Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 06-05-2010, 12:31 AM   #1
DJFlak
Junior Member
Question Thermal Break at Garage Door
Hi, I am in the process of building a large garage in northern WI and will be installing in floor hydronic heat. I will have 2" on foam under the floor and 1" of foam as thermal break between the slab and the walls.
My question is... What is the best way to install the thermal break at each of the garage doors. The mason has poured the 4' frost wall and left roughly a 6" deep opening at each of the garage doors so that he can pouring the threashold at the same time as the floor is poured. I know I need a thermal break somewhere... Does anyone have a suggestion for the best energy efficient and yet asthetic and functional approach?
I know he is planning on a black expansion joint between the door threashold and the apron, but my guess is that this would still allow significant heat loss at each door apron...
I need your help and suggestions!!!
DJFlak is offline   Reply With Quote
Old 06-05-2010, 08:44 AM   #2
Addrock
Senior Member
Addrock's Avatar
Default Re: Thermal Break at Garage Door
You could ask your concrete contractor about adding in closed cell expansion joint material.
Addrock is offline   Reply With Quote
Old 06-05-2010, 08:50 AM   #3
Addrock
Senior Member
Addrock's Avatar
How much do you have into Pex for your hydronic heat?
Old 06-05-2010, 09:29 AM   #4
Weedwaka
Senior Member
Weedwaka's Avatar
I am interested in this also.
Weedwaka is offline   Reply With Quote
Old 06-05-2010, 10:31 AM   #5
Torque1st
Senior Member
Torque1st's Avatar
Avoid the door area with the pipes unless you want the heat to melt ice. Keep the pipes 2' from the doors.
__________________
Faster, Better, Cheaper: Pick Two
The FairTax
Follow the Money. -72chevy
Yes, I am insensitive and yes, not politically correct, and yes, Im sure I offended someone,... -Busted_Knuckles (Me too, plus I am old, tired, and grumpy!)
Read "The Marching Morons" Here
"Works" <> Safe, Good, or Right
"You can't fix stupid." -Ron White
Torque1st is offline   Reply With Quote
Old 06-05-2010, 08:19 PM   #6
DJFlak
Junior Member
I have a plumber that is doing the rough in all of the floor drains, the bath room shower and all the in floor heat PEX tubing 5/8th inch for 1650 square feet for about $2800...
Old 06-05-2010, 08:21 PM   #7
DJFlak
Junior Member
I am still trying to figure out... where the thermal break should be...
Does anyone have more specific recommendations.
Old 06-05-2010, 11:00 PM   #8
ScaldedDog
Senior Member
I just used the normal stuff they put between expansion joints. It does let some heat through, for sure. There are photos in the heating section of how some guys did theirs.
Mark
ScaldedDog is offline   Reply With Quote
Old 06-05-2010, 11:04 PM   #9
Racecarl
Senior Member
Racecarl's Avatar
I put in 4X8 sheets of 2" (250) extruded polystyrene (the pink stuff) all around the inner perimeter. The vertical sheets start 1.5" below the top of the 6" slab and go down 4'. The horizontal sheets are beneath the slab and extend in 4' from the inner foundation walls. I ripped pressure treated 2X6's into 2" strips and screwed the strips to the inner walls, making absolutely certain the strips were level. I used the strips to screed the concrete as level as possible. The wood protects the insulation from damage.
For the single 16' garage door, I dug a trench across the door opening and installed the insulation to the correct level. I installed a 1.5X2" board in the same manner as the sidewalls. I then backfilled the trench and built forms to hold the concrete in place when I poured the floor. After the floor was poured and cured, I removed the forms, did the subgrade work, and poured the driveway. The board across the door is removable in case it gets damaged or rots in the future.
I can post some pics if I can get the camera away from my kids.
Racecarl is offline   Reply With Quote
Old 06-05-2010, 11:28 PM   #10
rlme36
Senior Member
Quote:
Mark
take a look at my build listed in my sig post number 15, but essentially I carried over the vertical portion across the door opening and then had my concrete guy pin the apron to the frost wall and not the slab, due to the pex. The pictures explain it much better, the picture shows the form off from the slab pour and then I added in a piece of foam board across the door. You can then cut it down and fill it the void with something that takes traffic a lot better. I choose wolverines integra flex epoxy. Its really goopy and I used it around the entire perimeter of my slab since the vertical foam poked up an inch or so.
__________________
My Build Thread
http://www.garagejournal.com/forum/s...ad.php?t=36657
rlme36 is offline   Reply With Quote
Old 06-06-2010, 02:43 PM   #11
Torque1st
Senior Member
Torque1st's Avatar
Concrete is a poor conductor of heat. 2' is normally considered enough to prevent significant heat loss. If you are really worried about the heat conduction from the PEX in the slab to outside then keep the PEX 3' from the doorway.
__________________
The FairTax
Old 10-21-2013, 10:40 AM   #12
surfsup
Junior Member
Quote:
Interesting concept alleviating any need to deal with the thermal break. Any other comments on this?
I was wondering, if a thermal break is still desired, since the concrete should be poured running out to the front of the garage foundation, is it possible to place a piece of foam vertically across the opening and pour the concrete over it to hit both sides simultaneously, carefully, to not knock it over, by putting pressure on both sides so it can all be done in one shot? or will the curing process compress the foam, etc?
surfsup is offline   Reply With Quote
Old 10-21-2013, 11:13 AM   #13
surfsup
Junior Member
I am having a home built. The architect (Chicago area home) put this together for the detail where the garage floor slab is tied into the foundation/footing and extends out pas the door. The pour, if I were to place a piece of foam under the door, would require another visit from the concrete people which complicates matters into more expense. Anyone have any ideas? I am considering Torque's suggestion to simply keep the tubing 2' from the door, but the thermal R value of concrete is 24" is R=2.5 which is not much.
http://chicagocadcam.com/house/garage.jpg
Old 10-21-2013, 11:23 AM   #14
ct71rr
Senior Member
ct71rr's Avatar
Send llwillysfan a PM. I asked him the same question. I think there is an older thread about this on here, as well.
ct71rr is offline   Reply With Quote
Old 10-21-2013, 12:31 PM   #15
Macguyvermedic
Junior Member
^subscribed. Building a 24x36 3 stall in SW Michigan, footings in today and walls Wednesday.
Macguyvermedic is offline   Reply With Quote
Old 10-23-2013, 03:26 PM   #16
surfsup
Junior Member
Quote:
This is what he says:
The best method I've come up with is to run 2" rigid insulation around the inside of the foundation and continue it right across the garage door openings. You then pour a concrete apron 2-3' out from the slab edge over the top of the foundation wall. You can either bevel the top of the rigid insulaion so it doesn't show or cover it with a rubber garage door sill strip.
It's a bit more work to do it this way but it keeps the heated part of your garage slab inside the overhead doors.
Old 10-23-2013, 04:10 PM   #17
Rookie2
Senior Member
Rookie2's Avatar
I have 2" insulation under mine and it hangs out 6" , i don't think its too big a loss to live with because i kept the pad i/s the walls and have 2 feet of insulation vertical 360 degrees.
The door threshold is the only place the floor cracked though.
Rookie2 is offline   Reply With Quote
Old 10-28-2013, 08:44 PM   #18
kj_mustang
Senior Member
Here is what I did. Used the xps and a board for support for my concrete form at the garage door. I wanted the outside pad tied to the interior slab so I ran rebar through the foam and wire tied the rebar and wire mesh together. I had to bend the rebar into a S shape to make the elevation change because my outside pad is lower than the interior. After pouring the interior, I cut the foam form down to expose about two inches of the interior slab. The exterior concrete was poured next and goes all the way over the top of the cut down foam. Here is some pictures.
kj_mustang is offline   Reply With Quote
Old 10-28-2013, 09:13 PM   #19
Rookie2
Senior Member
Rookie2's Avatar
You should keep the pex back a couple of feet or more and have the bay at the door on its own zone that way you can reduce the water flow/temp as required. Also don't get carried away in the bathroom, too much heat will dry the p-traps out under the shower.same as above have it on its own heat zone.
Old 10-28-2013, 09:15 PM   #20
stigedis
In the above 2nd picture, how thick is the cement at the threshold? Ie. over the edge of the foam? 2 inches? Will that crack? Also, I assume the black plastic that is seen is the top of the foundation wall and foam is run on interior wall?
stigedis is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
