Welcome to the The Garage Journal Board forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Thread Tools | Display Modes |
#61 |
Junior Member
Anyone have experience with these lifts?
http://www.kwiklift.com/Compare.htm I have many constrains working against me (power, ceiling height, space) but want something better and safer than the jack stand deal. |
#62 | |
Senior Member
Quote:
#63 |
Senior Member
Both a Rotary 12,000 lb and a Bendpak 14,000 lb lift. Both extra long runways and the Bendpak is a tall lift.
#64 |
Senior Member
#65 |
Junior Member
Supposedly it lays flat when not in use and you can drive on it to park. I agree its not ideal but I had a truck come off jack stands a few weeks ago and scared the heck out of me. I need a better solution and a 2 post or 4 post will not work for me.
#66 |
Senior Member
setting up my lift after raising the ceiling-
![]() lift in use- ![]() Lift is a Danmar
__________________
26x26 attached with 13.5' ceiling and Lift 20x16 detactched with 11.5' ceiling for tractor/lawn eqip -1989 Mustang Coupe- Twin Turbo, T56/RXT, DFI, Griggs/MM 563rwhp/610rwtq -1998 Lincoln Mark VIII LCS - 18" mustang wheels, T-bird suspension, 3.73s, Jmod, Xcal3, Magnaflow -2004 F-150 SuperCrew - 6" Lift, 35" M/Ts on 20x9s, Xcal, Magnaflow -1998 Explorer Limited V8 AWD -1988 F-250 Dually ATS Turbo 7.3 -1999 Buell X1 Lightning - Painted, Tuned, XB updates -2007 JD 2320 CUT |
#67 | |
Junior Member
Quote:
Race Ramps also has a drive on ramp similar to the Kwik Lift. I prefer the Kwik Lift. If you have a place where you just can't get a normal lift it's a very good solution. And it's not all that heavy to move out of the way if you have to. Set it up for the weekend and take it down after your done. |
#68 |
Junior Member
Thanks for the input +6r on the KwikLift
#69 |
Just got my Bend pak lift installed friday night . Looks like it will work out nice. The people I delt with were the best Dave Shedlock, workshop Depot.
#70 |
Alliance Member
a couple of mine
![]() ![]() ![]() I like the Forward brand lifts. |
#71 |
Senior Member
Here's mine
#72 |
Junior Member
Wheeltronic is a division of Snap-on. You can check out the web site Snap-On Canada or you can call them at 905-826-8600 and tell them your problem. Good luck
#73 |
Junior Member
Wheeltronic is a division of Snap-on. You can check out the web site Snap-On Canada or you can call them at 905-826-8600 and tell them your problem and they should be able to help you out in getting both sides leveled out. Good luck
#74 |
Senior Member
here is our 11000 pound eagle. just installed. it is working great so far. the instructions left a bit to be desired but we figured it out.
__________________
patience is not one of my virtues "if it's not broke I haven't fixed it yet" Welcome to the Doghouse!: http://www.garagejournal.com/forum/s...ad.php?t=44061 |
#75 |
All these nice setups...
![]() Mine's an Australian Molnar brand hoist. Aussie produced from locally sourced BHP steel and CNG motor. For me over here, probably on par with your Mowhawk. ![]() I haven't got any pics of it at home yet, but this is the pic of it in its first home, a wreckers, who had it for 10 years. The exact same lift is still sold by Molnar today at $7K AUD plus install. Being a wreckers, this one would have been lucky to have been used 2-3 times a week rather than a service workshop, being used 3-4 times a day. Bought, transported & installed for under $2.5K AUD, including change of motor from 3 phase to single. ![]() Would have liked a clear floor model, but the roof rafter's 6" too low!! ![]() Molnar Hoist 01.jpg
__________________
Too many projects, so little time, even less money! |
#76 |
mohawk A-7 with under ground line kit
#77 |
Senior Member
Here's mine, a used one from a dealership that was closing it's doors. I believe it's called a Benwil. Never heard of them, but the dealership had a bunch of them, so I figured they can't be too bad!
__________________
.......and remember, if the women don't find you handsome, they should at least find you handy! |
#78 |
Junior Member
This garage has been up for about a year and half. The lift is a Challenger model number 39000. It's rated at 9,000 lbs. Bought it from a guy who sells and installs all kinds of shop equipment. I just got the garage up and it wasnt 2 weeks before i had it bought and i installed it myself. Bought it for 1500 dollars,,,works like a champ! Biggest truck I've had on it is a crew cab 1 ton dually. Dont want anything bigger! The one picture shows the jack shaft style garage door opener. No clearance issues with this type of set up. The guy in the pic is not me,,,,he's my brother-in-law looking at his truck,,,he sure likes my lift!!
#79 |
Junior Member
Mine's a Two Post AmericanProducts Model TP9A Specifications
• Capacity 9000 lb • Lifting speed 45 seconds • Power pack 220v • Lifting height 72" - 82" • Width Overall 134" • Width between posts 110"
__________________
....never stop living your dream... |
#80 |
to all the 2 post asy litft owners out there. What kind of room do i need in front of my posts for clearance??? is 9 ft enough or do i need more?
reason is my pad is 31ft and i want to put it in the back centre of my shop. i have lots of height in the midle but i want to be able to park 2 vehicles behind each post when i'm not using it. |
| Tags |
| 2 post lift, 4 post lift |
| Thread Tools | |
| Display Modes | |
