Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 08-19-2010, 03:04 PM   #1
tpolley
Senior Member
tpolley's Avatar
Default whatever happend to the harbor freight re-fillable aerosol can?
whatever happend to the harbor freight re-fillable aerosol can? years ago i thought about getting one and a little 12 compressor to fill it up with. now i can't seem to find one.
i work on copiers and i go thru alot of can's of air. we have a compressor but its on the other side of the building. i often have to leave to run service calls so i need a portable air source to blow off optical sensors and the like. the cans of air explode if you leave them in the car on a hot day.
__________________
tpolley is offline   Reply With Quote
Old 08-19-2010, 04:07 PM   #2
tonydanzah
Senior Member
tonydanzah's Avatar
Default Re: whatever happend to the harbor freight re-fillable aerosol can?
you could always just get a shure shot
__________________
Cheap,fast,reliable. You can chose only 2. Rip Ryan Dunn
http://www.usenglish.org/
tonydanzah is offline   Reply With Quote
Old 08-19-2010, 04:51 PM   #3
KEH
Senior Member
I got one a long time ago thinking I could paint with it. It didn't work too well. It might be ok just for air.
KEH
KEH is offline   Reply With Quote
Old 08-19-2010, 04:56 PM   #4
1969
Senior Member
1969's Avatar
Make your own, wouldn't be too hard to do.
1969 is offline   Reply With Quote
Old 08-19-2010, 06:11 PM   #5
rodm1
Senior Member
They leaked air at the crimped seem and I assume they pulled them because of that.
rodm1 is offline   Reply With Quote
Old 08-19-2010, 06:23 PM   #6
impulse922
Senior Member
check these out:
http://www.sureshotsprayer.com/
impulse922 is offline   Reply With Quote
Old 08-19-2010, 08:40 PM   #7
woody 73
Senior Member
Quote:
This is good to know,mine has never leaked I use it all the time. The one I got from HF said to fill it only half full then fill it with air. I use it in conjunction with WD-40 and a few drops of oil.
woody 73 is offline   Reply With Quote
Old 09-21-2010, 12:35 PM   #8
tpolley
Senior Member
tpolley's Avatar
i talked to the boss. i went armed with research. i figured a case of 10 oz cans of air costs us $48. i go thru a case in a month in a half to 2 months. i got aproval to spend $50 on a 32oz sure shot from grainger. i filled it to about 100psi using our big upright compressor. i only get a little stream of air. not enough to blow dust inside a copier. also it ran out of air in about 45 seconds. i'm sure it would be fine for spraying fluid of some sort but not for straight air. luckily i told the guy at grainger what i was doing and he said as long as i didn't put anything other than air in it and had the box they'd take it back.
any other ideas?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
