Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 01-05-2007, 10:02 PM   #1
dreamingmuscle
Senior Member
Default Making a bedroom out a garage?
First off the garage used to be a carport. It's a 40 year old house.
The problem that is troubling me at this time is that the floor near the outside wall stays damp especially after it rains. No puddling or anything just damp concrete. I'm pretty sure there is no vapor barrier under the pad.
The pad is 15 inches below the house floor and I'm going to raise it to match the rest of the house.
Question is how do I keep the vapors from getting into the new floor and molding? Or warping the plywood.
Plastic is a given but how do I seal the edges?
________
Ridgeline
dreamingmuscle is offline   Reply With Quote
Old 01-05-2007, 10:58 PM   #2
z28toz06
Senior Member
z28toz06's Avatar
Default Re: Making a bedroom out a garage?
this is the garage junkies forum, you want us to tell you how to make a bedroom out of a garage! That's Blaspheme!. Now ask us how to make a garage out of a bedroom, that's a different story!
I dont think plastic is your answr, It will break down eventually. You need to seal it with drylock or something.
z28toz06 is offline   Reply With Quote
Old 01-05-2007, 11:41 PM   #3
Bib Overalls
Senior Member
Bib Overalls's Avatar
From your post, it sounds like your house has floor joists and decking over a crawl space or basement (not a slab). To do the conversion right you need to remove the garage/carport slab and put in footings and a stem wall foundation and frame the floor to match the existing construction. If your new crawl space is properly vented you should not have moisture problems.
__________________
Plan ahead.
Sweat the details.
My photos: http://www.flickr.com/photos/ratpoison/
When I am dead and gone a new owner will walk into my 99% completed dream shop and say "this place has potential."
Bib Overalls is offline   Reply With Quote
Old 01-07-2007, 08:22 AM   #4
dreamingmuscle
Senior Member
Ahhhh A new garage is the next project.
________
Motorrad
Old 01-07-2007, 08:29 AM   #5
dreamingmuscle
Senior Member
Quote:
You are right about the house having a crawl space.
The owner says that the the slab has a footing. He poured a slab next to it and when he dug down he did notice the footing on the old slab.
The new slab is about 4" below the old slab so I don't believe the water is coming from there.
________
Formula BMW
Old 01-07-2007, 08:32 AM   #6
PAToyota
Senior Member
PAToyota's Avatar
Send a message via AIM to PAToyota
I'd try to figure out why it is staying damp. Is it below grade? Possible drainage issue? Downspout or gutter leaking?
The moisture is coming in from the outside, so if you stop the condition you'll solve the problem.
You don't need to go to the trouble of removing the slab if the garage does have perimeter foundations and all. Just a matter of framing in the floor joists. Take off any interior finishes (drywall, whatever) and put a ledger board around the perimeter. May need a beam of some sort down the center depending on spans. And make sure that the new crawlspace is ventilated.
PAToyota is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
