Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 06-27-2010, 09:08 AM   #1
ChristopherLutz
Senior Member
Default How much weight do you think these would hold?
All - looking to build some cabinets in the garage, came across these in the Family Handyman mag:
http://www.familyhandyman.com/DIY-Pr...arage-cabinets
I like the look and the install seems pretty easy (relatively speaking).
I'm concerned about how much weight they would be able to hold given the 2x2 framing?
Thoughts?
Is there something I could do to improve the structure to accept more weight?
I plan to try and do something like this across a significant section of my garage wall...guessing about 3 feet deep, 4 feet high?
Thoughts welcome, don't want to have design flaws from the very beginning.
ChristopherLutz is offline   Reply With Quote
Old 06-27-2010, 09:19 AM   #2
e-tek
Senior Member
e-tek's Avatar
Default Re: How much weight do you think these would hold?
I'd say under 150 lbs for 2x2 construction and plus 400 pounds for 2x4. 'Course itdepends on your wall anchors too. Issue with 2x2 is also the ability for them to hold the screws used - not much meat there.
I'm in the midest of building a tree house addition and made the walls of 2x2 to save room - but they don't have to hold much weight!
__________________
VISIT me at www.E-TekRestorations.com
OR, read the blog: www.E-TekRestorations.blogspot.com
Quote:
We have to recognize that paying more for quality products made in countries that support the quality of life we want for ourselves and our children, is critical to protecting our own quality of life.
e-tek is offline   Reply With Quote
Old 06-27-2010, 09:54 AM   #3
ddawg16
Senior Member
ddawg16's Avatar
The key to the strength is how it's attached to the wall....
The plywood sides make it extreemly strong as far as shear stress goes.....the two major points of attachment strenght are at the bottom and top.
The bottom is what carries the majority of the weight. When I make my cabinets I always have a good support board that goes across and is securely attached to the sides.
On the top, that board is what keeps the top from pulling away from the wall...so it needs to be attached in such a way as to not let the sides pull away from it.
Here is a shot of one of the upper cabinets I made for my garage.....see the rear board going across the back? That is not intended to hold weight....just keep the top from pulling away from the wall.
What you can't see is the strip at the bottom....it carries the brunt of the weight....I have it attached to the sides and bottom shelf....
When I attach them I also screw in a bracket on the front top to the ceiling......with real wood I would not bother...but I used melamine....so I wanted a bit extra hold....
I feel these are strong enough that it would hold my weight.
__________________
John
Never blame any day in your life. Good days give you happiness. Bad days give you an experience. Worse days give you a lesson.
In Progress...2-Story Addition link
2-Story Garage Complete My Garage Build Link
Home for.....
84 CJ7 - With a 'few' modifications.. My Jeep Build Link
And my wife's art Studio...
and 3 kids with more energy than we have...
ddawg16 is offline   Reply With Quote
Old 06-27-2010, 10:02 AM   #4
ddawg16
Senior Member
ddawg16's Avatar
E-Tek....you are going to put a roof on that...right?
And you should have used a tublar slide.....that way it would keep the snow out in the winter time.....
This is what I made for my kids.....I used redwood....that stuff is expensive....but not very strong....
__________________
John
Home for.....
Old 06-27-2010, 10:23 AM   #5
1984GMC
Tree houses belong in trees.
1984GMC is offline   Reply With Quote
Old 06-27-2010, 02:15 PM   #6
ddawg16
Senior Member
ddawg16's Avatar
Quote:
Yep....I agree.....but these are not tree houses.....they are play areas for kids.....in my case, we call it "The Fort". If it was in a tree, we would call it "The Tree Fort".
__________________
John
Home for.....
Old 06-27-2010, 02:36 PM   #7
Jack Olsen
Jack Olsen's Avatar
Like ddawg16 says, the key to the whole thing is how you attach the verticals to the wall and then how you attach the shelves to the verticals (and also to the wall. You wouldn't need much more than 1x2s for the framing and you could put yourself inside the cabinets without an issue. But everything has to have strong ties back to the studs.
And then, on the 'play fort' sidetrack... well, some of us don't have trees (or very much lawn space):
Jack Olsen is offline   Reply With Quote
Old 06-27-2010, 04:22 PM   #8
nate379
Not sure what I would have done as a kid if I didn't have at least a few acres to roam around on. Well I guess get obese playing Nintendo games I suppose?
nate379 is offline   Reply With Quote
Old 06-27-2010, 06:00 PM   #9
overkill 19
Great play house. Whats up with all the wires running all over?
overkill 19 is offline   Reply With Quote
Old 06-27-2010, 08:05 PM   #10
mmhouse
Senior Member
mmhouse's Avatar
When I attach a cabinet to the wall that will carry significant weight I typically screw a solid ledger board to the wall and set the cabinet on the ledger. Then the bottom attachment is just keeping the bottom from kicking out, the weight is supported by the ledger. It also makes the cabinet much easier to install. As someone else stated, the connection to the wall at the top is also very important to keep it from pulling out.
mmhouse is offline   Reply With Quote
Old 06-28-2010, 01:42 AM   #11
onewaydave
Senior Member
Diagonal brace under, back to the studs. Shelf brackets under, box stores have industrial sized ones.
Dave.
onewaydave is offline   Reply With Quote
Old 06-28-2010, 02:54 AM   #12
brownfoot
the 2x2's are just cleats attached to the 3/4 plywood to allow it to be lag bolted to the wall, should be able to hold anything you could lift to put in the cabinet
the weakest part of the connection is screwing the ply to the 2x's that are attached to the wall
brownfoot is offline   Reply With Quote
Old 06-28-2010, 04:54 AM   #13
Kevin54
Senior Member
Kevin54's Avatar
It was either that cabinet design or ones similar to them that were a little larger (maybe in the Garage magazine that was out a while back) that showed a couple of people standing in them. The key to supporting the weight is how the joints are made and fastened together. If you just nail a bottom to a wooden box it will not support nearly the weight as it would when the bottom is fastened into all four sides
Kevin54 is offline   Reply With Quote
Old 06-28-2010, 11:55 AM   #14
kbs2244
Senior Member
If you just make them 12 inches deep that will keep you from overloading them.
kbs2244 is offline   Reply With Quote
Old 06-29-2010, 07:42 AM   #15
Wingnut65
Senior Member
Wingnut65's Avatar
Thanks ChristopherLutz for posting this project. I have been looking for economical 42" tall cabinets to buy without much luck. This seems to be a great solution. I only need them 12" wide because I park cars next to them and this also solves my concern of swing doors hitting the car. Now that I think of it, I have seen at least one garage here with similar cabinets with sliding doors.
I agree with the others that the 3/4" plywood carries the dead loads and the 2x2's are cleats to hold the ply to the wall. I will go with screwing the plywood to the 2x's at 6" on center max.
__________________
jeff
- Shop Sign: WE DO PRECISION GUESSWORK
- Follow along as I work on my
Wingnut65 is offline   Reply With Quote
Old 06-29-2010, 08:03 AM   #16
28HopUp
Senior Member
28HopUp's Avatar
Send a message via AIM to 28HopUp
Post Re: How much weight do you think these would hold?
Quote:
I'll echo this as well. Mounting a solid ledger to place the cabinets on will help with installation, keep them straight, and should assist with distributing the load weight.
__________________
Bill Jr.
1985 SSP Mustangs -
CHP #E408383 SMPV
CHP #E408395 B&W
28HopUp is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
