Go Back   The Garage Journal Board > The Tools > General Tool Discussion
Reply
Thread Tools Display Modes
Old 08-22-2010, 08:44 PM   #1
WHT
Senior Member
WHT's Avatar
Default FORD FS-10 A/C Clutch Field Coil
Does anyone know how to remove the clutch field coil on a Ford FS-10 A/C compressor while still installed on the engine?
Do you really need the removal T89P-19623-FH and T89P-19623-EH/T91L-19623-CH installer tools (I'll never use them again)?
EDIT: The truck is a 2002 Ford Ranger (4.0 SOHC V6)
Thanks for any help.
FORD FS-10 10-CYLINDER
CLUTCH ASSEMBLY
Clutch Field coil removal:
Using Clutch Holder (T94P-19703-AH) to hold compressor shaft from turning, remove clutch plate bolt. Discard bolt.
Thread an 8-mm bolt into clutch plate, and remove clutch plate and shims. Remove pulley outside snap ring. Remove pulley assembly. Note location of clutch coil electrical connector.
Disconnect clutch coil lead. Install Field Coil Remover (T89P-19623-FH) on nose opening of compressor. Using a 2-jaw puller, remove clutch field coil from compressor. DO NOT use air-powered tools when removing clutch coil.
Clutch Field Coil Installation:
Ensure clutch coil mounting surface is clean. Install clutch coil. Ensure electrical connection is correctly positioned. Position Coil Replacer (T91L-19623-CH) onto coil and Coil Pressing Adapter (T89P-19623-EH) onto coil replacer.
Install 2-jaw puller (D80L-1002-L) on compressor and coil replacer. Engage puller jaws with compressor front mounts. Carefully tighten puller until clutch coil bottoms completely against compressor. DO NOT use air-powered tools when installing clutch coil.
Compressor
Compressor Clutch
Compressor Clutch and Pulley Removed (field coil showing)
Clutch Field Coil (mine is NOT removed )
WHT is offline   Reply With Quote
Old 08-22-2010, 09:01 PM   #2
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
Default Re: FORD FS-10 A/C Clutch Field Coil
You don't need the holding tool to keep it from turning, just engage the clutch (if it works) and the engine will keep the compressor from turning while you remove the bolt and use the puller bolt to extract the clutch plate. The coil removal tool sounds like something that catches in a recess or groove that enables the two jaw puller to get a grip on it and pull the coil off. Its pressed on apparently.
Cannot help you beyond that.
Charles
Charles (in GA) is offline   Reply With Quote
Old 08-22-2010, 09:08 PM   #3
WHT
Senior Member
WHT's Avatar
Thanks Charles, I have the clutch and pulley removed and want to replace the coil also. I'd buy the tools, but will never use them again. Being too anal retentive for my own good, I would like to replace the coil while replacing the pulley and clutch (although the old coil still works).
Old 08-22-2010, 09:37 PM   #4
caper
Senior Member
caper's Avatar
Send a message via MSN to caper
I just used to tap the old one off with a hammer and tap the new one on carefully.They don't have much of a lip to go over.
__________________
Quote:
Originally Posted by mrholeshot View Post
Takes about two minutes once you have the shaft in hand.
caper is offline   Reply With Quote
Old 08-22-2010, 10:26 PM   #5
Mike83
Senior Member
Mike83's Avatar
O'Riley Auto Parts rents out for free (you just pay deposit) the kit that has all the removal and installation tools you need for AC clutch work. IMO you need to use these tools to make the job easy and most likely possible without damage to the parts. Autozone does not have a complete selection of AC clutch tools so I would skip that place.
__________________
Looking to Buy: SK Tuff 1 1/4" Flex Ratchet and 1/2" Flex Ratchet; Snap-on TF72 Ratchet
Mike83 is offline   Reply With Quote
Old 08-23-2010, 05:53 AM   #6
WHT
Senior Member
WHT's Avatar
Thanks caper and Mike83. I'll see if O'Reilly has the Ford tools.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
