Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 05-31-2010, 01:02 AM   #1
WVBrady
Senior Member
Default How to connect electronic ballast
I am planning on replacing my old ballasts with some new electronic ballasts. On the new ballast there are only three wires coming out of the secondary side: two blue wires and one red wire. The old ballast has six wires coming out: two blue, two red, and two yellow. The two blue wires go to a socket and the two red to another socket at the same end of the fixture. The two yellow go to a socket at the other end of the fixture and there are two black wires that go from that socket to the other socket at that end of the fixture.
I think that I should splice one of the blue wires to the two existing blue wires, splice the red to the two existing red wires, and the other blue wire to the two existing yellow wires. This seems to be the easiest way to do it; I am just wanting some confirmation.
TIA,
Brady
WVBrady is online now   Reply With Quote
Old 05-31-2010, 03:19 AM   #2
Torque1st
Senior Member
Torque1st's Avatar
Default Re: How to connect electronic ballast
Quote:
Originally Posted by WVBrady View Post
Hook it up just like the picture on the ballast shows. It looks fairly straight forward.
One blue wire from the ballast hooks to both blue wires.
The other blue wire from the ballast hooks to both the red wires.
The red wire from the ballast hooks to both of the yellow wires.
__________________
Faster, Better, Cheaper: Pick Two
The FairTax
Follow the Money. -72chevy
Yes, I am insensitive and yes, not politically correct, and yes, Im sure I offended someone,... -Busted_Knuckles (Me too, plus I am old, tired, and grumpy!)
Read "The Marching Morons" Here
"Works" <> Safe, Good, or Right
"You can't fix stupid." -Ron White
Torque1st is offline   Reply With Quote
Old 05-31-2010, 08:30 PM   #3
Mr_fixit
Senior Member
Mr_fixit's Avatar
And when it's wired correctly don't forget to use new t-8 bulbs. The old t-12's won't work.
Mr_fixit is offline   Reply With Quote
Old 05-31-2010, 09:15 PM   #4
WVBrady
Senior Member
Torque: That does seem more in line with the diagram. I just wanted to make sure that there wasn't something that I was overlooking.
Thanks for the responses!
Brady
Old 05-31-2010, 10:01 PM   #5
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
The end caps are simply snapped into that fixture. Remove the end plates by using a screwdriver in the right place to disengage the lock tab, and after they are removed, pull out one of the bulb holders and go to Home Depot or Lowes and buy four new ones. They are cheap. Your old one will require that you push a tiny screwdriver in to release the old wires, you will find the wire contacts are possibly burned, the bulb contacts are probably burned, and most likely, you will break one of the bulb holders putting in a new bulb.
Put in new bulb holders and push the stripped wire ends in them and you will have better luck with everything working when you are done. If you need additional wire for jumpers, just cut some off the old ballast.
I installed one new electronic ballast in the place of two magnetic ballast in each of two four bulb fixtures in my kitchen. I ended up replacing virtually all of the bulb holders before I was done, and I used wire off the old ballast to make the jumpers needed to connect the terminals of the bulb holders on one end.
Charles
Charles (in GA) is offline   Reply With Quote
Old 05-31-2010, 11:36 PM   #6
Aceman
Senior Member
Quote:
Originally Posted by Charles (in GA) View Post
bulb holders
We call them tombstones around here.
Our shop does a lot of lighting retrofits, we don't replace the tombstones unless they are visibly damaged or break when inserting the new lamps. If you have a lot of ballasts to change, Wagos are the way to go.
Aceman is offline   Reply With Quote
Old 06-01-2010, 01:09 AM   #7
Torque1st
Senior Member
Torque1st's Avatar
I don't replace the holders either unless they are damaged or burnt etc. Fighting with the cheap sheet metal parts just ends up with more bent parts than it is worth. Nothing seems to come apart and fit quite like it is "supposed" to.
The new electronic ballasts don't seem to have a filament heater circuit. With the old style magnetic ballasts and bulbs it always seemed that it was the filaments in the bulbs that burned out.
__________________
The FairTax
Old 06-02-2010, 11:37 PM   #8
WVBrady
Senior Member
Thanks for all of the replies. I replaced two of the ballasts with no problems.
I used: F32T8 - (1-2 Lamps) - 120 Volt - Normal Light Output Ballast - GE-232-120-N - GE 23671
My "tomestones" were in good condition, so I just spliced the wires. The only problem I had was that I dropped one of the biodegradable plastic lenses and it broke into three pieces. I used some Goop and glued it back together. I doubt that I will ever find a replacement, so I put it in the corner.
Brady
Old 06-03-2010, 12:52 AM   #9
Norcal
Senior Member
Brady
That wraparound fixture is a Lithonia LB series ( Homevue is their homeowner line) Homedepot has replacement diffusers in stock....
Norcal is offline   Reply With Quote
Old 10-27-2011, 06:05 PM   #10
Maxalan
Junior Member
My first post here. The two remaining black and white wires fm the ballast.
Do I splice them into the two double wires that come fm the ceiling?
Thanks,
Max
Maxalan is offline   Reply With Quote
Old 10-27-2011, 10:39 PM   #11
rburke65
Senior Member
rburke65's Avatar
The black and white wires " coming from the ceiling" should be feeding the old ballast and are the 120 volt feed. You have to refeed the the new ballast! Black to black and white to white. You might want to purchase a Basic Wiring book at the big box store.
rburke65 is offline   Reply With Quote
Old 10-27-2011, 11:26 PM   #12
dittle fart around
Senior Member
dittle fart around's Avatar
Ballast are in parallel with the bulbs. For a two bulb fixture your probably have two blues and one red. The blues feed one end of the fixture and the red is for the other end. On the blue end, each tombstone gets a blue wire.Two wires out of the tombstone and one blue for each bulb, wire nutted together. The other end of the fixture is a return path back to the ballast. Four wires out of the two tombstones wire nutted to the one red wire. The black and white wires are for power. Black is hot and white is the return.
Finally 4 years of electrical apprenticeship and 25 years on the job have paid off.
__________________
Yep I'm the NewAge Garage Cabinet distributor.
<a href=http://www.garagejournal.com/forum/picture.php?albumid=1347&pictureid=41691 target=_blank>http://www.garagejournal.com/forum/p...ictureid=41691</a>
dittle fart around is offline   Reply With Quote
Old 10-29-2011, 11:59 AM   #13
DoyleDee
Senior Member
If you did want to remove the wires from the tombstones, I have had luck with just pulling slightly and "twisting the wire like I'm unscrewing it".. (hope that made sense)
I work on commercial lighting and equipment.. 15 years ago I did my first ballast.
DoyleDee is offline   Reply With Quote
Old 10-30-2011, 01:08 AM   #14
Greatbear
Senior Member
Greatbear's Avatar
I reballasted all the fixtures in my garage several years back with T8 electronics. The fixtures are all industrial channel mount with porcelain reflectors and pressure holders (not twist-lock tombstones). Rather than disassemble each fixture I cut the wires back to pigtails at the holders then used wire nuts to connect all the wires of a particular color together, effectively wiring the fixtures per the diagrams. Took a lot less time, especially when dealing with 26 fixtures.
Greatbear is offline   Reply With Quote
Old 10-30-2011, 05:38 AM   #15
fireguy
Senior Member
There may be rebates if you are changing old tubes and ballasts, or the whole fixture. You have to use "approved" lamps and ballasts. I know in BPA land there is a rebate program. I am looking to upgrade the lights in my rented shop.
fireguy is offline   Reply With Quote
Old 10-30-2011, 04:08 PM   #16
tfi racing
Senior Member
tfi racing's Avatar
Your method works fine 8 out of 10 times,the sure way is to strip a small length of wire,push it in beside the wire already in the socket to push the "clip" back slightly to release the old wire you would like to remove.Once you have the feel for it,you can just use the new ballast leads to release the unwanted conductors.
tfi racing is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
