinrichco.com/critdim/critdim13-WH.htm
Looks like a shop project in the making.
__________________
Your Finest Hammer
Old 05-21-2010, 04:08 PM   #14
Mickey O
Senior Member
Mickey O's Avatar
We got something similar to that after the idiot tore open his stomach, wouldn't have helped in his case (hole saw and sheet metal) but they got one just the same.
__________________
Old 05-21-2010, 04:25 PM   #15
larry4406
Senior Member
I like lilredex's vise on the slide table.
larry4406 is offline   Reply With Quote
Old 05-21-2010, 05:27 PM   #16
MotoDave
Senior Member
MotoDave's Avatar
I've been tempted to draw one up and have it made, maybe I should get off my butt and do it
Old 05-21-2010, 07:18 PM   #17
Shadowdog500
Senior Member
I use several drill press clamps to hold down work and sometimes a vise. If I have something on the press that I can't clamp down I position the work so that a part that sticks out is up agains the left side of the pole. That way if the bit fetches up it wont spin the work around and hurt you since it is already against the pole.
Here is a photo of a drill press clamp.
Chris
Shadowdog500 is offline   Reply With Quote
Old 05-21-2010, 07:52 PM   #18
s_ontario
Senior Member
s_ontario's Avatar
you need a bigger vise
or bolt that vise with counter sunk bolts to a 1/4" piece of plate then bolt plate to your table
if you don't bolt what material your drilling to your press table please count your fingers before and after take pictures
s_ontario is offline   Reply With Quote
Old 05-21-2010, 08:56 PM   #19
Keep
Senior Member
Keep's Avatar
I took some 3/8 bolts and welded on some large (2 inch) 1/4 thick washers. I use those to hold the vise down. My vise has the "teeth" on the side so the washers allow for greater clamping.
I just use wing nuts on the bottom to make things a little faster.
Keep is offline   Reply With Quote
Old 05-22-2010, 07:02 AM   #20
larry4406
Senior Member
The problem with the drill press vises that I have seen are that the one jaw is fixed while the other adjusts. Unless you only drill the same size stock, the bit center and stock center change. Do they make a vise where both jaws adjust so you can always center or intentionally offset the stock?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
