Go Back   The Garage Journal Board > The Garage > Heating and A/C
Reply
Thread Tools Display Modes
Old 09-01-2010, 11:02 AM   #1
haugy
Senior Member
haugy's Avatar
Default Expandable foam to seal up a Pole Barn?
I have a pole barn, and with the steel's corrugation it has a small 2" hole at the base every 6 inches. And also at the top. I'm wanting to seal these up since I'll be insulating and drywalling. I don't need mice in there at the base, or wasps in the ceiling. Plus it will really help seal up my shop. I think
Is this the best way to do it? Just a quick shot of the foam? I've heard to use the blue type for window and doors since it isn't as heavy duty. I was told the Heavy duty ones can actually seperate screws and joints.
Is this a good or bad idea? If it's bad, any recomendations?
haugy is offline   Reply With Quote
Old 09-01-2010, 12:26 PM   #2
Possum
Senior Member
Default Re: Expandable foam to seal up a Pole Barn?
They make foam closures but they can be a pain in the ass. Do you have "rat guard" at the bottom?
Possum is offline   Reply With Quote
Old 09-01-2010, 12:52 PM   #3
haugy
Senior Member
haugy's Avatar
Quote:
Nope. Half of the building is above ground by about 10".
Old 09-01-2010, 02:31 PM   #4
Rosco
Senior Member
I've used both types of spray foam and am not fond of the blue can. It cost more and feels lighter. I had the same type of building in the past and the red can will work, you just have to be slow and wait for it to rise. I spayed all of my metal behind the post (very slowly) and let it sit for a day. Then I came back with a razor blade and trimmed off the excess. Sealed it up tight. The red can just needs to have room to expand or it can hurt some stuff. I have even used it to caulk with...........
Rosco is offline   Reply With Quote
Old 09-01-2010, 03:14 PM   #5
nonhog
Senior Member
nonhog's Avatar
Couple of ideas here... http://www.garagejournal.com/forum/s...t=26250&page=2
http://www.garagejournal.com/forum/s...ad.php?t=35522
Its not that hard to install this stuff it doesn't seal perfect but you could see
if something else was needed after the clousure strips.
Hope you can get to them o.k. Get a good charge on your cordless!
nonhog is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
