Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 06-13-2010, 12:09 PM   #1
indestro
Senior Member
indestro's Avatar
Cool sae/metric chart?
Hello all, curious here as to if there is a possible pdf chart out there that charts metric and sae wrench sizes next to eachother for quick reference
indestro is offline   Reply With Quote
Old 06-13-2010, 12:12 PM   #2
george4
Senior Member
Default Re: sae/metric chart?
http://www.engineeringtoolbox.com/in...ion-d_751.html
george4 is online now   Reply With Quote
Old 06-13-2010, 12:58 PM   #3
OccupantRJ
Senior Member
OccupantRJ's Avatar
Not directly relating to wrenches, but a quick rule of thumb for metric is that one millimeter equals approximately .040 inches, and there are approximately 25 millimeters to an inch. A digital caliper is also a good conversion tool. Measure in thousanths, then switch the tool to millimeters without moving the setting, and visa versa.
RJ
__________________
RJ
It's always easier to find a reason NOT to do something.....
The sum of all your choices, good and bad, become your life.....
OccupantRJ is offline   Reply With Quote
Old 06-13-2010, 01:12 PM   #4
Joe B.
Senior Member
Joe B.'s Avatar
Does anyone know if there is a source for standards regarding the exact dimensions for wrenches and if they are the same for SAE & Metrics. (If a bolt is exactly 14 mm across the flats and a wrench is 14 mm, it would almost be impossible to fit the wrench on the bolt.) Maybe every manufacturer has its own standard.
One could always do the conversions using Google or whatever, but one would need the true exact dimensions to start with.
Joe B. is offline   Reply With Quote
Old 06-13-2010, 01:15 PM   #5
camaross
Senior Member
How about this one? I can customize one for you, if this is not what you want.
http://cid-533c6ad99f5ed0c5.office.l...%5E_Metric.pdf
Quote:
camaross is offline   Reply With Quote
Old 06-13-2010, 05:11 PM   #6
MotoDave
Senior Member
MotoDave's Avatar
Send a message via AIM to MotoDave
I've got one I like at work, I'll scan it tomorrow.
MotoDave is offline   Reply With Quote
Old 06-13-2010, 05:46 PM   #7
indestro
Senior Member
indestro's Avatar
yah, thanks, im really looking for a quick printable chart
Old 06-13-2010, 06:07 PM   #8
Coach James
Senior Member
Coach James's Avatar
I got one from Wright in the form of a 4x6(I think) sticker. I put it on the inside lid of one of my top chests.
Coach
Coach James is offline   Reply With Quote
Old 06-13-2010, 06:46 PM   #9
bonneyman
Senior Member
There's a fantastic chart just like you're talking about in the 1986 Bonney I own. Even has drill numbers in it! Very handy. But I don't have a scanner. I'd be willing to snail mail a copy to someone with a scanner if they'll post it for all to see.
bonneyman is offline   Reply With Quote
Old 06-13-2010, 06:52 PM   #10
ATTappman
Senior Member
Try this one. Scroll down 'til you see "Jaw Size Table." Below the table is a list of links for other wrench/socket size tables.
ATTappman is offline   Reply With Quote
Old 06-13-2010, 07:44 PM   #11
Andy Traxel
Junior Member
I'm not sure to what end you want to put this information, so this may not be an answer for you.
Any edition of Machinery's Handbook from the last 15 years will have current information on ANSI standards for wrench dimensions. And it will have specs for the kind of clearance needed for different size wrenches.
Look at places like Half Price Books for an old copy of Machinery's Handbook. It's a good reference for lots of things mechanical.
Andy
Andy Traxel is offline   Reply With Quote
Old 06-13-2010, 08:02 PM   #12
caper
Senior Member
caper's Avatar
Send a message via MSN to caper
8mm=5/16",haven't compared 9mm and 11/32",3/8 has nothing similar in metric,10mm is bigger than 3/8" but has no sae match,11mm=7/16",13mm just slightly bigger than 1/2" but will work in a pinch.,14mm just a hair smaller than 9/16",annoying but it will work.15mm is on its own,16mm=5/8",17mm slightly smaller than 11/16",18mm is its own,19mm=3/4",20mm is its own,21mm is just a hair bigger than 13/16",22mm=7/8",24mm=15/16".Just off the top of my head.
__________________
Quote:
Originally Posted by mrholeshot View Post
Takes about two minutes once you have the shaft in hand.
caper is offline   Reply With Quote
Old 06-13-2010, 10:29 PM   #13
X1 Mike
Senior Member
X1 Mike's Avatar
Here is one.
http://www.jrcwelding.com/images/inc...hart_20001.jpg
Starrett has a great pocket chart. I keep one behind the cover of my calculator, which is never far from me when I'm working.
__________________
Don't always believe statistics, they will tell you that
the average human has one breast and one testicle.
X1 Mike is offline   Reply With Quote
Old 06-15-2010, 01:49 PM   #14
KLars1
Senior Member
Does anyone have a source for one similiar to the one X1 Mike posted that is pre laminated and large for hanging on the wall?
KLars1 is offline   Reply With Quote
Old 06-15-2010, 02:03 PM   #15
Falcon67
Senior Member
Falcon67's Avatar
For factional sizes such as X/Y", then ( 25.4 * X ) / Y gets a number you can use. 1/2 is 12.7 which is why a 13mm works, 3/4" is 19.05, etc.
__________________
Chris - Merkel, TX
http://raceabilene.com/kelly/hotrod
<a href=http://raceabilene.com/misc/NewShop/ShopIcon.jpg target=_blank>http://raceabilene.com/misc/NewShop/ShopIcon.jpg</a>
Click to view my GJ build thread
Falcon67 is offline   Reply With Quote
Old 06-15-2010, 02:12 PM   #16
Moose-LandTran
Senior Member
Moose-LandTran's Avatar
Send a message via AIM to Moose-LandTran Send a message via MSN to Moose-LandTran
Quote:
Yep. After a while you just "know".
__________________
Quote:
Originally Posted by cosmik binturong
I lived in a forest, I could always go punch a Moose or something.
Moose-LandTran is offline   Reply With Quote
Old 06-15-2010, 03:00 PM   #17
bonneyman
Senior Member
Quote:
The "real" test that you've arrived is when you can look at a nut or bolt and guess the right size by appearance. I can do that with SAE, but not metric - yet.
Old 06-09-2013, 10:25 AM   #18
Xoloski
Junior Member
Xoloski's Avatar
SAE to Metric Wrench Table
It is not an exact fit, but good enough for government work...
Xoloski is offline   Reply With Quote
Old 06-09-2013, 11:26 AM   #19
Wakefield
Alliance Member
Location: Arlington VA (but would like to get out to country or small town)
Wright Tool Catalog has a conversion chart in it for metrics trying to match inch-standard.
Wakefield is offline   Reply With Quote
Old 06-09-2013, 12:20 PM   #20
blackz26
http://www.garagejournal.com/forum/s...d.php?t=190399
Drill and tap chart is what you need. As stated in the link, if you have say a 14mm bolt that is rusty, and a 13mm is too loose, it helps to know the sae in between to hammer it on. Plus, youll get to know the sae "equivalent" to metric.
blackz26 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
