Go Back   The Garage Journal Board > The Garage > Lighting & Electrical
Reply
Thread Tools Display Modes
Old 09-03-2010, 10:49 AM   #1
Thunderpigeon
Junior Member
Default Circuit Breaker And Wire Size For 5HP Air Compressor
I am in the process of hooking up my air compressor. The compressor has a 5 horsepower motor and will be located 45 feet away from the main electrical panel box. What size circuit breaker should I use, and what gauge wire should I use?
Thunderpigeon is offline   Reply With Quote
Old 09-03-2010, 11:02 AM   #2
phiftyseven
Default Re: Circuit Breaker And Wire Size For 5HP Air Compressor
Will need more info before that can be answered. Single phase or Three phase ? What voltage will you be using ? What's the amp draw on the motor nameplate ?
phiftyseven is offline   Reply With Quote
Old 09-03-2010, 11:06 AM   #3
Thunderpigeon
Junior Member
It is a single phase, 230 volt motor. The plate on the motor indicates 23 FLA and 25 SLA.
Old 09-03-2010, 12:20 PM   #4
sberry
Senior Member
sberry's Avatar
These type of comps run fine from a 10 wire and 30 breaker.
sberry is offline   Reply With Quote
Old 09-03-2010, 01:09 PM   #5
Thunderpigeon
Junior Member
Is 30 amps and 10 gauge a rule of thumb or is it based on a calculation?
Old 09-03-2010, 01:44 PM   #6
JBurgess
Senior Member
Here's a calculator for motor branch Circuits.
http://www.electrician2.com/calculat...tor_ver_1.html
JBurgess is offline   Reply With Quote
Old 09-03-2010, 03:44 PM   #7
sberry
Senior Member
sberry's Avatar
JB is correct to use the calculator and my take was a general rule due to the fact that although it is listed as 5 hp it is closer to 4 real hp. The calc says 8 and one reason I suspect is the allowance for heavy breakers. I am sure it has happened but I haven't seen one of that class trip a 30 and doubt it would ever a 40. The calc is for cable, a wire in pipe would change things a bit also.
A ? for JB and others, I see new breakers are listed with 60/75, this would change the calc also to allow 10? Apparently romex must be used with 60 degree termination?
Old 09-03-2010, 06:43 PM   #8
Aceman
Senior Member
Code says #8 Romex minimum on a 35-70 amp breaker.
I'd use #8 on a 40 amp breaker personally.
Aceman is offline   Reply With Quote
Old 09-03-2010, 07:21 PM   #9
type11966
Junior Member
I have a 5hp 24 amp draw. I used a 30amp breaker and 10-2 with ground romex. My licensed electrician friend help me.
type11966 is offline   Reply With Quote
Old 09-03-2010, 07:28 PM   #10
type11966
Junior Member
Here is my compressor and the small one in front of it that it replaced.
Old 09-03-2010, 07:49 PM   #11
sberry
Senior Member
sberry's Avatar
You have an owners manual for that? Just curious if the wire sizes are listed in installation instructions?
Old 09-03-2010, 08:03 PM   #12
Thunderpigeon
Junior Member
Thank you for the responses.
I don't have the manual. It is an older Atlas Copco Automan direct drive compressor.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
