Go Back   The Garage Journal Board > The Tools > Fabrication & Techniques
Reply
Thread Tools Display Modes
Old 08-09-2010, 02:33 PM   #1
Krokodil
Senior Member
Krokodil's Avatar
Default Angle iron corner joints
What is the best way to join angle iron at corner joints. I'm planning my workbench, but can't decide how I want to make these joints.
If I cut 45 deg angles on the top frame, the legs must also be trimmed to fit on the inside.
Please help with some ideas and pictures.
Thanks!
__________________
When I'm dead I hope my wife doesn't sell my tools for what I told her I paid for it.
Krokodil is offline   Reply With Quote
Old 08-09-2010, 02:48 PM   #2
T1320T
Senior Member
T1320T's Avatar
Default Re: Angle iron corner joints
I've 45'd most of my frame corners. I weld them then grind down the weld if a wheel plate or leg it gonna contact that area.
T1320T is offline   Reply With Quote
Old 08-09-2010, 02:57 PM   #3
s_ontario
Senior Member
s_ontario's Avatar
miters are the weakest
cutout to fit as image will be your best
s_ontario is offline   Reply With Quote
Old 08-09-2010, 03:22 PM   #4
gorilla
Senior Member
I would miter the corner joints and weld the angle leg to the outside of the corner. If you cut your frame pieces 1/32" short it gives you a little wiggle room to get your frame square and allows a full penetration weld.
gorilla is online now   Reply With Quote
Old 08-09-2010, 03:27 PM   #5
Jack Olsen
Jack Olsen's Avatar
I agree with s_ontario. Interlock the two pieces. You can make the cuts with any angle grinder.
Jack Olsen is offline   Reply With Quote
Old 08-09-2010, 04:15 PM   #6
Krokodil
Senior Member
Krokodil's Avatar
Thanks for the tip guys. That will be most accurate as I only have a grinder to cut with.
Should I put the leg on the inside or on the edge? If I put it on the inside I will have to grind away some of the corner due to the angle iron chamfer on the inside.
__________________
Old 08-09-2010, 08:29 PM   #7
GeorgiaHybrid
Senior Member
GeorgiaHybrid's Avatar
Cut the leg off flush and grind the inside radius off to get a flush fit. The square cut section will go over the notched member.
Edit: In a shop this is called "cope to fit" and will involve a small radius on the coped member where it fits into the square cut one.
GeorgiaHybrid is offline   Reply With Quote
Old 08-09-2010, 09:33 PM   #8
reinhardt
Senior Member
Quote:
ditto. this is the way we do it in the shipyard. much stronger, also easier to get a square corner.
if u do two 45's and cut them at say 37 and 42, its hard to get a square corner.
reinhardt is offline   Reply With Quote
Old 08-09-2010, 09:47 PM   #9
gorilla
Senior Member
Explain to me why you think a coped joint is stronger than a 45* joint?
Old 08-09-2010, 10:02 PM   #10
GeorgiaHybrid
Senior Member
Quote:
It's not any stronger if welded together correctly. You need to have a nice cut-off saw to make sure the 45 degree cuts are correct and then prep the edges for the welds. Most guys have an easier time with coping the corner.
Old 08-10-2010, 12:25 AM   #11
Justanoldguy
Senior Member
Justanoldguy's Avatar
There is more welded surface on a coped corner than there is on a mitered corner so in theory it must be stronger.
In saying that, the miter will be easily strong enough for the application.
Justanoldguy is offline   Reply With Quote
Old 08-10-2010, 05:18 AM   #12
Krokodil
Senior Member
Krokodil's Avatar
The joint should not be stronger due to more weld area. The total contact area is the same and should have equal strenght if the weld is as strong as the iron itself.
__________________
Old 08-10-2010, 09:14 AM   #13
KustomZ
Senior Member
A coped joint is stronger because of the overlap.
KustomZ is offline   Reply With Quote
Old 08-10-2010, 10:10 AM   #14
T1320T
Senior Member
T1320T's Avatar
I've used coped joints on a few of my projects but it seems like after I cut the angle leaving the leg, it loses strength since it's no longer part of the angle. And, during welding it tends to warp more.
Old 08-10-2010, 10:46 AM   #15
gorilla
Senior Member
I am willing to accept that a coped joint may be easier for some folks to make, but it is not stronger. More weld does not make something stronger proper welding and joint prep does. The coped joint has 20% more heat affected zone than the mitered joint and is more likely to warp.
Old 08-10-2010, 12:18 PM   #16
GeorgiaHybrid
Senior Member
Quote:
There is no overlap on a coped joint if it is done right. The strength is the same between both types of joints is the weld prep is correct and the welder does their job. You have the same amount of steel in each direction. Some shops prefer one way while the next shop will go another.
The coped joint is easier to fit up but takes more weld while the miter is easier to cut and takes less weld but requires more weld prep time. It's all in how your shop is set up.
Old 08-10-2010, 12:28 PM   #17
Krokodil
Senior Member
Krokodil's Avatar
Now I'm just waiting for somebody to do a finite element analysis on the strength difference!
__________________
Old 08-10-2010, 02:08 PM   #18
Jack Olsen
Jack Olsen's Avatar
Let's take a step back.
Strength is simply not an issue for the junction between the border pieces for the top of a bench. The important joint -- from that perspective -- is going to be the one that joins the legs to the top frame, along with what other type of support the legs might get (lower crossmembers, diagonals, etc.).
That said, the interlocking joint has one advantage over a miter joint. It's less likely to tear open like a zipper if you were prying the two pieces apart. A weld is theoretically as strong (or stronger) than the metal it joins. In practice, that's often not the case (we'd all like to be theory-level perfect welders, but we aren't). Interlocked seams might not fail in the same kind of zipper-like fashion (meaning: one straight-line seam that can be opened a millimeter at a time instead of having to fail all at once).
Then again, I'm not an engineer. So I could be way off base.
But as I said, the corner really gets no stress at all. I mean, you're attaching a top to this thing, right?
Old 08-10-2010, 02:25 PM   #19
sberry
Senior Member
sberry's Avatar
Strength is irrelevent at this point, this type of joint doesnt have to be as strong as it can be, only adequate.
sberry is offline   Reply With Quote
Old 08-10-2010, 02:27 PM   #20
sberry
Senior Member
sberry's Avatar
A bench corner isnt a high stress connection.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
