Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 06-02-2010, 06:48 AM   #1
diogenes
Senior Member
diogenes's Avatar
Default Can a homeowner recharge a window AC unit?
Honest, I did search for a post about this with no luck. So here is my question:
I've got a window unit that isn't all that old and which is not performing like it used to. I've added coolant to an automotive AC system before, but I've never even pulled the case off a window AC unit to see what is in there for connections, etc.
Can a DIYer recharge a window unit economically? If so, what would I need to have to do it?
__________________
Just my opinion, of course. I've been accused of being an opinionated ass, and with some justification, in the past.
_
"An army of words escorting a corporal of thought"
--Ambrose Bierce
_
They who would enslave you will do so with the best of intentions.
diogenes is offline   Reply With Quote
Old 06-02-2010, 08:05 AM   #2
FANTASY FACTORY
Default Re: Can a homeowner recharge a window AC unit?
A typical window unit does NOT have service valves, you will have to istall a pinch valve.
and be very judicious with the can. window units are very sensitive to critical charge.
Not impossible, but impractical.
PS, make sure the cond, and evap are CLEAN and the cap bulb is in contact with evap coil,
FANTASY FACTORY is offline   Reply With Quote
Old 06-02-2010, 08:29 AM   #3
IndyGarage
Senior Member
Yeah most window units are sealed, so if it's low on charge, then it's got a leak and refilling it would be a waste of time.
It's more likely just dirty or something else is wrong. check how clean the coils are - you can clean them with a vacuum cleaner or a hose if you're careful about not getting the electronics wet. Sometimes the compressors overheat and shut down, and sometimes the thermal switches on them go bad.
You are not supposed to work on AC units unless you are licensed, and have the proper equipment. Of course getting an EPA 608 license isn't all that hard.
IndyGarage is offline   Reply With Quote
Old 06-02-2010, 09:54 AM   #4
Falcon67
Senior Member
Falcon67's Avatar
X3 - not really economical. They are basically use and toss units. The problem now is that you can't toss the damn things, they have to be evac'ed and tagged and such or the scrap yards won't touch 'em.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is offline   Reply With Quote
Old 06-02-2010, 03:53 PM   #5
diogenes
Senior Member
diogenes's Avatar
Thanks for the replies, guys. I'll pull it out and see what I can find along the cleaning lines. If I can't get it running better, I'll have to see if I can't get a new one on sale somewhere.
__________________
_
--Ambrose Bierce
_
Old 06-02-2010, 04:53 PM   #6
Gary S
Senior Member
Quote:
I agree. They aren't worth fixing. If the unit has leaked some freon, putting in more just buys you a very short time and it will be low again. New 5k btu window units are available under $100. New 10K units are available under $200. How much messing around is it worth to you?
Gary S is offline   Reply With Quote
Old 06-02-2010, 11:01 PM   #7
lsrx101
Senior Member
Double Post.
lsrx101 is offline   Reply With Quote
Old 06-02-2010, 11:04 PM   #8
lsrx101
Senior Member
Like others have said, if the refrigerant has leaked, toss it. Most often, though, the coils are dirty causing poor heat transfer and poor performance. If the compressor runs and you can hear it load down in the first few seconds of running, that is the likely problem.
I usually just remove the cover, or pull the unit from the case, and blast coils with a garden hose then blow it dry with compressed air. I then let it sit for a day or so to dry the electrical. If it is an electronically controlled unit, you obviously need to prevent soaking the electronics, but water generally won't hurt them as long as you let it dry thoroughly.
If you do have to replace it, be very wary of the cheap units. They cool ok but the build quality is horrible! I just bought a ~$90, 5K BTU unit for my GF from Wally World and was absolutely appalled. (Haier brand) I don't see it lasting more than a season or two. The lowest priced 7-10K BTU units are just as bad.
Old 06-22-2010, 06:13 PM   #9
SteveU
Senior Member
SteveU's Avatar
Our 12K window unit got to where it was running but wasn't cooling much. Took the cover off it & the back was coated with bugs, cottonwood, dust, etc. Cleaned that by spraying it off & removed handfulls of bugs & gunk & it started cooling again. You can also get a can of coil clean at hardware stores & try that. All the crud was on the inside of the coils. What I did after that was to put 2 layers of window screen around the outside which did a good job of keeping stuff out but needs to be cleaned occasionally.
SteveU is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
