Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 09-01-2010, 03:45 PM   #1
652plus2
Junior Member
Default Supply Wire Size for 220 circuits
Hey guys,
I'm re-wiring my old garage - I added a 100amp subpanel and now I'm laying out all of the circuits. I want to run 4 dedicated 220 lines for my 6hp 80 gallon compressor, my electric oven for powdercoating, a mini-split hvac and a 220 mig welder. None of the runs will be more than 25' long. I know just enough about electricity to get myself in trouble. What size supply wire should I be using? The more I read, the more I think I should ask someone who knows. Can you help?
652plus2 is offline   Reply With Quote
Old 09-01-2010, 04:35 PM   #2
Charles (in GA)
Senior Member
Charles (in GA)'s Avatar
Default Re: Supply Wire Size for 220 circuits
Its 240 volt, not 220. You need to look on the data plates of each item and find out the amp draw of the equipment. The welder manual should tell you what to use on it.
Charles
Charles (in GA) is offline   Reply With Quote
Old 09-01-2010, 05:00 PM   #3
Rosco
Senior Member
Charles is correct. I ran 10/3 for my compressor, 8/3 for my welder, 12/3 for future mini-split and 6/3 for a free standing stove. It will all depend on the current draw from the appliance or tool. I always run larger just in case and then breaker it down.
Rosco is offline   Reply With Quote
Old 09-01-2010, 06:53 PM   #4
652plus2
Junior Member
Quote:
Charles
See what I mean...I know just enough to get myself into trouble. 220, 221...whatever it takes.
Thanks so much for your help. Lets say I haven't chosen a welder yet, ('cause I haven't) but I want to run my wires while I have the walls open. I'm a hobbyist restorer working mainly with sheetmetal, but I want a to step up from a 110 welder. Is there a wire size that I will be safe with without knowing exactly what machine I'm buying and without going wild?
Old 09-01-2010, 07:10 PM   #5
Rosco
Senior Member
Thats why I ran 8/3. I Might not need the extra wire or guage but I do not want to pull it out in the future.........I will just match my breaker size to the welder.
Old 09-01-2010, 07:15 PM   #6
sdowney717
Senior Member
I used 8/2 on the welder.
Craftsman AC arc welder with 3 prong plug is only 240 volt circuit.
Inspector approved!
sdowney717 is offline   Reply With Quote
Old 09-01-2010, 07:46 PM   #7
Norcal
Senior Member
Inspector approved!
That because a neutral is not needed & a waste of money for a 240V circuit.
Norcal is offline   Reply With Quote
Old 09-01-2010, 07:48 PM   #8
sdowney717
Senior Member
sure would have been!
Old 09-03-2010, 04:59 PM   #9
652plus2
Junior Member
Thanks for the help on this, guys. I don't post much, but I read here every day. This is a great forum.
Old 09-03-2010, 06:40 PM   #10
gatchel
Senior Member
Quote:
Great movie!
gatchel is offline   Reply With Quote
Old 09-03-2010, 07:47 PM   #11
ForceFed70
Senior Member
ForceFed70's Avatar
Well, to run a kitchen oven you need a 40A circuit which means 8/3 wire.
ForceFed70 is offline   Reply With Quote
Old 09-03-2010, 08:21 PM   #12
Norcal
Senior Member
Quote:
Depends on the oven, the nameplate tells all but how often is someone gonna install a oven in the shop? not unheard of but a rare thing.
Old 09-03-2010, 08:34 PM   #13
ForceFed70
Senior Member
ForceFed70's Avatar
Quote:
Well, he did mention electric oven for powdercoating in the original post.
Standard kitchen oven requires a 40A circuit. If he's using a specialty oven, then yeah... he'd need to know the reccomended circuit size.
Old 09-03-2010, 10:53 PM   #14
Norcal
Senior Member
30A is not unheard of for a oven....
Old 09-03-2010, 11:30 PM   #15
652plus2
Junior Member
Yeah, it's just a standard kitchen oven I bought for powdercoating, so I'll go with a 40A breaker and 8/3 wire. You can see some of the old set-up in my "pre-divorce garage" below. Now I'm trying to recreate that garage at my new residence. It probably sounds like I'm asking stupid questions, but I don't actually have my compressor, lift, oven, etc with me right now, so I can't just look to see what their requirements are. Everything was stashed in storage in another State when I moved out.
My new garage may be much smaller, but I'm far happier in it...trust me...
Old 09-04-2010, 12:33 AM   #16
Norcal
Senior Member
A freestanding range will require a min of a 40A* circuit, plus it's required to be 4-wire as grounding the frame of a appliance to the neutral is not allowed in new installations anymore, (Since the adoption of the 1996 NEC).
*Nameplate rating will determine the required circuit.
Old 09-04-2010, 01:24 AM   #17
ForceFed70
Senior Member
ForceFed70's Avatar
1 post you are saying it's not unheard of to use a 30A circuit, the next you are saying it's 40A minimum. Yes, yes.. look at the nameplate rating. But let me assure you that you're not going to find a regular 30" kitchen oven that requires larger than a 40A circuit. Nobody builds them because nobody has the wiring in their kitchen.
The OP already said that he'll use 8/3 wire.
Old 09-04-2010, 09:58 AM   #18
Norcal
Senior Member
ForceFed70: A oven and a range are 2 different things...........
Old 09-04-2010, 12:09 PM   #19
marslawn
Senior Member
marslawn's Avatar
I just read your post and I can comment on what I know. I have helped out an electrician for some extra work the last years. I put in 6/3 wire for my welder. If I were you I would buy a roll of 6/3 and use it for you welder and oven. The new ranges are almost all 50amp. You can always use a smaller 40amp plug with 6/3 wire. The compressor can be 10/2. I can't speak to your split hvac, but if you have enough 6 wire I would use that. Just remember when you go to install all these items that you use the correct breaker size for each item, this way your wire is protected.
marslawn is offline   Reply With Quote
Old 09-05-2010, 02:19 PM   #20
fflintstone
Senior Member
fflintstone's Avatar
my garage space grew by leaps and bounds when I got divorced.
I was much much happier.
I used to not have a clue with automotive electrical. I met a girl that crawled into the engine bay of my CJ8 and showed me how to use a multimeter. about 12 years latter she became wife2.0......
fflintstone is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
