Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 08-04-2010, 05:15 AM   #1
timtim2008
Senior Member
Default How do you keep your garage cool during the summer?
with out installing an AC unit?
do they make garage door fans? (not just the ones you hang from the ceiling) i mean one that can install/mount on your door, and goes up and down with the door, too would be nice..
i would love this
timtim2008 is offline   Reply With Quote
Old 08-04-2010, 05:58 AM   #2
Fubar
Senior Member
Fubar's Avatar
Default Re: How do you keep your garage cool during the summer?
Big three speed pedestal fan.
Fubar is offline   Reply With Quote
Old 08-04-2010, 06:29 AM   #3
wsettle
I use a big 4' roll around shop fan which keeps the air moving but it will do little today as it will just push 104 degree air around.
wsettle is offline   Reply With Quote
Old 08-04-2010, 06:47 AM   #4
Alf Torp
Junior Member
Send a message via AIM to Alf Torp
Easy. I live in Norway, that helps a lot.
Alf Torp is offline   Reply With Quote
Old 08-04-2010, 07:20 AM   #5
bochnak
Senior Member
I have the blower motor from my old furnace out in the garage. I set it up outside to suck in cool air when I'm out there at night. It also keeps bugs under control since they can't fly in 25mph winds.
Looks like this:
bochnak is offline   Reply With Quote
Old 08-04-2010, 07:31 AM   #6
MScott
Senior Member
MScott's Avatar
Depends a lot on where you live. You cannot make a garage cooler than the outside air....all you can do is reduce the effect of the heat.
First, insulate, insulate, insulate to reduce the amount of heat transfer from the sun-baked exterior. Make sure the garage doors are insulated.
Second, make sure the atic area is well ventilated. Use powered or whirlibird vents to keep the attic as cool as possible. A light coloured (colored for you guys) roof will stay cooler than a dark roof.
As stated, use multiple fans to keep the air moving. You will feel cooler with a breeze on your body and persperation will evaporate more easily.
If possible, keep the garage doors closed and use a dehumidifier to reduce humidity. Drier air always feels cooler.
MScott is offline   Reply With Quote
Old 08-04-2010, 07:55 AM   #7
NUTTSGT
Senior Member
NUTTSGT's Avatar
My garage has been too damn hot this year. I'm not going out there when it's 85+ and humid. After I put a new floor in, I'm dropping the ceiling to try help cool it, heating it is no problem.
__________________
ERIC
Too much is.... Just enough.
My garage refurb thread.
http://www.garagejournal.com/forum/s...ad.php?t=75024
Are you military or prior military ? Please visit OUR thread and post your experience.
http://www.garagejournal.com/forum/s...ad.php?t=64422
Take a look what your USA honorable service may have done for you.
http://www.garagejournal.com/forum/s...d.php?t=100237
NUTTSGT is offline   Reply With Quote
Old 08-04-2010, 07:59 AM   #8
dankicksass
Senior Member
dankicksass's Avatar
Attic fan, exhaust fans in the rear of the garage, oscillating intake fans in the doors. it's not pretty but it makes things livable.
dankicksass is offline   Reply With Quote
Old 08-04-2010, 08:14 AM   #9
Heavy Metal Doctor
Senior Member
Heavy Metal Doctor's Avatar
High humidity makes even the 85-90*F range feel rotten. I can't do much but use a few fans to try to keep air moving through the shop...beyond that, it's just keep a jug of cold iced tea or water handy and sweat....I find that once I'm completely sweat-soaked I stop thinking about it....
Heavy Metal Doctor is offline   Reply With Quote
Old 08-04-2010, 09:23 AM   #10
79firebird
Senior Member
i did the same as bochnak fan from a old furnace they work real good and are portable. works good when welding a lot also moves all the fumes away
79firebird is offline   Reply With Quote
Old 08-04-2010, 09:29 AM   #11
haugy
Senior Member
haugy's Avatar
I hope I'll be keeping the pole barn cool with insulation, to fans mounted high in the upper corners to circulate air, and an window A/C unit.
haugy is offline   Reply With Quote
Old 08-04-2010, 10:43 AM   #12
PurdueSD
Senior Member
PurdueSD's Avatar
Quote:
I built my garage 4 blocks deep in the ground. Its well insulated and will easily stay 10-15 degrees cooler than the outside air if i keep the doors shut.
__________________
My Truck Shop Build thread...
http://www.garagejournal.com/forum/s...ead.php?t=9671
PurdueSD is offline   Reply With Quote
Old 08-04-2010, 12:54 PM   #13
Jack Olsen
Jack Olsen's Avatar
That's my attic fan in the original picture. It was only $80 and it recirculates all the air in my garage every five minutes (by its specs). Since I've got a flat roof, it was pretty easy to install. It can also be used with a traditional roof, though.
For really hot days, I'm currently adding a small AC unit I picked up second-hand. It's a portable one that vents to the outside through holes I'm cutting in the wall. We'll see how well it works.
Jack Olsen is offline   Reply With Quote
Old 08-04-2010, 01:29 PM   #14
Steve in Mi
Senior Member
Steve in Mi's Avatar
Wrong as PurdueSD already pointed out and I second. I often see greater than 20 degrees difference. Insulation down to the frostline means that the 53 degree ground water temp is pulling heat out of my shop leaving it cooler and comfortable. No A/C and my shop doesn't go above 73 downstairs in the Summer. It gets a little warmer upstairs, maybe 2 - 3 degrees. In the Winter it doesn't go below 63 degrees downstairs and again 2 to 3 degrees warmer upstairs. Insulate well and keep it closed up as much as possible has worked for me.
__________________
Work safe, have fun, enjoy the sport.
Remember that a guy never has to come down out of the clouds if he keeps filling the valleys with peaks. Steve
Steve in Mi is offline   Reply With Quote
Old 08-04-2010, 01:46 PM   #15
1Garageman
Senior Member
1Garageman's Avatar
Quote:
I know what you mean fellow Ohio'an. It is freak-en how and humid in my garage also. I feel like keeping the garage doors down and buying a cheap air conditioner for it.
__________________
“Life is hard; it's harder if you're stupid.”John Wayne
1Garageman is offline   Reply With Quote
Old 08-04-2010, 02:14 PM   #16
red baron
Senior Member
red baron's Avatar
I open the bay door.
But it doesnt get too miserable this close to the coast.
red baron is offline   Reply With Quote
Old 08-04-2010, 02:20 PM   #17
61scout80
Senior Member
61scout80's Avatar
I use an evaporative (swamp) cooler. Not so good now that the humidity is up here...
Quote:
Looks like this:
yeah, but how to you keep your hammers from blowing away????
61scout80 is offline   Reply With Quote
Old 08-04-2010, 02:22 PM   #18
geaugafletcher
Senior Member
Ha! Keep it cool in 100 degree weather? You better figure on honest-to-Pete air conditioning or just get up before the sun does. Open door? Attic fan? Portable A/C? Passive cooling through the slab? Fat chance, the weather around here will scoff at your feeble gestures.
geaugafletcher is offline   Reply With Quote
Old 08-04-2010, 02:23 PM   #19
51rider
Senior Member
51rider's Avatar
Quote:
Jack,
you should have no issues with that portable unit-we used one to provide 'temporary' a/c to a server room for about two years!
To the OP-easy move to England where we never have a summer anymore
51rider is offline   Reply With Quote
Old 08-04-2010, 04:35 PM   #20
Iroc-Z
Senior Member
Iroc-Z's Avatar
I will be installing a window unit.
Iroc-Z is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
