Go Back   The Garage Journal Board > The Garage > General Garage Discussion
Reply
Thread Tools Display Modes
Old 08-26-2010, 08:35 PM   #1
tigmusky
Senior Member
tigmusky's Avatar
Default floating slab attached to foundation
hi, all
Is there any to attach a floating slab ( my garage) to a foundation ( the house) Like a breeze way. I live in minnesota so frost is a issue.
thank you Daye
tigmusky is offline   Reply With Quote
Old 08-27-2010, 12:15 AM   #2
Nailbender
Junior Member
Default Re: floating slab attached to foundation
Hi. I would have to know more of what you have there. Is money an issue? How old?
Nailbender is offline   Reply With Quote
Old 08-27-2010, 07:17 PM   #3
nehog
Senior Member
nehog's Avatar
The term 'floating' means something, it floats on the ground. Ground can move many inches with frost (depends on soil, temperatures, and other factors, but it moves...) The foundation won't move, it is below the frost line.
So tie the two together, and something has to give. The floating slab will move (up) with the frost, the foundation will stay in place, and oops...
__________________
My name is Peter, and I'm never going to grow up.
30 x 60, oops, 30 x 72 (it got larger!) with a Rotary 10K lift.
AM General H1 NA Wagon (95 For Sale)
AM General H1 Turbo Wagon (99)
Volvo S80
Mercedes Benz Sprinter RV
Saab Turbo Convertible
VW Cabriolet
nehog is offline   Reply With Quote
Old 08-27-2010, 07:49 PM   #4
Stuart in MN
Senior Member
Stuart in MN's Avatar
As far as I know, building codes in Minnesota won't allow a floating slab to be tied to a foundation. However, you're thinking about connecting the two with a breezeway and I don't know if that gets you around the problem or not. The garage will still move up and down with the seasons, which will put a strain on the connecting breezeway section.
It's probably a question for the building inspector. Here's the link to the Forest Lake inspections department, with contact names and numbers: http://www.ci.forest-lake.mn.us/inde...39ADD1392F2%7D There's also some code information online there; I took a quick look but didn't find anything specific to your situation.
Stuart in MN is offline   Reply With Quote
Old 08-27-2010, 08:01 PM   #5
mpraddict
Senior Member
mpraddict's Avatar
What are you trying to accomplish? Is this an existing enclosed garage slab that's sinking and you're trying to stabilize it? New garage slab and you're thinking it would be better supported on a foundation?
__________________
visit the nest ... www.roadrunnernest.com
my garage build
http://garagejournal.com/forum/showthread.php?t=7600
mpraddict is offline   Reply With Quote
Old 08-27-2010, 08:15 PM   #6
Gary S
Senior Member
Around here no floating slab can be tied to a house. Anything attached to the house needs to have at foundation wall down at least 4 feet and a footer under that.
Like already mentioned, floating slab means just what it says. If you attach something floating to something solid, it will break and cause you more problems than you bargained for.
Gary S is offline   Reply With Quote
Old 08-27-2010, 08:21 PM   #7
kbeitz
Senior Member
Why not just let it float ????
kbeitz is offline   Reply With Quote
Old 08-27-2010, 09:07 PM   #8
toolmiser
Senior Member
I'm over here in Wisconsin, and my house was built with a full basement, the garage was originally separate, but later attached with a breezeway (no foundation), then our home was annexed. I wanted to build an addition to the garage, and they said I needed to go below frost, so to keep them happy I did, because I was going to do the structure myself, and didn't want it to be examined with a microscope. I haven't had problems, but still think it was silly.
toolmiser is offline   Reply With Quote
Old 08-28-2010, 06:26 PM   #9
mpraddict
Senior Member
mpraddict's Avatar
I've seen frost heave concrete slabs. There's a good reason building codes require footings go below frost level.
__________________
my garage build
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
