Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 06-23-2010, 03:13 PM   #1
Scramblur
Senior Member
Scramblur's Avatar
Default What paint to use on plastic sink?
I have a standard plastic slop sink I want to take from the standard ivory color to black. What is a good paint to use?
Scramblur is offline   Reply With Quote
Old 06-23-2010, 03:19 PM   #2
Elkiebob
Senior Member
Default Re: What paint to use on plastic sink?
I have had good luck with Krylon spray paint for plastic.
Elkiebob is offline   Reply With Quote
Old 06-23-2010, 04:19 PM   #3
Jack Olsen
Jack Olsen's Avatar
I think prep is going to be your biggest decision. Scuff it good with an orbital sander -- then acetone -- then primer. Whatever semigloss or gloss you put on top of that should have very few issues.
Jack Olsen is offline   Reply With Quote
Old 06-23-2010, 07:41 PM   #4
rodnok1
Senior Member
rodnok1's Avatar
If you are painting the inside use some marine paint or it'll flake off due to water getting behind it.
__________________
Some people are like Slinkies... They're really good for nothing.
...But they still bring a smile to your face when you push them down a flight of stairs!
rodnok1 is offline   Reply With Quote
Old 06-23-2010, 10:01 PM   #5
Ruddy
Senior Member
Ruddy's Avatar
as a sort of related question...has anyone built their own cabinet to enclose their all plastic garage sink? They are not veru attractive on their own! ;-)
__________________
Lived in California my whole life and happy!
Ruddy is offline   Reply With Quote
Old 06-23-2010, 10:27 PM   #6
Jack Olsen
Jack Olsen's Avatar
I painted and (kind of) enclosed my ugly plastic sink. It was a quick-and-dirty job and I'm planning on doing a better job when time permits. I used plywood for a benchtop, covered with the plastic sheeting you use for shower stalls -- then wrapped an aluminum band around the edge.
Old 06-23-2010, 10:45 PM   #7
Scramblur
Senior Member
Scramblur's Avatar
I think I'm going to do something similar to you're design Jack. Maybe enclosed all the way with plywood, painted black and trimmed in aluminum. Probably better than painting.
Old 06-24-2010, 03:34 PM   #8
NUTTSGT
NUTTSGT's Avatar
Are you talking outside and inside of the sink ? I'm not sure what paint would hold up to the inside clanging and banging abuse. For the outside I would try using an automotive interior paint. They also make a prep or primer to use prior to spraying the paint.
I'd check your local autobody supply store, maybe check out SEM brand paint.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 06-24-2010, 07:03 PM   #9
Scramblur
Senior Member
Scramblur's Avatar
I think I'll stay away from inside the sink, unless someone tells me there is a full proof solution. I'm looking for a used stainless restaurant sink in the mean time.
Old 06-24-2010, 07:54 PM   #10
Jack Olsen
Jack Olsen's Avatar
I also want to scrap the big sink, long term, and put in something smaller. I think the big tubs are useful if you're soaking laundry, but that's about it. I don't soak laundry.
My long term plan is to make curving cabinet faces out of brushed aluminum sheet, with an aluminum or stainless countertop and backsplash. I'd like hot and cold controls for one spigot in the sink, and then a T-valve off of that on a line to a retractable reel so I can have cold or hot water to run outside or anywhere in the shop. I'll follow the same curved line up above for more aluminum-faced storage. If I can find a way to fit in a small dorm-styl fridge, that's be great.
When it's done, it'll be the one corner of the garage that's not green.
Old 06-25-2010, 11:07 PM   #11
Ruddy
Senior Member
Ruddy's Avatar
Since those plastic tubs have a lip, thought it might not be too hard to build a cabinet that fits just under those lips. I could see having more "counter" space around it like Jack's. Also some kind of backsplash. I was thinking about using that as a practice area for me to learn how to put down tile with leftover tile from the house. Most of the left over stuff is kinda fancy for a garage though!!
__________________
Old 06-25-2010, 11:58 PM   #12
Jack Olsen
Jack Olsen's Avatar
I made the counter edge overlap the sink so that water would run off the cabinet and into the sink.
Old 06-26-2010, 12:46 AM   #13
JC23
Senior Member
JC23's Avatar
Wouldn't the obvious wise ass answer be -wait for it - water paint?
JC23 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
