Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 07-22-2010, 03:39 PM   #1
plinker
Senior Member
plinker's Avatar
Default Cleaning battery acid corrosion in a Maglite
Hav a 4-D cell Maglite that had a battery leak near the tail end. Whats the best way to clean it out?
They were Rayovac batterys, FWIW.
__________________
Have a Snap-on ratcheting screwdriver? check out this link...
http://www.garagejournal.com/forum/s...ng+screwdriver
plinker is offline   Reply With Quote
Old 07-22-2010, 03:57 PM   #2
TheGrooveking
Senior Member
TheGrooveking's Avatar
Default Re: Cleaning battery acid corrosion in a Maglite
Lemon juice and some scotchbrite. You'll need an acid to remove the alkaline leakage from the batteries.
TheGrooveking
TheGrooveking is offline   Reply With Quote
Old 07-22-2010, 04:03 PM   #3
Davefr
Senior Member
Davefr's Avatar
I thought battery companies would replace the flashlight if their batteries runied it. If so, send it to Rayovac.
Davefr is offline   Reply With Quote
Old 07-22-2010, 04:07 PM   #4
Interex
Senior Member
Interex's Avatar
Go down the auto store and get some corrosion cleaner. Comes in a little squirt sprayer and works amazingly well. Corrosion just dissolves to a point that you simply wipe it off with a paper towel.
Interex is offline   Reply With Quote
Old 07-22-2010, 04:16 PM   #5
Rockford514
Senior Member
Rockford514's Avatar
Baking soda and water
Rockford514 is offline   Reply With Quote
Old 07-22-2010, 04:22 PM   #6
1969
Senior Member
1969's Avatar
I had the same thing happen to me,contacted the people that made the batteries and they sent me numerous coupons towards new products. I can't remember at this time who made the batteries. If I remember correctly they offered to replace the Maglite if I wanted. I was able to clean up the mess myself, so I just accepted the coupons. I would recommend contacting Rayovac.JMO
1969 is offline   Reply With Quote
Old 07-22-2010, 05:31 PM   #7
Mike83
Senior Member
Mike83's Avatar
Same exact thing happened to me two weeks ago. It is a 3 AA Maglite. The end battery came out but the second one is stuck due to all the corrosion. Rayovac batteries also.
Looks like I'll need a combination of lemon juice, baking soda, water, corrosion cleaner and scotchbrite and I'll be good to go!
__________________
Looking to Buy: SK Tuff 1 1/4" Flex Ratchet and 1/2" Flex Ratchet; Snap-on TF72 Ratchet
Mike83 is offline   Reply With Quote
Old 07-22-2010, 07:49 PM   #8
kblazer87
Senior Member
kblazer87's Avatar
Quote:
This is what I used when mine needed it.
kblazer87 is offline   Reply With Quote
Old 07-22-2010, 08:13 PM   #9
jride200
Senior Member
Contact Maglite. Although slow to process (3-4 weeks), and poor with communication, I sent mine to them and got a new one in return.
I was told that the major battery manufacturers all have warranties against the leakage of acid. Maglite, in turn, has agreements with all of the battery manufacturers, to act as the administer of their warranties.
jride200 is offline   Reply With Quote
Old 07-22-2010, 08:48 PM   #10
mrholeshot
Senior Member
mrholeshot's Avatar
I throw them out and buy a new one, lol Life is short, maglights are cheap now (compared to 1975). I can remember when the mini maglite came out it was 30 dollars off a tool truck.
mrholeshot is offline   Reply With Quote
Old 07-22-2010, 10:28 PM   #11
bonneyman
Senior Member
Quote:
I had a 4 cell Mag with Alkaline Energizers that bulged and leaked due to being in a hot van all day. Never could get the corrosion out enough to get it to work. My own fault, but I've switched to old vintage metal flashlights converted to LED bulbs. They are plenty bright without needing alkaline batteries - and carbon zinc cells don't leak bad stuff!
bonneyman is offline   Reply With Quote
Old 07-22-2010, 10:50 PM   #12
cortez
Senior Member
Mag flash lights are prone to this ozzing of batteries and being near impossible to get cleaned out and working again. I think it has to do with the electro-galvanizing effect between the alloy aluminum and the steel of the batteries (???).
I have gone thru at least a half dozen of them (around 35 bucks a piece). Now I use the super lightweight plastic ones from sears, home depot, HP, even the dollar store!!
All with LEDs and the problem of the exploding batteries is gone.
If you need to have a head basher size MAG flash light for protection take the batteries out daily (yes you will get used to the hassle).
cortez is offline   Reply With Quote
Old 07-22-2010, 11:06 PM   #13
srmofo
Senior Member
x2
asdfgfhujl
srmofo is offline   Reply With Quote
Old 07-22-2010, 11:25 PM   #14
jride200
Senior Member
Quote:
How about some pics/details of the vintage flashlights? I'm planning a retry teardrop trailer build and it'd be cool to have a few of these.
Old 07-23-2010, 12:41 AM   #15
Buxfan
Senior Member
Quote:
Uhhh daily?
Buxfan is offline   Reply With Quote
Old 07-23-2010, 01:08 AM   #16
Mr_fixit
Senior Member
Mr_fixit's Avatar
I had that happen to 2 maglites, 3 times total, twice to the same one. I couldn't get the batteries out, Threw them out, stopped buying maglite and now I don't have that problem.
Mr_fixit is offline   Reply With Quote
Old 07-23-2010, 11:58 PM   #17
cortez
Senior Member
Quote:
Originally Posted by Buxfan View Post
Uhhh daily?
Uh --Yea, for rats and such (not to mention guard dogs!!).
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
